LinkBack (11) Thread Tools Display Modes
  11 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 06-22-2008, 03:11 PM
Dealer : Champion Toyota Scion Gulf Freeway
1996 Toyota Tacoma,
2007 Toyota Tundra RCSB 4x4 5.7
Last Online: Yesterday 05:15 PM
swank501 will become famous soon enough.
swank501's Photo Albums
Default DIY Wheel Painting
Painting can be a bit intimidating. After all, who wants to mess up an expensive set of wheels, right? One thing to understand is that a great paint job is the result of great preparation. Anybody that knows anything about painting will tell you the same thing. . Hopefully by the time you read this, you will have the confidence and knowledge to tackle the job with ease. That being said, here is an easy dramatic modification you can make for under $50.
before:
Materials
(2) Cans Dupli-Color WP10() High Performance wheel coating (WP103 in my case)
(2) Cans Dupli-Color HWP103 High performance wheel clearcoat
(1) Can Dupli-Color CM-541 Wax and grease remover
(1) Roll 3M ¾” green high performance tape PN-03431
(1) Roll 3M 2” Scotch masking tape 2015
(1) Roll Scott shop towels
(1) 3-Pak maroon 3M Scotch Brite pads 37447
(1) Sleeve 600 grit 3M wet or dry sand paper 03020NA
(1) Tack cloth (optional but highly advised!)
This is not a mandatory list, but everything above guarantees the job will be done correctly. Taking away will only take away from the finished product. Notice there is no primer. That is because it is NOT necessary. Primer serves three main purposes:
1.) To create a bond between substrate material and subsequent topcoats.
2.) To inhibit corrosion.
3.) To fill in repair areas prior to top coating.
Since I’m starting with a relatively new set of wheels, there is already a primer in there doing its job. If the wheels had damage or rust I would have to repair accordingly and then use a primer. A few safety items that should never be ignored are
1.) Safety glasses or goggles
2.) Organic vapor respirator
3.) Nitrile gloves (I prefer them over latex because they are much stronger and more resilient to chemical exposure)
The total cost for materials minus the personal safety gear came to $48.77. I will admit that I went a little OCD on the masking supplies, but it’s all in the prep work baby!
Procedure
1.) Start on level ground and set the parking brake. Loosen, but don’t remove all lug nuts. Lift the front of the vehicle and place on jack stands. Remove the front wheels. Repeat the process for the rear
2.) Once all the wheels have been removed it is time for some serious cleaning. Soap and water should do the trick, but a degreaser like Simple Green may be better suited. Since I want a seamless look on my wheels, I will be doing the inside and outside. The wheels had better be spotless if you want the paint to stick. An old painter’s trick is to use some Comet in combination with a red scotch brite and water to clean and prep the surface simultaneously.
3.) Now you should be ready to sand. A five gallon bucket would come in handy but isn’t necessary. Fill the bucket with warm water and about a quarter-squirt of dish soap. Put a couple of the wet or dry sandpaper sheets in there and give them a couple minutes to “soften” up. Dip a rag in the water and use this to irrigate the area you will be sanding. Fold the sandpaper over and get to sanding. Use smooth overlapping motions and be sure to check your work every once in awhile. You can do so by drying the area to check for remaining shiny spots. Sand the entire wheel (Or face only if this is all you care to paint).
4.) Once you have sanded all four wheels, allow them to dry and then do a final once over with the red scotch brite. This will catch any spots that you may have missed.
5.) Now comes the masking. There is no 100% right way to do this, but there are several wrong ways. They keys to a good mask job are neatness and completeness. A sloppy mask job with several folds and wrinkles will only provide a place for dust and trash to settle that will later end up in your paint job. Don’t get lazy here; it is an important step just like the rest. Overspray will always find its way into places you don’t want it, so if you are unsure about anything, mask it off!
