  #31 (permalink)
Old 05-12-2008, 07:29 PM
low c1500's Avatar
Dealer : Red Deer Toyota
Last Online: Yesterday 11:33 AM
Images: 1
low c1500 is on a distinguished road.
low c1500's Photo Albums
Default Re: Get better fuel mileage guaranteed
Originally Posted by TundraBay View Post
Yeah, but what about the cold winter air intake? Doesn't that result in a more efficient engine?
Not at all. The cold air will result in more peak HP. But that air is less "willing" to mix with the fuel before combustion, and there is more energy loss involved in heating up the cool air during combustion.
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
  #32 (permalink)
Old 05-12-2008, 07:33 PM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: 11-16-2009 10:10 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Oh no!!! so the CAI I put in is going to hurt my mileage!!!
I just can't win
[Tundra Bay]
Proud Member CBTMA
Radiant Red
  #33 (permalink)
Old 05-12-2008, 07:57 PM
Dealer : Parker Toyota Scion
2008 Toyota Tundra,
2008 Toyota Camry SE
Last Online: 07-08-2009 08:02 PM
toy4x4man is on a distinguished road.
toy4x4man's Photo Albums
If we really want to get technical on the "thinner air" debate. Warmer air is less dense resulting in less Aerodynamic Drag.
More importantly though, less dense air means that there are less air molecules per given volume being sucked into your engine. Since your MAF and your ECU are constantly trying to match the proper amount of fuel molecules to air molecules for proper combustion if the incoming air is less dense you will use less fuel. Consequently, you will also lose a percentage of power. That is why SAE has exact standards for measuring HP Ratings that include temperature of the air in the intake. You can actually get a good explanantion of this by reading about aircraft piston engines. Also, for those who live in areas like Denver where your air is less dense than someone like me who lives near sea level you will generally see higher MPG's but less power. I can attest to this personally as a good friend of mine that lives in Denver had the same model of Tacoma as I did and no matter how conservatively I drove he always averaged 2-3mpg better than me.
Just figured I'd chime in my knowledge of both aerodynamics and engines.
  #34 (permalink)
Old 05-13-2008, 01:07 AM
Dealer : Vancouver Toyota and Scion
Last Online: 11-25-2008 07:34 AM
DeathWind1 is on a distinguished road.
DeathWind1's Photo Albums
This You Mite Try-----------I went to the $ store and tried there octain booster---I have made 3 checks of 4 tanks then 4 tanks with out it and and every time I put it in I got A 1m Increase in gas millage !
  #35 (permalink)
Old 05-13-2008, 02:29 AM
trd12's Avatar
Dealer : Street Toyota
Last Online: 11-19-2009 01:29 PM
trd12 is on a distinguished road.
trd12's Photo Albums
woah woah woah...i think you got things mixed up...cold air is more dense (fog settles) and warm air is less dense (hot air rises) therefore someone closer to sea level such as the houston area your truck would get better mpg than someone in the denver area...when the air is cold your sensor knows and more fuel is put into your engine--so in denver wouldn't you be using more fuel??? jw
07' Tundra 5.7L White, TRD package, K&N drop in airfilter, pinstripe, line-x bedliner, black weathertech floorliners, 10" pioneer slimline subwoofer, pioneer navigation, black headlight mod, blacked out windows, that pretty much makes up my dream truck minus the rims and supercharger!
  #36 (permalink)
Old 05-13-2008, 08:02 AM
Dealer : Le Mieux & Son Toyota
2003 Toyota Camry,
2007 Toyota Tundra DBL Limited
Last Online: 09-16-2009 11:32 PM
cannondale27 is on a distinguished road.
cannondale27's Photo Albums
I have no idea if the Fitch gives you better mileage but I do know that if you put one in a tank of a snowmobile being stored over summer the gas will not go bad.So I would say it works to stabilize the fuel at minimum.
  #37 (permalink)
Old 05-13-2008, 08:56 AM
Dealer : Putnam Toyota
Last Online: 10-07-2009 09:28 PM
joshp is on a distinguished road.
joshp's Photo Albums
This device has been tested by the EPA, and there was no measurable increase/decrease in MPG.
Who knows if the EPA is honest?
The EPA is more criminal than this company, afterall, you can fail on not using approved parts even if what's coming out your exhaust is within the reasonable specs for your car.
