Closed Thread
Old 06-12-2008, 02:47 AM
Dealer : Mountain States Toyota
Last Online: 06-28-2009 12:29 PM
nlxskunk may have some regrets.
Send a message via AIM to nlxskunk nlxskunk's Photo Albums
Default Do-It-YourSelf Mod gauge cluster
So this is an entry into the Do-It-Yourself contest...
So I just got this 2008 Green Tundra on 5-31, has 50miles on it, the big 5L and as you all say hauls ***. Well one thing that has always crabbed my *** was the way they put the tunnels in the guages. Pretty dumb if you ask me since, I would prefer a solid open view at all my gauges rather then whizin down a hole. So I set out to cut th **** out and make that thing open. Here is the deal...
These 2008 Tundras at least are almost snap and go trucks. Everything inside this thing is snapped in one way by one style of clip, and all you have to do to get it out it TUG! There are a few bolts along the way, but they have at least made then all use a 10mm socket or an allen head screwdriver.
So first comes the front gray dash that covers the gear cluster and whatnot. Just grap a hold of a few areas top and bottom, and cross your arms when you do it, the pul towards you, its really simple and you'll see once it comes out.
http://img.photobucket.com/albums/v6...a/IMG_6225.jpg
http://img.photobucket.com/albums/v6...a/IMG_6226.jpg
you'll see that the two blowers come out when you take the silver dash piece out, and you will also have to be careful with all the cables, they didn't allow much slack in my cables so be sure to ease on them. Using a flat head screwdriver works good for popping out all the elec. connections.
Then once you have the silver dash out, pop out all the other small pieces, and then take apart the silver and black tunnels.
http://img.photobucket.com/albums/v6...a/IMG_6222.jpg
http://img.photobucket.com/albums/v6...a/IMG_6220.jpg you can see in this last picture that there are little white pieces of plastic holding everything together, just use a pair of need nose pilers and grap and twist and it will come right off, then follows the dis-assembly of the black tunnels and the silver rings.
After you get all that crap outta there, you have the blank silver cover. At this point you will see the oval that will come out of the cover, by using masking tape that was 1" wide, I lawyered the front of the cover to protect it from scratches and to draw my cutout on.
http://img.photobucket.com/albums/v6...IMG_6235_1.jpg
http://img.photobucket.com/albums/v6...a/IMG_6236.jpg
In this last picture you can see where I started with the design, using stencils and a ruler, it took a few times and a few retapings, but I eventually got my shap with patentience and french stencils to help make the curves...
http://img.photobucket.com/albums/v6...a/IMG_6237.jpg
http://img.photobucket.com/albums/v6...a/IMG_6243.jpg
http://img.photobucket.com/albums/v6...a/IMG_6240.jpg
Once I finally got the right shape I held my piece down on one end and then used a drimmel to cut out my shape following the red line.
[url]http://img.photobucket.com/albums/v632/bikermod/Tundra/IMG_6241.jpg
[url]http://img.photobucket.com/albums/v632/bikermod/Tundra/IMG_6242.jpg
So after you get the whole inside cut out you need to sand or smooth the edges somehow. I used a metal file and put a nice bevel on the front edge to hide the small imperfections you may see at an angle when in the truck.
http://img.photobucket.com/albums/v6...a/IMG_6244.jpg
There is a clear plastic cover covering the gauges. I said fug it and got rid of that to, I know it should prob. be there for safety sake,. but it looks way better with it off. Now you can see all the gauges with minor interference from the design
http://img.photobucket.com/albums/v6...a/IMG_6246.jpg
http://img.photobucket.com/albums/v6...a/IMG_6249.jpg
http://img.photobucket.com/albums/v6...a/_MG_6259.jpg
once, you have it all back snapped in place, you will have to deal with the main wires that run over the top of the original placement., just zip tie or use double backed tape to hold these down out of sight, and there you have it. A nice clear view of all your stock cluster and a small no price mod. The only thing I may do now is paint it black....ahhh yeah...enjoy
eNIg
http://img.photobucket.com/albums/v6...a/IMG_6254.jpg
Old 06-12-2008, 07:23 AM
671Tundra's Avatar
Dealer : Findlay Toyota Scion
2008 Toyota Tundra,
2000 Toyota 4Runner V6 2wd SR5 *Traded
Last Online: Today 10:22 AM
Images: 23
671Tundra is on a distinguished road.
