This is a discussion thread titled "my tires are in! need advice asap", within the Tundra forum, part of the Truck Forums category.
Old 03-31-2008, 02:26 PM
benito_suave's Avatar
Dealer : Hayward Toyota
benito_suave's Photo Albums
Last Online: 10-14-2008 01:37 AM
benito_suave is on a distinguished road.
Default my tires are in! need advice asap
discount tire has my rims and tires in...finally! i bought the black 20" rockstars (9" wide, +35 offset) and 275/60R20 cooper LTZs. will these tires fit without the 2.25" spacer (front only) from the TGC leveling kit? i have the leveling kit, but haven't installed it yet. i want to put my tires on today
2008 Tundra 5.7L DC
Tundra owner since Feb. 2, 2008
Flowmaster 50 Series - installed 2/22/08
5 window tint - installed 3/21/08
20" KMC XD Series Rockstar rims - installed 3/31/08
275/60R20 Cooper Zeon LTZ tires - installed 3/31/08
Truxxedo Roll-up Tonneau cover - installed 4/17/08
Westin black nerf bars - installed 5/01/08
Black headlight mod - completed 6/14/08
Black front emblem mod - completed 6/14/08
Old 03-31-2008, 03:17 PM
eddiekidd's Avatar
Crest Pro Health
Dealer : Ramey Toyota
2007 Toyota Tundra,
- Other - 05 Legacy Sedan GT
My eBay eddiekidd's Photo Albums
Last Online: Today 09:33 AM
eddiekidd is on a distinguished road.
Default Re: my tires are in! need advice asap
If I'm reading your post correctly, I don't think you can fit a 33" tire under the front unless you raise it. I have 275/60R20's on the Pro Comp 6066 20x8.5 which has an off set of 32mm and a 6" backspace and a 2inch front leveling kit. I have very little room left when turning the wheel to a full lock according to the guys that installed them. They put one on my truck to check before balancing and installing the rest. I can't remember reading any post where a 33" tire was added without a leveling kit. I may be wrong but i don't remember any. You may just have to try it to know for sure.
Performance: Drop in TRD Air Filter; Classic Chambered True Dual Exhaust
Exterior: Clear lens headlight covers; Westin side steps; Ventvisors-in channel, Spray in liner, Rancho shocks 9000xl front and rear, Silverstar high beams & fog lights, Polarg low beams, TRD oil cap, Chrome door handles, Limited outside mirrors, EGR bug shield, Remote start, TRD rear sway bar, TruXedo Tonneau, Grille overlay, 275/60 on Pro Comp 6066 20x8.5.
Interior: Weathertech floor mats, Sport Pedals, auto-dim rear view and 35% side window tint.
SEARCH FIRST
Old 03-31-2008, 03:33 PM
JBK23's Avatar
Dealer : Butler Toyota Co.
2008 Toyota Tundra 5.7 X-SP
JBK23's Photo Albums
Last Online: Today 06:12 AM
JBK23 is on a distinguished road.
i thought he said 20'' from what I under stand.
2006 Double cab SR5 mods Leather seat covers, running boards 15% tint.
Old 03-31-2008, 03:42 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
DanielAcosta's Photo Albums
Last Online: 11-29-2008 09:41 AM
DanielAcosta is on a distinguished road.
You won't know until you try, but my guess is these will fit without the kit. Stock tires are 32, so if yours are 33 shouldn't be an issue imo. Note: I did not run a calculator to confirm your size is only 33.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 35K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), just swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 03-31-2008, 03:56 PM
RMcCleary's Avatar
Dealer : Toyota-Scion Of Bend
2007 Toyota Tundra,
- Other - 1997 Ford F-150
RMcCleary's Photo Albums
Last Online: Today 10:33 AM
RMcCleary is on a distinguished road.
I have 285/65/18 BFG All Terrain T/As which are the equivalent to 32.7 inches tall and 11.5 on a 8.5 inch rim. I am also running the stock TRD wheels (18x8). Now I looked at the Cooper LTZ. The size you have are equivalent to 33.03 inches tall and 11.06 inches wide. I don't have any issues with my tires and I am not running a leveling kit of any sort. Since your tires are .3 inches larger in diameter and .5 inches narrower I wouldn't think you would have any issues if you mounted them early without a leveling kit. Just take your truck down and have them mount your new rim/tire combo.
Ryan
2007 Tundra CrewMax SR5, 5.7L, 4x4, Black with Black Interior, Black leather, TRD package, Cold Weather kit, Line-X, Moonroof, BFG All Terrain T/A KOs 285/65/18, SnugTop SnugLid SL, White LED instrument display with Yakima Rack and soon Camburg Coilovers, Total Chaos UCAs, and a lighter right foot.
