***please Answer Question***
I have been searching this site for months now and I have not found a definite answer on a couple of questions. So if you could please answer the question to those of whom it applies.
1. Does 285/65/20 tires work with a Toytec lift without rubbing? If so, is there any modifications that need to be done for it to work without rubbing? I plan on using Pro Comp 6066 wheel 20x8.
2. Can you install a TRD Sway bar with a Toytec lift or any leveling kit?
Those of you who respond, thank you for your patience with these exhausted questions?
I want to make sure I do it right the first time before I spend any money.