671Tundra's Photo Albums
Default Re: Do-It-YourSelf Mod gauge cluster
I'd rather much deal with the "tunnels" than the "gaps". *ouch!!! JMHO...
2008 Toyota Tundra DC SR5 5.7 4x4: Airaid CAD, Gibson Dual Turndown Exhaust, Billet Grill and Bumper Inserts, 6" Icon Coilovers Upgrade from PC Stage 1, Eagle Alloy Wheels, Pro Comp Xtreme A/T 35x12.5x18, Factory Fog Light Addition, Black Headlight Mod, Custom Skid Plate.
Old 06-12-2008, 07:49 AM
Tundradrenalin
This message has been deleted by Tundradrenalin.
Old 06-12-2008, 08:54 AM
millsp's Avatar
Dealer : Lipton Toyota Scion
2007 Toyota Tundra Crew Max Silver TRD
Images: 39
millsp will become famous soon enough. millsp will become famous soon enough.
millsp's Photo Albums My eBay
I edited it again so people can easily click on the links to see how badly you butchered your dash!
The least you could have done is cut the Hole evenly on both sides.....
TundraSolutions.com Forum Rules
Classified Forum Rules
What is Rep Power? read more HERE!
Florida Panthers Season Ticket Holder! Sweet!
Old 06-12-2008, 09:03 AM
Bocephus's Avatar
Last Online: Yesterday 02:12 AM
Bocephus is on a distinguished road.
Bocephus's Photo Albums
just a little tip for using photobucket....... you can actually set your upload size so that every picture over 800x600 is automatically reduced to that size. very convenient for most situations, but you do need to turn the feature off when you want to UL larger pics
2008 DC 4x4 TRD 5.7L
* 2.4 Ready-Lift, 305/55/20 Mickey Thompson Baja ATZ's on 20'' Ultra Goliath's and 285/65/18 BFG AT's on stock TRD rims, grille surround, door handles, and tailgate handle painted to match body, black headlight mod, OEM fender flares, Lorado tonneau cover, N-Fab nerf bars, 6000K HID lows and highs, 3000K ebay special fogs, Tekonsha P3 brake controller, Firestone airbags, LED tail lights, LED 3rd brake light, Pioneer AVH-P4100DVD head unit, Kicker KX600.1, Rockford 450.4, Kicker Resolution 6.5'' components front and rear, Kicker 12'' L7
Old 06-12-2008, 09:07 AM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 02:00 AM
Images: 204
Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything. Tundradrenalin has done just about everything.
Also, please note that 800x600 is the MAX size. This does not mean that you can't insert smaller pictures.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full VLED's Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Sound Deadener
Cosmetic: Line-X Bedliner & Mirror covers, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve,
Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 06-12-2008, 09:08 AM
JBK23's Avatar
Dealer : Lowe Toyota of Warner Robins
2006 Toyota Tundra SR5 DC
Last Online: 11-06-2009 10:02 PM
Images: 10
JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor.
JBK23's Photo Albums
I could not bring my self to cut up a brand new truck dash no way. The tunnels aren't bad enough to go an cut them up and have wires and stuff hanging out I could not drive around like that. Every one that see that is going to say what the hell. You just made it worse looks like an old car falling apart. Hope you did not void anything.
2006 Tundra Double cab SR5 4x2 4.7L V8
Old 06-12-2008, 09:12 AM
Dealer : Avondale Toyota Scion
Last Online: Yesterday 10:27 PM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
Not for me! How are you going to keep dirt, bugs and french fries from falling in the cluster?
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 06-12-2008, 09:26 AM
Bocephus
Old 06-12-2008, 10:41 AM
Dealer : St. Charles Toyota
2008 Toyota Tundra SR5 4x4 Salsa Red
Last Online: Today 08:40 AM
mrfoster is on a distinguished road.
mrfoster's Photo Albums
I got excited about this when I read the title and then saw the intent. I don't like the partioned gauges.