Old 03-31-2008, 03:59 PM
Dealer : Toyota of Plano
07DCwhiteSR5's Photo Albums
Last Online: Today 04:34 AM
07DCwhiteSR5 is on a distinguished road.
your posts almost never make sense....the 20'' is the rim....the 33 inch mentioned above is the overall tire diameter which obviously is larger than the rim since it goes around it.....thats the one that matters when u are squeezing it into a smaller opening...
back to topic....just try it and see...
just make sure it doesnt contact anything during full suspension movement and turns etc. or u can send them to me and i'll be glad to evaluate them.
Old 03-31-2008, 05:42 PM
los211's Avatar
Dealer : Piercey Toyota Scion
2007 Toyota Tundra,
2005 Toyota Sienna The wifes "bus"
los211's Photo Albums
Last Online: Yesterday 09:05 PM
los211 is on a distinguished road.
Hey man can you show us some pics when you get theses on??!?!?!?!?
Have your tire shop mount one and giver a try with the truck on the ground turning the wheel from lock to lock. That should give you a good idea if it works or not. Good luck.
'07 SR5 DC 5.7 silver sky metalic
5% tint rear windows, Flowmaster 50 SUV series w/ dual tips out the back, Carriage Works polished grill overlay w/emblem, 3-piece bumper inserts ( not CW), Airaid, Ground Force 2-4 lowering kit.
Old 03-31-2008, 06:24 PM
yep...my guess would be that it would fit since the diameter difference (between stock and the new tire) is only 1" larger and the width is .8" wider (255 vs 275). its in the shop now...so we shall see. T minus 90mins until I get off work and pic it up!
ya los211, i'll take a pic and post it right when i pick it up. might be a little dirty though since it rained a couple days ago. i might have it go for a bath, but with my past luck with car washes, it will rain again.
2008 Tundra 5.7L DC
Old 03-31-2008, 06:41 PM
los211's Avatar
2007 Toyota Tundra,
you know it always has to rain right after you wash it!!! I washed mine up today and with my luck we'll have a freak storm come in and I'll have to do it again tomorrow
Old 04-01-2008, 01:00 PM
i have my new rims and tires!!! copying from another thread so you guys don't have to do an extra click:
Just picked up my truck today. I went with the black XD Series Rockstars (20x8.5, +35mm offset) and the Cooper Zeon LTZs (275/60R20). I decided to try to put them on without installing the front spacers and THEY DON'T RUB! Even at full lock (both left and right), it doesn't rub. U-turns...no rub. Go over speedbumps at 10mph...no rub.
These coopers are quiet and runs smooth. I'm happy I went with this size too...I don't notice any power loss off the line (maybe there is some, but I can't even tell). Overall...VERY HAPPY with this setup. Here are some pics...sorry for the dirty truck. She'll be taking a bath tomorrow:
whatchu guys think?
Anyone who wants to buy my stock tires (255/70R18 with 1,500 miles) or steel-styled 18s, PM me.
2008 Tundra 5.7L DC
Old 04-01-2008, 01:04 PM
FIVEPOINTSEVEN's Avatar
Dealer : Stadium Toyota Scion
FIVEPOINTSEVEN's Photo Albums
Last Online: Today 09:25 AM
FIVEPOINTSEVEN is on a distinguished road.
Awesome...They look really good.
DCSB SR5 2WD
-THE MONSTROUS 5.7
-6SPD AUTO
-STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS
-K&N 77 SERIES INTAKE
-TOYTEC 3" LIFT
-DEBADGED
-SYLVANIA H9 LOW BEAM MOD (2100 LUMENS)
-HIR1 HI BEAM MOD (2350 LUMENS)
-SILVERSTAR EURO SIGNALS
-BLACK HEADLIGHT MOD
-BLACK BADGE
-JBL 440W SYSTEM W/ NAV W/ BACKUP CAM
-SONAR
-ESCORT PASSPORT 8500 X50 RADAR
-MOTO METAL 951 18" RIMS
-MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS
-BFG TA KO 285/65/18's!!(32.7")
-CHROME TOYOTA NERF BARS
-BEDLINER
Old 04-01-2008, 01:08 PM
Dealer : Hanlees Toyota Scion
reefer_bob's Photo Albums
Last Online: 09-13-2008 07:45 PM
reefer_bob is on a distinguished road.
What tire pressure are you running in the tires? I recently put the Zeon's on, and had some horrible noise at about 35 f/r. I bumped them to 40/38 and it got better. Then after talking to the manager at Discount tire, he suggested 30/30, and the're totally silent.
I'm really not sure I'm comfortable running that low of a tire pressure.
Wheels and tires look great!
Old 04-01-2008, 01:09 PM
Are you talking P-metric or LT?
Old 04-01-2008, 01:17 PM
thanks! not sure what my tire pressure is set at...just drove it off from discount tire so maybe they set it at 30/30? i'll be going back there in a couple days...i'll ask em when i get there or the next time i load gas i'll check.
2008 Tundra 5.7L DC
Old 04-01-2008, 01:18 PM
thanks 5.7!
2008 Tundra 5.7L DC
