LinkBack (3) Thread Tools Display Modes
  #31 (permalink)
Old 06-30-2008, 02:04 AM
WFO_Racer's Avatar
2007 Toyota Tundra CM,Silver w/TURD Pkg
Last Online: Today 02:17 AM
Images: 2
WFO_Racer is on a distinguished road.
WFO_Racer's Photo Albums
Default Re: DIY: Sirius Satellite Installation
I'm pretty close to doing this mod but have a question.
Since I do not have the Nav but the upgraded JBL, bluetooth, CD changer radio, does anybody know how this would show the display and the many stations on the SAT radio? So I select the SAT button on the JBL but how do I change the stations on the Sirius?
  #32 (permalink)
Old 06-30-2008, 02:19 AM
Dealer : Sharp Toyota
2001 Toyota Corolla,
2008 Toyota Tundra DC 4WD 5.7 TOW PKG
Last Online: 09-21-2009 05:18 PM
porkenstein is on a distinguished road.
porkenstein's Photo Albums
Thanks for the great how to. I wanted sirius but didn't think I could handle the install. Ordered components off of ebay after watching your video. Will let you know how it goes.
  #33 (permalink)
Old 06-30-2008, 12:45 PM
chixdigit's Avatar
Dealer : Universal Toyota
2008 Toyota Tundra Slvr 5.7 SR5 DC 4x4
Last Online: 10-12-2009 07:58 PM
Images: 19
chixdigit will become famous soon enough.
chixdigit's Photo Albums
I installed mine this weekend, and it was a piece of cake- thanks to wleeb's video's on how to take everything apart.
Here is my input:
The center speaker grille is actually solid plastic- with a hole cut out where the speaker is. Due to this, I did not want to mount the antenna under that solid plastic, but I DO like the location on the dash.. It seems to have a decent field of view of the sky, and it is inside- keeping my antenna from the elements (versus mounted on the cowl) and also, my truck goes through a car wash with the big fabric rolling brushes, so mounting it on my roof would have gotten it knocked off every time I ran it through the wash..
So... What I did was just cut 2 more 1 inch strips from the plumber's tape that I used to mount the recievers under the cup holders (from wleeb's videos), and super glue those strips side by side to the underside of the solid section of the speaker grille- to the right of the speaker. From there, I just ran the antenna up from the front of the speaker grille right before I popped it back into place and then just stuck the magnetic antenna on top of the grille and it sticks to the metal on the underside of the grille. That way, my antenna is bove the speaker grille. The wire is tucked in at the front of the grille so it looks very clean, and the antenna has a great view of the sky. It does not obstruct my view of the clock or "info" at all either. I've had mine installed since Saturday afternoon, and the signal has not cut out at all with it mounted there unless I drive under bridges sometimes, etc.
Another tip: have that long antenna wire untangled (completely unraveled) before you go to route it. Mine was ALL knotted up, and it would have been a lot easier to untangle it if I had done that before I had half of it tucked up into the dash, etc...
Another tip: I did not actually bolt the metal plumber's tape into place like wleed did. Those bolts were a booger to get to, so I just wrapped the ends of the tape around existing "stuff" and that will stay in place just fine. I used about 20 iches of the tape instead of the 16.5 inches wleeb mentioned, which gave me more tape to tuck under the carpet in the front section, and then wrap around a plastic cross- piece under the cup holder for the back section.
VERY simple install guys... Don't be afraid to do it! SIRIUS ROCKS!!! I LOVE IT!!
To anwer your question WFO... Once it is instaled and powered up, you will actually have a SAT1, SAT2, and SAT3. (3 different bands, just like FM). I set 6 presets for Rock on SAT1, 6 presets for Country and R&B on SAT2, and 6 presets for my fiancee's dance/ electronica and other random stations on SAT3.
I do NOT have the "memo" and FF or RW features that I had on my old Sirius Starmate that I had in my old truck, but this integrated system is soooo clean and streamlined that I don't mind. The only thing you can see after the install is the tiny antenna on the speaker grille.