But then I think that it ended up like someone took a dremel to the plastic without much of a plan. Oops. That is what happened.
No way. No good.
Old 06-12-2008, 10:56 AM
MMichaelJJ
Mtrosclair
Old 06-12-2008, 11:00 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
If it was me, here's what I'd be doing...
Google = Search Wrecking Yards for a 2007 Tundra Dash
To each their own, but not a mod I'll be doing anytime in this life.
Beer please!
Old 06-12-2008, 11:06 AM
Dealer : Tom Scott Toyota
2007 Toyota Tundra,
2007 Toyota Camry white xle v6,
- Other - 77 celica gt one own
Last Online: Today 06:20 PM
mgsw530 is on a distinguished road.
mgsw530's Photo Albums
Too bad dude. Not to mention the fact that it looks like you scratched the shi* out of your black dash. Not for me butn if you like it---
Old 06-12-2008, 11:08 AM
bbolton's Avatar
Dealer : Jim Hudson Toyota Scion
Last Online: 09-08-2009 04:30 PM
bbolton is on a distinguished road.
bbolton's Photo Albums My eBay
ya'll are vicious! You've got balls man, I'll give you that.
2007 Tundra DC - TRD
Old 06-12-2008, 11:09 AM
Canadian_Yoda
Last Online: 11-04-2009 11:13 AM
jacksprat is on a distinguished road.
jacksprat's Photo Albums
This guy has got to be kidding. I bet he got a XSP carbon fiber dash and he just hacked up the silver one just for fun. Watch in a few days he will post pics of his new carbon fiber dash haha.
Old 06-12-2008, 12:06 PM
DrBundy's Avatar
Wanker
Dealer : Lakeside Toyota
2007 Toyota Tundra,
2008 Toyota Highlander
Last Online: Today 12:34 PM
Images: 21
DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything. DrBundy has done just about everything.
DrBundy's Photo Albums
Will smaller pictures make his work look better?
Personally, I like the deep-set gauges. My wife can no longer see how fast we're going.
Cheers!
~A
PS-Good luck in the contest!
"There's nary an animal alive that can outrun a greased Scotsman!"
~Groundskeeper Willie
CBTMA - Member
07 CrewMax Limited 5.7L - Radiant Red - hardwired Valentine 1, TRD Sway Bar (debating a drop kit)
08 Highlander Sport - Black - mods include whatever the wife will let me do to her brand new baby, which at this point is exactly nothing.
Old 06-12-2008, 12:35 PM
Damn you guys must think you are the shiz when it comes to Mods., don't any of you tight wads know the meaning of the word Mod. Who cares if it did not come out PERFECT like from the factory. If some of you actually looked at the pics, instead of being such pussy *** whiners about their size, give me a break, then you'll notice I did take my time and made a template, and took my time so as to not fug it up, but obliviously all of you so called Tundra owners can go shove it up your ***. Let me see any of you come out with a real mod you do yourself. Nothing is ever going to be perfect, and if you don't like it, so be it, it was simple a small contest for personal DIY mods, don't like it...BOUNCE!!! Go drive your stock piece of plastic and let it look like every other one thats on the road....at least I've got the balls to take some action, while all you haters got nothing to show but stupid bolt ons everyone and their mother has.....
What a great forum, I buy a new truck, try a simple mod, (who cares about replacing that cover anyway), and all I do is get bashed by a bunch of haters who do nothing but surf the internet for crap that bolts on, and then you get on here and say ohohoh looky look I made a mod, I'm cool....get a life and live outside of the box instead of being like everyone else out there....you guys are lame, go rub your shifter I'm sure it will make you feel better for putting 20" tires and rims and thinking your badass, your not!.....
go poop on yourself...
Old 06-12-2008, 12:41 PM
Dealer : Parker Toyota Scion
2008 Toyota Tundra,
2008 Toyota Camry SE
Last Online: 07-08-2009 08:02 PM
toy4x4man is on a distinguished road.
toy4x4man's Photo Albums
All I can Say is WOW!
Closed Thread
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/135511-do-it-yourself-mod-gauge-cluster/
Posted By For Type Date
newest epic internet thread - Page 2 - XR-Underground This thread Refback 05-21-2009 12:55 AM
