LinkBack (6) Thread Tools Display Modes
  #421 (permalink)
Old 10-31-2008, 06:42 PM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: 11-04-2009 11:46 AM
jliltd is on a distinguished road.
jliltd's Photo Albums
Default Re: New Stebel 300 Hz Truck Horn
Originally Posted by Swatdude1 View Post
I am the original poster and mine is still going strong!!! One thing you need to pay attention to is the way you mount it. The opening should always be facing down so no bug guts or water gets in and ruins it. Try to to blow it in a hard down pour because it could suck water into the tiny compressor. If you follow a few preventitive measures, I see no reason why this horn shouldn't last a long time.
Also, you can attach a tube to the air intake of the horn with the included adapter. I have yet to do this but I will take the tube to the engine compartment so it gets clean air and doesn't suck in any water.
Here is a picture of how I mounted mine before I cleaned up the wiring. I used Stebel's factory mount bolt and drilled a hole in the center vertical support bracket for a quick no-bracket install. I also used some 14/4 trailer wire for a ruggedized run since it was already sheathed. I didn't have 12 guage wire so I used two of the 14 guage wires for an overkill on the power lead. The negative is already a 12 guage wire. I also used the passenger-side horn wire for the relay signal (white wire):
This gave me about 1.5" to 2" clearance between the horn and the radiator as shown:
I mounted the 12V relay near the battery and ran the white wire to it for signal while attaching the 12V source directly to the battery with 12Ga wire.
Here is a final shot after I covered the wiring with convoluted tubing to protect the wires and keep the front end in front of the radiator all black. You can easily see the plastic air input fitting on the lower front that I'm going to attach some tubing to as soon as I get a chance:
Sounds great when combined with the two factory horns.
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
  #422 (permalink)
Old 11-08-2008, 02:48 PM
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 08:15 AM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Just added it to my existing 2 stock ones. First impression from the driver's seat: yeah! it's loud, different.
But then I came to show it to my buddy, and told him go to the hood I want to show you something. He expected me to open the hood, but I just blasted the horns, by the expression on his face I thought it's time to change the diapers. He was like, man that is loud.
I asked him to blast it when I was upfront and can tell you, you can not compare this sound to the one you hear from the cab, it is so freaking loud! Like one of those train horns. Really recommend this one!
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
  #423 (permalink)
Old 11-10-2008, 11:56 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
I scared the crap out of a red light runner this morning...look on the JO's face was priceless.
...A TRAIN!!!!
Beer please!
  #424 (permalink)
Old 11-10-2008, 12:05 PM
RudyDep's Avatar
Moderator
Dealer : Universal Toyota
2007 Toyota Tundra,
- Other -,
2008 Toyota Sequoia Slate Metallic Ltd
Last Online: Yesterday 06:18 PM
Images: 23
RudyDep has blessed us with their presence. RudyDep has blessed us with their presence. RudyDep has blessed us with their presence.
RudyDep's Photo Albums
Im LMFAO....Shane, you ROCK !!!!
I had a guy try to force his way onto an off ramp in front of me. I laid on the horn, needless to say he missed his exit. I was TRIPPIN...
This horn is by far the BEST mod and investment that ive made since buying this truck.
Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member"
all that is remaining is:
Black Mod Headlights
1997 Chevy Tahoe Sport 4x4
2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem."
President Ronald Reagan 1985
  #425 (permalink)
Old 11-12-2008, 05:42 AM
Last Online: 11-12-2008 05:42 AM
Roadie250 is on a distinguished road.
Roadie250's Photo Albums
Here's a pic of the Stebel Compact Nautilus Truck Horn and the TM80/2 Magnums installed on my 08 Tundra.
Loud Motorcycle Air Horns
  #426 (permalink)
Old 12-15-2008, 10:23 AM
maisano's Avatar
Dealer : Freeman Toyota
2006 Toyota Tundra DC 4X4,
2007 Toyota Sienna
Last Online: 10-30-2009 04:29 PM
maisano is on a distinguished road.
Send a message via AIM to maisano Send a message via Yahoo to maisano maisano's Photo Albums
wow this thing is great i finally got to install mine this weekend and i like.
4x4
roll n lock bed cover
painted OEM rims---265/75/16 BFG AT
no chrome
12" solobaric
hellwig swaybar
dvd headrest
bilstein 5100 front
5% front and 2%back tint
escort 9500 radar dectetor
rhino lined
toyota all weather mats
AVS in-channel visors
stebel horn
scangauge ll
  #427 (permalink)
Old 12-31-2008, 02:53 PM
DesmoBob's Avatar
2008 Toyota Tacoma
Last Online: 03-09-2009 06:08 PM
DesmoBob is on a distinguished road.
