LinkBack (5) Thread Tools Display Modes
  #31 (permalink)
Old 04-21-2008, 08:02 AM
Dealer : Thompson Toyota
Last Online: Yesterday 05:29 PM
Images: 4
hoffmavl is on a distinguished road.
hoffmavl's Photo Albums
Default Re: DIY: How-To Enable “Anytime” Fog Lights for $15 or Less
TKIEU83,
Plug the socket into the relay, splice 30 and 86 together just a few inches from the socket replay, and leave a pick tail, another words when it’s finished it should look like a upside down Y. Add the spade connector to the end of this connection, and another one on wire coming from 87; plug both of them into the fog switch relay. And follow the rest it does work
  #32 (permalink)
Old 04-21-2008, 04:24 PM
Dealer : Toyota Walnut Creek
Last Online: Yesterday 04:28 AM
TKIEU83 is on a distinguished road.
Send a message via AIM to TKIEU83 TKIEU83's Photo Albums
thanks hoffmavl, i'll try that on thursday my day off, based off the instructions, i just wired the wires straight to the relay, did any of you have a hard time, connecting the large wire from the relay to the pink wire under dash? pink wire is very thin.....
2007 Slate CrewMax LIMITED 4x4 CURRENT
2007 Super white DoubleCab 4x4 TRADED
2004 PWP RSX type S 6sp ITR make over SOLD
1994 White integra LS full ITR make over SOLD
  #33 (permalink)
Old 04-22-2008, 10:29 AM
Images: 4
I used a wire nut, mush easer
  #34 (permalink)
Old 04-22-2008, 06:25 PM
MechEng1's Avatar
Dealer : Stevens Creek Toyota
Last Online: 10-07-2009 10:29 PM
Images: 17
MechEng1 is on a distinguished road.
MechEng1's Photo Albums
This was so easy and so quick to do, but the only pain is just the wires are so short for stripping and splicing. I did the jumper wire option only. Everything is fine. I will try to take a pics to post here when I get the chance.
  #35 (permalink)
Old 05-08-2008, 11:18 PM
BENNETT_79's Avatar
Dealer : Johnstons Toyota Scion of Middletown
2008 Toyota Tundra Blue Streak TRD SR5
Last Online: 11-16-2009 01:38 AM
Images: 14
BENNETT_79 is on a distinguished road.
BENNETT_79's Photo Albums
anyone else besides me wire this to work with the parking lights? the feature i like the most is that you can leave the switch in the parklight position and they turn on and off with the key.
2008 DC SR5 TRD 5.7L Blue Streak Metallic
MODS:TO MANY TO LIST
GO YANKEES!!!!!!!
UNION:
I. A. OF M. Lodge 447 District 15
www.vforcecustoms.com vinnie & cody-formerly of orange county choppers
  #36 (permalink)
Old 05-24-2008, 10:49 AM
Eddie's Avatar
Moderator
Dealer : Crystal Toyota
2000 Toyota Tundra,
- Other - 93.5 Supra
Images: 32
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
Originally Posted by Eddie View Post
I'm glad someone finally had time to try this mod. I posted something similar a while ago,involved cutting two wires to bypass body ECU control of the relay.
With this mod you must have the parking or headlights on for the fogs to work.
Frank (or anyone else with a multimeter) can you check if terminal 1 (green wire) at the OEM fog relay has voltage with the parking or headlights on? I don't have a 2nd-gen Tundra to test,but I may be right since it's from the taillight relay. If it does,the mod will be even cheaper to do
Hey everyone,if you read Frank's pdf of this modification http://www.tundrasolutions.com/forum...htseddiev1.pdf the gray wire at connector AJ10 is cut instead of the light blue wire I indicated above.
He did this because access to connector AJ10 is easier than to the blue wire going into the body ECU. Other than the change in where the ECU "FFGO" connection is bypassed,this is still the same mod.
This is how it looks like as per Frank's document ...
Again,this is still the same mod I originally posted,Frank just found a better location to bypass the body ECU wiring. Thanks again Frank for testing and verifying that the mod works
  #37 (permalink)
Old 01-10-2009, 01:14 PM
PowerHogger's Avatar
Dealer : Fred Haas Toyota Country
Last Online: Yesterday 04:35 PM
Images: 8
PowerHogger is on a distinguished road.
