Re: OEM Backup Camera Install With Auto Anytime Camera
Originally Posted by Targamond
Thanks for the clarification guys and the addition picture (Pedro). That is the view I would consider 'functional' for a rear-view cam.
It seems like the flip-down monitor would get to be a pain - having the extra process of flipping it down when you are backing. For those who have had this option for awhile, do you find the flip-down annoying and wish you had the fixed mount?
I would have to agree. But I think the screen on the drop down is a little bigger. The fixed one is kind of small.
Best bet if you dont have one and your stereo system is need of an upgrade anyhow, just get an indash DVD with a nice 7" screen, buy a rear cam for about $100-150 and veiw your cam right through the head unit screen, get the best of both worlds.
__________________ 2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
I installed the flip down one in both my Tundra's. I looked at the old fixed style version and didn't like the viewing angle. The quality of display in the flip down version appeared (may have been the light) to be much sharper. The display also appeared slightly bigger - but I didn't actually see them side by side, so this may have been an illusion.
I don't find flipping it down a pain. Of course you could always leave it down all the time if you wanted to. I like the idea it folds away - only to be brought out when needed.
If I am honest I also like the idea that it is the latest version, just for that sake alone
Originally Posted by yoyo123
can be install a buckup camera an 2008 tundra v6
are they prewired if anyone knows
Make sure you have the prewired plugs at the rear of the truck, find yourself something to lie on and get under the rear of the truck on the passenger side. Look up next to the spare wheel and you should see this loom and plug.
If you don't it can be done as a retro the wiring is easy I would suggest using the flip down monitor with my anytime modification (See Post #3) then you don't have to find reverse wires etc as you have to flip down the monitor to see it hence turning it on.
If you need more help just ask
Pete
Thanks
Pete
2007 5.7 SR5 DC Long Bed - BFG Rugged Trail 275/70/18 - A.R.E LSII Cover - Leveling Kit - Leather Interior - Spray Bed Liner - SL2Vi iPod Interface -
OEM Fog Light Switch Installed - Blinglights On Fog Circuit -
Mini Fogs In Bumper Slots - Sirius Connect With TOY-SC1 -
Radar Power - OEM Anytime Backup Camera -
DU HA Under Seat Storage
Can this mod be done without the flip down monitor and using say an Alpine IVA-W200... It has a wiring harness for a backup camera with a signal wire that goes to reverse circuit in order to switch it during reversing. Any power issues with this or can I simply substitute installing the screen for wiring up the headunit?
Josh
2008 Salsa Red Pearl DCSB SR5 2WD
Corsa Sport Single Exit, Doug Thorley's, 20% Tint up front, Line-X, Access Roll-Up Tonneau, Alpine Touchscreen Nav, Sirius Satalite Radio... VA 757 Area Group MEETS
Future Mods: Color Matches Grill, Lowering Kit, TRD CAI, Wheels, Fender Flares, Supercharger, JL Stealthbox, Black Headlight Mod...
Josh
If your using the Toyota camera you will need to install a voltage regulator to drop the camera voltage down to around 6 to 7 volts that is normally supplied by the monitor but other than that you have the basic outputs from the camera that you would have from any other.
You will need to search some of the other posts for installing HU's to find regulator and reverse wires info if you need it.
You could also install an anytime switch
Thanks
Pete
Josh
Josh,
Yes. Here's an _outstanding_ writeup describing the installation of an incredible system including the back up camera.
I installed a Kenwood DNX5120 and used the factory camera and wired it to the kenwood. Picture is much bigger. I wired it so it would come on anytime or when shifted into reverse. Install is pretty simple.
Do a search for Kenwood 5120 on here and you can see the rest but here is the screen shot with the Kenwood...
Just want to thankyou Pedro, for awesome directions and Pics. I couldn't have installed my camera/monitor kit without them. One question though, the one thing that I have that was left over was a small foam strip about 3-4 inches long with 3m sticker behind. Where does this go, somewhere around the monitor is my guess. Does it go behind it? Anyone know..
Thanks again.
Good Morning Pedro, Great DIY Article. Thanks for taking the time to document it and share it with us.
Question for you.
I noticed your article has a Pre- title of “DIY Contest Article….” Yet it was posted on 4/22/2008.
Can you tell me how you included this “Pre Title” for the contest? Was this a previous Contest you submitted this article for, or the current DIY Contest?
I have several DIY articles I have already posted that I would like considered for the Contest if this is allowed.
I have no clue, one of the mods must of put it in the contest
Thanks
Pete
Re: DIY: OEM Backup Camera Install With Auto Anytime Camera
Installed my rear view camera. Thanks to your great write up, it went smoothly. Didn't do the anytime mod yet, I will try it stock for a while. Thanks.
Like allot of other people after getting my new 08 tundra I wanted to install accessories. The camera was easy to install. Installed a factory flip down one but now I really don't know what I was expecting. I do like gadgets but I think it was the biggest waste of money I could have spend. Just the old Porkers opinion.
Anyway to bring those pics on the first page back to life?
__________________ 2007 Silver Sky Metalic SR5 TRD 5.7L 4X2 Crewmax.
JBL Sound System
Autodimming Mirror
Bucketseats
Bedliner
(FE, EJ, BU, OF, RL, SO, SR, N1, LU, C4) Just added:
5 piece Carriage Works Billet Grill. No Logo
Bed Extender
Exhaust Tip
Wet Okole Seat Covers
Anodized Aluminum Shift Knob
Door Sills
Sport Pedals
Tow Mirrors
Raptor 4" Stainless Oval Tube Bars
TRD CAI (with HC filter mod)
TRD Sway Bar
Truxxx 3"/1" lift
20% Tinted Front Windows
Bed Rail over OEM Bed Liner
Relocated Rear Window Button
Coin Holder Replaced With Garmin GPS Mount
50 Series Flowmaster
