This is a discussion thread titled "New Stebel 300 Hz Truck Horn", within the Tundra forum, part of the Truck Forums category.
Errr... that seems a bit strange. How did you wire it in?
I have one horn. Wired it to work in tandem with both the stock horns. What I did was use the power from the stock horn, driver's side, to be the switched power on the relay. The output to the stebel and driver's side horn comes out of the relay. The relay power comes directly from the battery, via 20A fuse. Stebel is independantly grounded and the relay has a good ground as well. My one concern is that I may have gone a little light on the wire to the stebel. I believe I used 20 guage wire. Will double check. I can snap some pics later to better illustrate what I've just explained, a pic is worth a 1000 words eh.
Thanks everyone for your help!!
'07 Pyrite crewmax LTD "B" package w/ 18" wheels (BFG 285/75R18 A/T KO) - 51,000 kms since April 30/07!!! ARE canopy, hunter bullbar (careful) and running boards, TGC 2.25" front leveler, & husky liners. Air Lift 57299 Air Springs.
'07 USA market Honda Odyssey EXL-RES imported to Canada (sorry Honda Canada, this one reads MPH)
20 gauge wire is WAY too small for the current draw of the horn. that's getting into the fire hazard range. double check that, cause i'd hate to see someone burn something up from improper wiring.
2.4" front/1" rear leveling kit - toyo A/T 285/75/18 tires - bull bar with hella 500FF lights - 20% tint side and back windows - 55% full windshield tint
in the works:
stock HU -> LOC -> PPI FRX-456 -> DLS A4 + Marathon 6150 -> DLS iridium 6.2 comps + Hybrid-Audio L3's + 4 Tang Band W6-1139SI's
to come:
JBL MS-8 + center channel speaker + components for the rear + sirius adapter for stock HU
Another question cropped up in my head as I was reading what you wrote about the window roll up button...
Brow,
Do you notice the dimming headlights when you are at idle, or while driving at elevated RPMs?
The reason I ask is that the window rollup button dims the lights at idle, but not at higher engine speeds.
at idle, stock alternators barely put out enough current to keep the vehicles stock electronics/engine running. peak output is usually between 1,500 and 2k RPMs. high output aftermarket alternators are even worse for idle output. an easy fix for that is to reduce the pully size on the alternator to get it spinning a little faster at idle. our engines can certainly handle the minor added load.
in the works:
to come:
OK been reading this thread and ordered the Stebel.
I have seen every mounting possible (almost) of the horns...
I just bought some 12 Ga wire and an inline fuse socket...now how do you connect the 12 Ga. wire to the battery ???
and what voltage 20 Amp fuse ? (this I was asked by my local ratshack rep)
So far the pics I've seen cleverly show everything but....
BTW great group of various backgrounds make this site one of the most informative
__________________ 2007 Red Rock Edition DC, 4X4 4.7L Tundra Limited' 20" wheels,Nav sys w/ backup camera, sonar, Bluetooth, 2" towhitch, folding mirrors, running boards, dual air, underseat storage.. etc. etc.
what kind of fuse socket did you get? can you post a link to rat shack's product listing?
i used a ring terminal to connect the main 12 gauge wire to the battery. i used the same size ring terminals for the ground (i think).
in the works:
to come:
Got mine installed. I replaced the drivers side horn, so I am running the Stebel and the high tone stock horn together. I LOVE the sound. I figure that I'll never get cut off by the same car twice!
Between the horn install and the Corsa exhaust install (which of course came after a few laps around the neighborhood with no muffler!), the neighbors must really love me now.
. 2007 TUNDRA 5.7L SR5 TRD 4x2 Double Cab, Salsa Red Pearl
TRD CAI, Corsa Sport Side Exit Dual Tip Exhaust, Stebel 300Hz Air Horn, OEM Tundra Mud Mats, Black powder-coated side-step bars, Ventshades, Line-X, TRD Sway Bar, Blacked headlights surround, White LED guage and dash lights, Viper 771VXR Remote Start / Alarm, Carriage Works black billet grille with logo remount (awaiting install).
What did you use for your fuse holder? I was under the impression that all this hardware came with the horn... guess not
Looks like I get to go dig around at the random parts store
What did you use for a fuse holder? Are you considering changing? (I ask because of your comment above)
this is the fuse holder that i got, except mine has larger wires going to it:
pretty much any automotive fuse holder that is rated for at least 20 amps will work fine. the reason i asked the other guy was because the cylinder glass fuses are usually the ones that the ratshack guys ask what voltage you need, and i prefer to not use them in automotive applications, unless its for low amperage.
in the works:
to come:
try the stebel with just the stock low horn or both. i'm trying to decide if i like it with just the low, or both the high and low best. but i like it with just the low better than just the high.
in the works:
to come:
