Old 04-03-2008, 09:19 PM
Dealer : Valdosta Toyota
Last Online: 12-17-2008 10:31 PM
vykman is on a distinguished road.
vykman's Photo Albums
Default Gas pedal vibration is killing me!
There is a vibration in the floor board and gas pedal at almost every speed except wot. Esp. when just cruising. Vehicle was made 07/07. I have had it and need a real solution. Cant believe that toyota would let this roll off the line like this. Heard about various problems including the front diff. Plan on taking to toyota but want to give them a head start.
Old 04-03-2008, 09:51 PM
FL_Tundra's Avatar
Dealer : Sun Toyota Scion
2008 Toyota Tundra Radiant Red Limited
Last Online: 11-05-2009 07:40 PM
FL_Tundra is on a distinguished road.
FL_Tundra's Photo Albums
Default Re: Gas pedal vibration is killing me!
There have been a couple of other posts on here concerning the vibration that you are experiencing. Seems to be just a few incidents, and have not seen any one state what was done to resolve the problem. You might try doing a search to see if there was any solution posted. Hope you find an answer.
Old 04-03-2008, 09:59 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
The truck is drive by wire, there will be a bit more vibes than a cabled pedal because some of the resistance is missing.
What kind of shoes do you wear when you notice it most? Dress shoes I bet.
How high is the air pressure in your tires? Too much PSI can magnify it too.
Your tone is kind of hard to take seriously...If you want members to help you, I suggest you mellow out a bit...
Have your dealer check it out if you are not sure, that's what they are there for.
Beer please!
Old 04-03-2008, 11:04 PM
Tone reflects frustration after dropping 35 grand. I have read several threads where members have had the same problem, some to the point of new front diff. replaced. I love the truck but this one thing is getting annoying and cant help but wonder if it's part of a bigger problem coming down the road. You were right about the dress shoes!
Old 04-03-2008, 11:23 PM
Dealer : Fred Haas Toyota Country
Last Online: 07-19-2009 07:20 PM
tatmonkey is on a distinguished road.
tatmonkey's Photo Albums
i have this same problem and when i brake on those small reflectors also when somes exhuast is real low my pedals would vibrate even when bass coming from other peoples cars is this a problem i need to take to the dealer or is it really that wire?
