LinkBack (5) Thread Tools Display Modes
  #181 (permalink)
Old 04-12-2008, 10:46 PM
Last Online: Yesterday 10:40 PM
weverb is on a distinguished road.
weverb's Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by got wake? View Post
i want people to fear my truck coming down the road so far i've got the stebel horns. i'm in the process of upgrading from H11 to H9 headlight bulbs, the high beams to HIR1's, and my 5" hellas from 55 watt bulbs to 100 watt bulbs next i'm going to have a custom exhaust system fab'd up.
Let me know how the H9 and HIR conversion goes. This may be my next under $100 upgrade. I noticed they have an upgraded H11 that is 90% brighter listed too. I wonder which is better, the H9 or the H11+90?
  #182 (permalink)
Old 04-12-2008, 10:51 PM
got wake?'s Avatar
Dealer : Daytona Toyota Scion
Last Online: Today 10:02 AM
got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all. got wake? is a name known to all.
got wake?'s Photo Albums
i grabbed my camera to take some pics of one side upgraded and the other stock, but i left the memory card in my laptop i'll get some pics and info tomorrow. i may pick up a set of the osram nightbreakers H11's to compare to the H9's. the navara H9's are definitely brighter and whiter than the stock sylvania H11's. i was having trouble getting the high beam HIR1 to fit. i didn't have a lot of time to work on it, so maybe tomorrow i'll have it put in. the H3 100 watt bulbs are sick
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
  #183 (permalink)
Old 04-12-2008, 10:54 PM
I am jealous! I used a pair of toenail clippers on the HIR's I put in my wife's TL. The easily chipped away the plastic to make them fit. I will just and wait to see the pix!
  #184 (permalink)
Old 04-12-2008, 11:01 PM
got wake?'s Avatar
i modified the plastic tab, but they just aren't fitting in the housings. i may pull out the battery or windshield washer tank to get a better look at it and maybe get in there with a pair of calipers and measure the inside hole.
in the works:
to come:
  #185 (permalink)
Old 04-13-2008, 01:06 AM
Mtrosclair's Avatar
Dealer : Northshore Toyota
Last Online: 11-05-2009 10:16 PM
Mtrosclair is on a distinguished road.
Mtrosclair's Photo Albums
Which factory horn are you guys leaving on there the high or low tone?
You can make a difference---> http://www.carboncreditkillers.com/
"The tyranny of Murphy is the penalty for hubris."
  #186 (permalink)
Old 04-13-2008, 01:10 AM
FIVEPOINTSEVEN's Avatar
Dealer : Stadium Toyota Scion
Last Online: 07-22-2009 10:31 AM
Images: 17
FIVEPOINTSEVEN will become famous soon enough.
FIVEPOINTSEVEN's Photo Albums
For my little video clip the passenger side factory horn is in along with the stebel. I think it sounds pretty sweet...What do you think?
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS, K&N 77 SERIES INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MOTO METAL 951 18" RIMS, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
  #187 (permalink)
Old 04-13-2008, 01:14 AM
Images: 17
I didn't know the factory horns are two different tones??
DCSB SR5 2WD
  #188 (permalink)
Old 04-13-2008, 01:58 AM
Banned
Dealer : Sun Toyota Scion
Last Online: 05-19-2009 10:56 AM
blaster21996 has little shameless behavior in the past.
blaster21996's Photo Albums My eBay
Originally Posted by brow View Post
No relay?
Nope.... no relay needed!
  #189 (permalink)
Old 04-13-2008, 07:59 AM
got wake?'s Avatar
Originally Posted by blaster21996 View Post
I installed one yesterday. Here is what I did.....
I removed the factory horn on the drivers side. Then removed the flat bar from the horn and put in a vice, I then bent the flat bar in to a an offset, so the new horn will be located further under the crossmember it is atached to. I then clipped the factory plug of the hot wire for the factory horn and put on a standard female spade connector and connected it to the (+) terminal of the STEBAL. I then took a 8 inch peice of 12 guage stranded wire and put a female connector on one end, then on the other end I used a standard eye connector, I connected the spade end to the (-) side terminal of the STEBAL and the other end to the mount bolt of the STEBAL to ground it out.