DesmoBob's Photo Albums
This is my first post, just want to say hi, and basically this thread is what got me to register for this forum.
I have to say this will be the first mod on my truck! I actually read all 29 pages of this thread.
  #428 (permalink)
Old 12-31-2008, 02:57 PM
mxsjw's Avatar
Images: 10
Mine seems to have stopped working...
over-useage?
wire disconnect?
Will check it out this weekend and report back.
Beer please!
  #429 (permalink)
Old 12-31-2008, 10:27 PM
TO_Tundra's Avatar
Last Online: 07-01-2009 10:41 PM
TO_Tundra is on a distinguished road.
TO_Tundra's Photo Albums
boy do i need one of these babies up here in toronto!
2007 Black/Slate Tundra CM LTD 5.7L 4x4
OEM Navi, DVD, Cam, Bedliner, Steptubes
HID kit/smoked tails/Bed Mat/Full DeBadge
RollnLock Cover/Cane Corso Security System
305/60/20 Toyo Open Country A/Ts (35")
20" stock rims/3"/1" SST ReadyLift
K&N 63 CAI/BackRack
  #430 (permalink)
Old 01-13-2009, 03:25 PM
Dealer : Toyota of Richardson
Last Online: 11-09-2009 12:16 AM
Nobull is on a distinguished road.
Nobull's Photo Albums
Hey,
I just got mine up and running - it is awesome. I added mine to the two factory horns and there is no doubt that if you pull out in front of me you will think you are about to be hit by a train!
Special to jliltd for the wiring diagram - it made it much easier.
As a funny side note I was chatting to a friend online and she asked if this new horned played Dixie - I said no, it plays "get the $%^& out of my way!"
2007 Tundra Crewmax 2WD TSS package
Dual INViSiON DVD Headrests, BakFlip Tonneau Cover (G2)
  #431 (permalink)
Old 01-13-2009, 03:30 PM
maisano's Avatar
2007 Toyota Sienna
over-useage?
wire disconnect?
any updates yet. as the over-useage i do seem to honk more. i know if i still have a motorcycle this would be the fiirst thing i have. on of my buddies wants to put it on his atv...
4x4
no chrome
12" solobaric
hellwig swaybar
dvd headrest
bilstein 5100 front
rhino lined
stebel horn
scangauge ll
  #432 (permalink)
Old 01-13-2009, 03:45 PM
mxsjw's Avatar
Images: 10
Still hasn't fixed it's self and I haven't bothered to pop the hood and take a look...I'll try to dig into it within the next couple days.
Beer please!
  #433 (permalink)
Old 01-13-2009, 08:51 PM
08SalsaMax's Avatar
Last Online: Yesterday 10:01 PM
Images: 43
08SalsaMax will become famous soon enough. 08SalsaMax will become famous soon enough.
08SalsaMax's Photo Albums
Try the relay. If it's bad, just replace the stock Italian one with a Bosch German one.....
2008 Toyota Tundra 5.7L 4x4 Limited Salsa Red CrewMax
  #434 (permalink)
Old 01-15-2009, 11:24 AM
mxsjw's Avatar
Images: 10
any updates yet...
Originally Posted by 08SalsaMax View Post
Try the relay...
Got it, I had blown the fuse. Replaced and I'm back in business.
I figure it must have went when we had our big snow/rain storms and I was blasting it to get people out of the way. Must have had some extra moisture on the relay or on the in-line fuse.
Beer please!
  #435 (permalink)
Old 01-15-2009, 12:06 PM
RudyDep's Avatar
Moderator
2007 Toyota Tundra,
- Other -,
Images: 23
Mine did the same thing....and those fuses are odd too! I wonder what the current draw is on that horn plus the two stockers?
"CBTMA Member"
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/129425-new-stebel-300-hz-truck-horn/
Posted By For Type Date
ninemsn Shopping This thread Refback 11-18-2009 06:42 AM
ClubCJ - The CJ Lancer Club :: View topic - Louder horn for CJ? This thread Refback 11-04-2009 04:15 AM
Viper Sailboat Historydodge, Viper Motorcycle Exhausts, Virago 550 Yamaha Motorcycle - Wireshelf This thread Refback 03-08-2009 10:48 AM
ToyotaVanPeople.com • View topic - Horn Replacement Rules ok This thread Refback 12-21-2008 05:14 AM
My horn is louder than yours... - Wander the West Forums This thread Refback 07-15-2008 10:23 AM
STEBEL - Zoekmachine totaalzoeker This thread Refback 05-04-2008 03:36 PM