PowerHogger's Photo Albums
Would these mods work without a foglight switch? My car right now has no foglights installed therefore no switch. If i were to buy the fog lights without buying the switch for the steering column would this mod work if i were just to turn on the headlights?
  #38 (permalink)
Old 01-10-2009, 01:20 PM
mendonsy's Avatar
Dealer : Lebrun Toyota
Last Online: Today 09:13 AM
Images: 7
mendonsy has blessed us with their presence. mendonsy has blessed us with their presence. mendonsy has blessed us with their presence.
mendonsy's Photo Albums
No. I don't think that your truck will have the relay or the wiring installed.
You probably need to read this one:
DIY: OEM Foglight Install
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors
CBTMA member
  #39 (permalink)
Old 01-10-2009, 06:23 PM
Images: 8
Actually i saw that there were the wires for foglights under the car so i dont know.
  #40 (permalink)
Old 01-10-2009, 08:37 PM
mendonsy's Avatar
Images: 7
If you have the wiring harness, then you will need to install the fuse, relay, and fog lights as described in mhadden's OEM Foglight Install DIY. All you will lack is to supply a ground on pin 2 of the relay (gray wire). There are several ways to do this including just grounding it (be sure to cut the wire), but I would recommend at least a switch or some variation of the Anytime Fog Lights.
Toyota SS steps
ARE MX cap
AMP bed step
CBTMA member
  #41 (permalink)
Old 04-01-2009, 08:08 PM
Last Online: 04-04-2009 06:14 PM
jojotundra is on a distinguished road.
jojotundra's Photo Albums
My 09 Tundra didn't come with fog lights. I want to install them as cheaply and easy as possible. I know the wiring is there from the fog lights to the relay/fuse panel. Can I use a SPDT 30 amp relay with the signal to turn on the fogs by jumping from the headlight relay? I really don't need a dash mounted switch and I want the fogs on anytime the headlights are on.
  #42 (permalink)
Old 05-30-2009, 04:36 PM
Last Online: 07-10-2009 12:26 AM
maltezf is on a distinguished road.
maltezf's Photo Albums
Hello, does anyone know if this would work on a 2005 Tundra DC with day time running lights? Or if you can point me in the right direction, thanks. Frank
  #43 (permalink)
Old 06-05-2009, 03:08 AM
Dealer : Carlson Toyota
Last Online: 09-13-2009 01:01 PM
duanels is on a distinguished road.
duanels's Photo Albums
Originally Posted by Lightning Rod View Post
Frank,
What is the process to have the for lights operate with the stock switch, but only when the any of the main lights (driving and/or headlights) are on.
I believe this is what most want...
I also believe with another relay, you tell me, the fog lights will go out when the high beams go on. I believe we here have a law where only 4 front facing lights can be on at a time.
Thanks
Rodney
Hear in MN I we have The law where only 4 front facing lights can be on at a time. I would like to see the lights work with driving and/or headlights put go off with high beam Would that be possible?
  #44 (permalink)
Old 08-17-2009, 05:34 PM
Last Online: 11-03-2009 04:57 PM
jbrittmartin is on a distinguished road.
jbrittmartin's Photo Albums
i'm about to do this mod.
i have one question though.
Option C says the fogs will stay on 2 hours after the ignition is turned off. why would anyone want my fogs to stay on 2 hours?
or will they cut off whenever i use my key fob like my headlights do?
  #45 (permalink)
Old 08-17-2009, 05:46 PM
mendonsy's Avatar
Images: 7
No. Option C wires them to the power outlets which stay on for 2 hours after the key is turned off. Actually I thought it was 90 muniute, but that's not important.
Toyota SS steps
ARE MX cap
AMP bed step
CBTMA member
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/130303-diy-how-enable-anytime-fog-lights/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-14-2009 12:05 PM
Fog light mod 08 Tundra? - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-15-2009 01:06 AM
Fog light mod 08 Tundra? - IBTO Toyota Tundra Forum This thread Refback 07-02-2009 05:43 PM
Fog light mod 08 Tundra? - IBTO Official Forums This thread Refback 05-21-2009 07:56 AM
Fog Lights on with only the parking lights - Toyota Forums :: Toyota Nation This thread Refback 09-11-2008 08:07 PM