I then upgrades the factory fuse from a 10a to a 15a fuse...... all done!
the stock wiring is what, 16 gauge? that equates to much less than 300 circular mils per amp, which gets into the dangerous range. 8 feet of 16 gauge with 18 amps passing through it = about 144 cir mills / amp. i've replaced enough wiring in peoples' cars from improper wiring/crappy blue headlight bulbs to know that i won't skimp on wiring. the fuse is not for the device hooked on the other end, it is for the wire going to it. i would highly advise against just hooking the stock wire to the new horn. electrical fires are not fun...
in the works:
to come:
  #190 (permalink)
Old 04-13-2008, 09:29 AM
alexisd's Avatar
Dealer : Palm Beach Toyota/Scion
Last Online: 11-06-2009 08:17 PM
alexisd is on a distinguished road.
alexisd's Photo Albums
I leave the stock wire from the stock horn to the new relay,that's ok?And then use in line 30 amp fuse and replace the 15 amp fuse for a 25 amp fuse is ok?Oh all wire with 12 g wire.Except the wire from the stock horn.You guy's think is fine,sound good.
2007 DC,Blue strike metallic,BBS rims,3rd ligth cover,x-sp,trd,calipers painted in blue.Chrome strips around the tailgate,,bug shield,wind deflectors.Side bed rails.G2 bakflip cover.TRD CAI,Alpine 2-1023d woofer,6x9 front dr,and 6x5 back dr speakers.1 Hifonics amp 4 channels,1-1000 wtts crunch amp for woofers.Dynamat all dr's,and back wall.Head ligths paint mod in black. Custom box 2 -10" woofers by Tech12volts.Chrome towing mirror covers,tail gate handle chrome cover,dr handle chrome cover.Billet grill top and bottom and bumper insert.Custom made dr sill's and dr pillar overlay by Billet technology.Stebel horn.More to come.
  #191 (permalink)
Old 04-13-2008, 10:23 AM
GGWOODY's Avatar
Kibble Wrangler
Dealer : Alexander Toyota of Franklin
Last Online: Yesterday 05:54 PM
GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One. GGWOODY is the One.
GGWOODY's Photo Albums
Yes, stock wire goes to new relay.
What 15A fuse are you replacing for a 25A? (the 'HORN' fuse on the OE fuse block is a 10A) Use an in-line 20A fuse on your hot wire going to the relay, just to be on the safe side (the packaging recos it, and if you can use a smaller fuse without blowing it, why not?)
Want to know what's ironic? My Polish grandparents who were captured during the Warsaw Uprising.
Grandmother was enslaved in a German concentration camp and forced to make artillery shells for the 3rd Reich. Grandfather was in German and Soviet POW camps...ending up in Siberia. After WWII, they moved to the USA to be free, but Obama has turned it into the USSA...Grandaddy is rolling in his grave.
CBTMA Member
  #192 (permalink)
Old 04-13-2008, 11:32 AM
Mtrosclair's Avatar
yup factory horns have one high tone and one low tone, its marked on the back with either "high" "low" or "H" "L"... I will experiment to see which one sounds better..
  #193 (permalink)
Old 04-13-2008, 12:05 PM
Mtrosclair's Avatar
Just went outside and hooked up both of the stockers, it really does sound like a train!!!
  #194 (permalink)
Old 04-13-2008, 12:33 PM
Images: 17
Which one sounded better with the stebel?
DCSB SR5 2WD
  #195 (permalink)
Old 04-13-2008, 12:55 PM
awesomebase's Avatar
Dealer : Jones Toyota
Last Online: Today 09:01 AM
awesomebase is on a distinguished road.
awesomebase's Photo Albums
pulled out my old cheap ratshack meter today and measured the horns. one horn measured 114 dB and two measured 117 dB at the same distance. so to reach nearly double the volume, we'd need at least 8 horns (9 dB increase). 10 dB's equates to double the volume.
i might try hooking up the stock horns as well tomorrow to see how it sounds. two stebels plus both stock horns = really effin loud
Just wanted to make a correction... a 3dB increase = approximately double the volume (1.99526 to be exact), not 10. So, in fact you already are getting double the volume since your increase was from 114 to 117 dBs...
07 Tundra CrewMax 4x4 SR5 Silver Sky Metallic is here!
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/129425-new-stebel-300-hz-truck-horn/
Posted By For Type Date
ClubCJ - The CJ Lancer Club :: View topic - Louder horn for CJ? This thread Refback 11-04-2009 04:15 AM
Viper Sailboat Historydodge, Viper Motorcycle Exhausts, Virago 550 Yamaha Motorcycle - Wireshelf This thread Refback 03-08-2009 10:48 AM
ToyotaVanPeople.com • View topic - Horn Replacement Rules ok This thread Refback 12-21-2008 05:14 AM
My horn is louder than yours... - Wander the West Forums This thread Refback 07-15-2008 10:23 AM
STEBEL - Zoekmachine totaalzoeker This thread Refback 05-04-2008 03:36 PM