BTW, all info is displayed on my regular JBL system. You can push Text to switch beweeen displaying station name/ band name/ song name.. VERY COOL.
  • Silver 2008 5.7 4x4 SR5 Double Cab with Gray Leather and JBL picked up on 5/31/08
  • I installed the Truxxx 3/1 leveling kit the day after I got it. PAIN IN THE A!! Get a shop to do it!!
  • Excalibur AL-2000 2-way pager alarm with remote start and dark as legally possible tint installed the very next day
  • 305/55/20 Toyo A/T tires and black with machined lip ATX Vice wheels installed the day after that!
  • Aries 4" Deluxe Oval tube steps.
  • Sirius Satelite Radio installed using wleeb's awesome DIY.
  #34 (permalink)
Old 06-30-2008, 04:47 PM
Frag Master's Avatar
Dealer : Thurston Toyota
Last Online: 08-03-2009 02:04 AM
Images: 12
Frag Master is on a distinguished road.
Frag Master's Photo Albums
Quote: "From there, I just ran the antenna up from the front of the speaker grille right before I popped it back into place and then just stuck the magnetic antenna on top of the grille and it sticks to the metal on the underside of the grille."
Sounds like a good way to mount the antenna, I know Wleeb sounded like he was loosing the signal from an under the speaker grill mount.
do you have some pics for us?
2008 Tundra CM Limited 4x4 5.7
  • ProComp 6" Stage 1 Lift
  • 35" Toyo Open Country M/T's
  • 20" Pro Comp 6088 Wheels
  • Amp Power Steps
  • G2 Bakflip Tonneau
  • Borla Catback Exhaust
  • Bedrug Liner
  • Deaver Mini Pack Springs
  • Color Matched Grill Surround
  • Carriage Works Billet Grills
  #35 (permalink)
Old 06-30-2008, 04:58 PM
chixdigit's Avatar
Images: 19
Not yet, but I will take one....
It is the only thing you can see from the "Sirius stuff" at all... VERY clean install.
  #36 (permalink)
Old 06-30-2008, 08:34 PM
WFO_Racer's Avatar
Images: 2
Thanks for the reply chixdigit.
  #37 (permalink)
Old 06-30-2008, 10:39 PM
zzzpro's Avatar
Dealer : Frontier Toyota
2007 Toyota Tundra 4X4 crewmax
Last Online: 10-23-2009 10:45 PM
Images: 13
zzzpro is on a distinguished road.
zzzpro's Photo Albums
Question all. Does your display only show the first 10 letters of Names and songs? Sure wish the display would scroll the whole title or band name etc. Electric light Orchestra becomes " ELECTRIC L"
2007 4X4 SR5 ,Crewmax, Slate Metallic , 5.7
TRD Exhaust and CAI
TRD sway bar
Camburg Coilovers and UCA's
Rancho 9000xls
18" Ultra Goliaths
275/70/18 Goodyear wrangler silent armour
Carriageworks grill
Color matched front cowl/grill
Hunt hard, Kill Clean, Apologize to no one!
  #38 (permalink)
Old 06-30-2008, 11:09 PM
chixdigit's Avatar
Images: 19
Here's the pics!
From my seat: (You have to look closlely at the center speaker grille to even see the only HW visible from this install)
DIY: Sirius Satellite Installation-from-my-seat.jpg
From my seat-zoomed:
DIY: Sirius Satellite Installation-from-my-seat-zoomed.jpg
Closeup:
DIY: Sirius Satellite Installation-closeup.jpg
Birdseye- through the windshield:
DIY: Sirius Satellite Installation-birdseye-view.jpg
  #39 (permalink)
Old 07-01-2008, 10:55 AM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Today 02:53 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
I did it! Very happy. I put the antenna were wleeb put his and it only cut out once or twice when I was in some heavy foliage. The whole installation took about an hour, and it would have been much quicker if my hands were smaller: it was a bugger to route the wires from the back of the head unit down to the underside of the center console. I do like having everything hidden, unlike my old unit with wires going every which way and the antenna falling off the dash onto the floor if I took a corner too fast
Before watching the videos I was worried about how to take the dash apart, but it really is a piece of cake. Just like Lego! LOL (my son's a big Lego fan).
