Old 05-20-2008, 05:01 PM
jmen's Avatar
Dealer : Frank Smith Toyota
Last Online: 11-09-2009 10:59 PM
Images: 15
jmen is on a distinguished road.
jmen's Photo Albums
Default 305 65 18 tires?
OK i jus came back from discount where i was about to order some new wheels and tires
the wheels are the procomp 6047 18x9 and the offset on them is +12mm
and the tires i want to get with them are the BFG 305 65 18 and well on the first call to procomp they said the wheel and tire combo will work on my truck
then they called again and they said that they might rub and i will have to get a smaller tire, a 305 60 or even a 285...
Now what i really want to know is will the 305 65 tires rub with a wheel with that offset cause i really dont want a 285
any help would be greatly appreciated
thanks
2007 Tundra 4.7 TSS
3/1" Toytec Lift
18x9 6047 Procomp wraped with 305/65/18 BFG AT
6000K HIDs in Headlight, 3500k HIDs in fog lights, 6500k HID in Hella 500's behind grill
Eyelids, Under tailgate LED light bar
2 10" Rockford Fosgate Subs in custom box, Westin Bull bar, Spray on Bedliner
Old 05-20-2008, 09:38 PM
Banned
2008 Toyota Tundra SR5 CM TRD 4x4 5.7,
- Other - Toyota FJ60
Last Online: 07-18-2008 12:35 PM
Sequoia2003 may have some regrets.
Sequoia2003's Photo Albums
Default Re: 305 65 18 tires?
I am wondering the same thing. According to BF Goodrich's web site the 305/60/18 tire is 12.2 inches wide (9in Rim) and 32.6 inches tall so on a stock rim I would think it would fit.
Old 05-20-2008, 09:53 PM
Dealer : North Park Toyota of San Antonio
2007 Toyota Tundra Black Crewmax TRD
Last Online: 11-11-2009 07:59 PM
Images: 5
markramirez is on a distinguished road.
markramirez's Photo Albums
and the i want to get with them is the BFG 305 65 18 and well on the first call to procomp they said the wheel and tire combo will work on my truck
then they called again and they said that they might rub and i will have to get a small tire, a 305 60 or even a 285...
thanks
You may need to get a wheel with a higher offset. Mine are +30. I have a 3" lift in the front and I rubbed just a bit on the mud flap with the wheel cranked in reverse. I removed the mud flaps and no more rubbing. The 305's look good. I have them and am glad I didn't do 285's.
Icon coilovers up front.
Deaver 3 leaf minipack plus overload in rear.
BFG AT KO 305/65/R18
American Racing 18" Vice wheels
Debadged
Black headlight mod
Black Grill
Old 05-21-2008, 08:37 AM
NYPDBLUE's Avatar
Dealer : Maroone Toyota Scion
Last Online: 06-18-2009 10:04 PM
Images: 25
NYPDBLUE is on a distinguished road.
NYPDBLUE's Photo Albums
I have my 305/65/18 BFG ATs on the Stock 18" Wheels and had to only cut back the Skid Plate a little to prevent the front tires from rubbing when making wide turns. You would also need a front lift (2.5 inch) I have a readylift 2.5 installed on my front end.
305/65/18 with no front lift kit will rub and definitely will rub on the skid plate too.
LIFE IS A BEACH EVERYDAY !
2007 Tundra DC 5.7 4x4 SR5 (Black Ext./ Tan Int. Cloth), 2.5" Readylift w/ BFG 305/65/18 AT on Stock 18x8 Wheels, Husky Floor Liners front and Rear, Milemarker 9000lbs rear mounted winch setup w/ double ball w/ 1 7/8' & 2 " combo
Old 05-21-2008, 10:54 AM
jmen's Avatar
Images: 15
jmen's Photo Albums
Yea well i already got the Toytec 3/1 on it so im hoping its enough.
I already got them ordered so hopefully they work out with out rubbing on the inside of the fenders
2007 Tundra 4.7 TSS
3/1" Toytec Lift
Old 05-21-2008, 11:24 AM
fire_mike's Avatar
Dealer : Findlay Toyota Flagstaff
2010 Toyota Tundra Slate 4x4 Crewmax
Last Online: Today 12:05 AM
fire_mike is on a distinguished road.
fire_mike's Photo Albums
they sould fit just fine. You might have to trim the skid plate though.
Old 05-21-2008, 11:35 AM
jmen's Avatar
Images: 15
jmen's Photo Albums
Yea well thats not a problem i'll prbly trim it either way just to be on the safe side
Tires are too expecive to risk messing them up
2007 Tundra 4.7 TSS
3/1" Toytec Lift
Old 05-21-2008, 11:55 AM
Dealer : Empire Toyota
2007 Toyota Tundra 5.7 DCab 4x4 Red
Last Online: 05-17-2009 10:36 AM
Uncle Pinky is on a distinguished road.
Uncle Pinky's Photo Albums
I have 305/65/18 BFG's on my stock wheels with no lift and only had to trim the skid plate. No rubbing anywhere else
Old 05-21-2008, 12:25 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
You don't even have to trim the skid plate, a slight bend should suffice...
Before
After
And Complete with Truxxx 3" lift (are they ever really complete?)
Beer please!
Old 05-21-2008, 01:14 PM
jmen's Avatar
Images: 15
jmen's Photo Albums
well i know the tire will fit, its just that the guy from discount said that since the rim offset is a +12mm they might rub
2007 Tundra 4.7 TSS
3/1" Toytec Lift
Old 05-21-2008, 06:10 PM
Dealer : Karl Malone Toyota
Last Online: 10-06-2008 06:44 PM
Masterfrank1965 is on a distinguished road.
Masterfrank1965's Photo Albums
100% clear (leaves even more room than OEM)
will stick out 63 mm (2.5'') farther. Make sure that you have enough room under the fender. If not, consider narrower tires or higher offset.
Wheelwells Will fill out the wheelwell by extra 19 mm. Make sure that you have enough room under the fender. If not, consider lower profiles or smaller rims.
Old 05-21-2008, 07:31 PM
Sequoia2003
This message has been deleted by mxsjw. Reason: troll
Old 05-22-2008, 10:44 AM
jmen's Avatar
Images: 15
jmen's Photo Albums
yea well thats what im worried about the inner wheelwell.. but i guess we'll just have to wait and see they are already on the way and gonna have them test fit them on the truck.
2007 Tundra 4.7 TSS
3/1" Toytec Lift
Old 05-23-2008, 02:01 AM
winslow's Avatar
Dealer : Teton Toyota
Last Online: 07-26-2008 12:57 AM
winslow is on a distinguished road.
winslow's Photo Albums
I am running 305s on my 2008 limited. I have a 1" coil spacer on the front. Light wheeling and my everyday- I have not noticed any problems.
Old 05-23-2008, 07:50 AM
Dealer : Williams Toyota
Last Online: 03-17-2009 05:18 PM
jbar800 is on a distinguished road.
jbar800's Photo Albums
Winslow, Where did you get your 1" coil spacer? Is the picture of the white truck in the gallery with aftermarket wheels have the 305's and 1" spacer only? Thanks
Old 05-23-2008, 08:20 AM
Henry T's Avatar
Dealer : St. Charles Toyota
Last Online: Today 07:59 AM
Images: 25
Henry T will become famous soon enough. Henry T will become famous soon enough.
Henry T's Photo Albums
As was said many people have run these tires on the stock rims. If your new rims have the same specs you will be fine. Skid plate bending is all you will have to do. The area of main concern is where the tire can rub the UCA, different rims could cause this, im not sure.
2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