  #38 (permalink)
Old 05-13-2008, 09:03 AM
Are you trying to say that "air temperature has no effect on MPG"???
Because that would be wrong. Wind resistance is the biggest loss at hiway speeds, more so than weight. Now city driving weight is the biggest factor, and not so much wind resistance. There is 2x the air mass per volume at -40 C than at +40 C.
And cold air is more dense and in turn requires your injectors to give more fuel to prevent too lean of a mixture.
  #39 (permalink)
Old 05-13-2008, 09:40 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
You guys are getting wayyy off topic. The thread is about the Fitch thing, not cold air intakes. Create a new thread, or just stop posting about it in this one. In two months, I don't want to see a poor soul searching for CAI's and bump this one on accident.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
  #40 (permalink)
Old 05-13-2008, 10:00 AM
2007 Toyota Tundra 5.7L TRD Black
Last Online: 11-19-2009 10:54 PM
blackgts2002 is on a distinguished road.
blackgts2002's Photo Albums
no pics still huh
  #41 (permalink)
Old 05-13-2008, 02:59 PM
2008 Toyota Tundra,
There are wo different aspects to think about when it comes to air density. Temperature and Ambient Pressure. Temperature you have the right idea about (Cold Air is Dense and Sinks, Hot Air is less dense and rises). I was trying to explain how someone at sea level will be bringing in more dense air because of their altitude/elevation compared to someone who lives in Denver at 5,000 plus feet in elevation. As you go up in altitude air density/pressure decreases meaning less molecules of Oxygen per given volume of air. Less oxygen means you need less gas other wise you would start burning too rich. Vice Versa if you go down in altitude your air density/pressure increases meaning you have more Oxygen molecules per given volume of air meaning that you need more fuel or you will go lean. Thus, places like Houston or where I live you will burn more gas generally, but also get more power. This is why piston-powered aircraft have mixture control knobs so you can avoid being too rich or too lean as you change altitiudes. Our trucks do this automatically by the MAF, computer and fuel injection system. Some older carbureted cars had mixture set screws that you could adjust if you took the car to higher altitudes.
About the Fitch Fuel Catalyst, I haven't looked at it yet but what is the idea behind how it works? It seems like quite a bit of work and $ for a savings that could be achieved by improving driving habits.
  #42 (permalink)
Old 05-13-2008, 03:21 PM
JBK23's Avatar
Dealer : Lowe Toyota of Warner Robins
2006 Toyota Tundra SR5 DC
Last Online: Yesterday 06:16 AM
Images: 10
JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor.
JBK23's Photo Albums
Originally Posted by JJB View Post
I saw an episode of Trucks! recently where they installed it on a cummins. They recited all the marketing stuff about what it should do, and said they'll update us on it's effectiveness on a future episode. Considering Fitch is a corporate sponsor of the show(s), I suppose it'll be favorable, or they just won't show the results at all.
While I'd like to see a product that really works, I'm not holding my breath.
Yeahy I seen that episode of truck's also I can't wait to see what the out come is.
2006 Tundra Double cab SR5 4x2 4.7L V8
  #43 (permalink)
Old 05-13-2008, 09:53 PM
Dealer : Karl Malone Toyota
Last Online: 10-06-2008 06:44 PM
Masterfrank1965 is on a distinguished road.
Masterfrank1965's Photo Albums
Sorry guys I have taken some pics of the install. But the pics are to big to post. Im finding out how to resize them. Sorry. soon very soon!
  #44 (permalink)
Old 05-13-2008, 10:16 PM
Images: 205
I have your answer!
http://www.tundrasolutions.com/forum...ctures-easily/
http://www.tundrasolutions.com/forum...photo-gallery/
  #45 (permalink)
Old 05-13-2008, 10:23 PM
Dealer : Desert Toyota of Las Vegas
Last Online: 08-21-2009 06:53 PM
gary_william is on a distinguished road.
gary_william's Photo Albums
so since we are debunking this technology, is anyone going to debunk the HHO devices?
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/133340-get-better-fuel-mileage-guaranteed/
Posted By For Type Date
Fitch Fuel Catalyst - Bio Fuels Forums This thread Refback 08-10-2008 07:00 PM