Thanks for the tutorial wleeb
[Tundra Bay]
Proud Member CBTMA
Radiant Red
  #40 (permalink)
Old 07-01-2008, 11:37 AM
Images: 12
Originally Posted by chixdigit View Post
Here's the pics!
Attachment 33285
Attachment 33286
Closeup:
Attachment 33287
Attachment 33288
Thanks chixdigit, nice group of photos, keep us informed as to your reception as time goes by.
  • Amp Power Steps
  • Bedrug Liner
  #41 (permalink)
Old 07-01-2008, 03:11 PM
TundraBay's Avatar
2007 Toyota Tundra,
I'm just posting this here for anyone else like me who hates having to turn up your stereo to 50 to hear any sound when on SAT and then gets their ears blasted out when switching back to radio or CD. Now the volume seems the same from SAT as radio. Thanks FSS.
Originally Posted by FSS View Post
I installed the Sirius SCC1 and TOY-SC1 a few days ago. These are what are needed to hook up the Sirius setup to the all 2007+ Tundra OEM HU's (aftermarket anyhow). I was really disappointed with the volume. Very low compared to all other outputs.
For all you others that have noticed the same problem, I came across an easy fix in another forum: turn on your HU to SAT input. Then press presets in succession 1 6 2 5 3 4.
I now have the same output level as the other inputs.
[Tundra Bay]
Proud Member CBTMA
Radiant Red
  #42 (permalink)
Old 07-31-2008, 09:06 PM
5keepers's Avatar
Dealer : Leith Toyota
2008 Toyota Tundra White DC 5.7,
- Other - 85 SR5 Truggy on 39s
Last Online: Yesterday 04:34 PM
Images: 22
5keepers is on a distinguished road.
5keepers's Photo Albums
OK, need a little help here. I did this install today. Very simple and great write up. When I punch the AM/SAT button.... only AM. No satelite at all. I have the non JBL head unit. Am I missing something? I connected the 2 ebay units, ran the antenna, plugged the "T" wire into the blank spot on the back of the radio. Does the other end of the t wire that came with my directed unit go somewhere?
08 DCB 5.7-Dual Powersticks-K&N FIPK-Boost Brothers Headers-Moto Metal 951's (black)-Dominator II Steps-Tint-BakFlip-EGR In Channels-Sirius-Black HL Mod-Invisible Bra
WWW.SHUTUPANDWHEEL.COM
  #43 (permalink)
Old 07-31-2008, 10:54 PM
If you are talking about the double plug that goes to the factory radio you only use the plug that plugs in to your radio. The other plug not used. I had problems with the plug that goes to the back of the radio popping out. Maybe it came unplugged???
  #44 (permalink)
Old 07-31-2008, 11:05 PM
boathik's Avatar
Dealer : McGee Toyota
Last Online: 10-26-2009 04:54 AM
Images: 19
boathik is on a distinguished road.
boathik's Photo Albums
I had this problem most of the time (occasionally it would decide to scroll) until I disconnected the battery when doing the HC removal mod. Now it scrolls all the time!
BTW, I have th JBL radio so the switches on the TOY-SC1 is set at 10 characters and scrolling is on.
  #45 (permalink)
Old 07-31-2008, 11:13 PM
boathik's Avatar
Images: 19
You change stations with the factory radio controls or on the steering wheel. I put in a Dock and Play so I could us it in the house and mounted it in the upper glove box. There is no need to get to it at all to operate. The display shows the 'Sirius Connect' logo with dim back-light when on.
DIY: Sirius Satellite Installation-upper-glove-box.jpg   DIY: Sirius Satellite Installation-upper-glove-box-2.jpg   DIY: Sirius Satellite Installation-sirius-installed.jpg
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/135336-diy-sirius-satellite-installation/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-15-2009 07:30 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Toyota Tundra Forum This thread Refback 06-30-2009 11:52 AM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 06-07-2009 12:12 PM