6.) Get the wax and grease remover and Scott towels. Apply the remover with one rag and remove it immediately with a dry, clean one. Again this is a crucial step. Once you are done blow off the wheels with compressed air (if available) and wipe again with either a lint free towel or a tack rag.
7.) Now it’s time to paint! I will go ahead and restate the importance of a tack rag. When using a metallic base color, a tack rag will be your best friend. The high metallic contents of today’s paints can be somewhat tricky to deal with. The metallics need to flow in the paint in order to lay down properly and not cluster or mottle. Do to varying spray conditions the metallics will often want to stand up or not flow into the paint. After spraying the first coat of paint, you may notice a slightly dusty finish once it has dried. This is the metallics and overspray that has not settled or conformed with the paint. Once the paint is dry to the touch, run your tack rag over the surface to remove the particles. This will leave a smooth layer for which to apply subsequent layers of paint. Please note that it isn’t intended to be used on the clear coat!
8.) As far as painting is concerned, follow the directions on the can! Their guidelines for coverage, flash times and handling times are usually a good reliable source. Although it isn’t necessary, I used a clear coat for added protection. I would advise waiting as long as possible before clear coating. This is to ensure that the base color has had plenty of time to flash off and not cause solvent popping in the clear coat (it will look like tiny bubbles trapped in the clear).
(this is a poser shot with the masking partially removed)
9.) After allowing proper time for drying, unmask and reinstall the wheels on the truck.
Conclusion
I would love a set of custom wheels, but unfortunately I just can’t afford them right now. Maybe after I get my engineering degree I will have all the cash in the world to do all the fun stuff I want to do to the truck. I must admit I’m really pleased with the outcome of this mod and feel that it looks better than many of the aftermarket wheels currently available. I’m sure many of you prefer the look of black wheels on a black truck, but I feel a little contrast gives the truck more appeal. Furthermore the chrome emblems and lug nuts add to this contrast and appeal. This is only my opinion.
This mod took approximately 6 hours from start to finish not including allowing them to dry overnight. The one thing that would stress more than anything is to have patience when doing this. It is really easy to get burned out on the hours of sanding and try to take shortcuts. If you can tough it out, the end result is well worth it.
2 tone Katzkins Leather
Custom made bolt on Rock Sliders
Line-x xtra
Old Man Emu 2.5" lift front and rear
Old 06-22-2008, 03:14 PM
HotWheelsUMD's Avatar
Dealer : Fitzgerald's Lakeforest Toyota
2007 Toyota Tundra,
- Other - 93 Toyota Celica GT
Last Online: Today 05:56 PM
Images: 5
HotWheelsUMD will become famous soon enough.
HotWheelsUMD's Photo Albums
Default Re: DIY Wheel Painting
Wow. Love the look of the grey against the black. Well done.
2007 TUNDRA 5.7L SR5 TRD 4x2 Double Cab, Salsa Red Pearl
TRD CAI, Corsa Sport Side Exit Dual Tip Exhaust, Stebel 300Hz Air Horn, OEM Tundra Mud Mats, Black powder-coated side-step bars, Ventshades, Line-X, TRD Sway Bar, Blacked headlights surround, White LED guage and dash lights, Viper 771VXR Remote Start / Alarm, Carriage Works black billet grille with logo remount (awaiting install).
Old 06-22-2008, 03:18 PM
millsp's Avatar
Dealer : Lipton Toyota Scion
2007 Toyota Tundra Crew Max Silver TRD
Images: 39
millsp will become famous soon enough. millsp will become famous soon enough.
millsp's Photo Albums My eBay
Very nice. It's too bad you missed our DIY contest. I remember before you started school you made your rock sliders from scratch. Nice work!
TundraSolutions.com Forum Rules
Classified Forum Rules
What is Rep Power? read more HERE!
Florida Panthers Season Ticket Holder! Sweet!
Old 06-22-2008, 03:25 PM
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Today 04:51 PM
Images: 61
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
awesome write up and pics. excellent end result. hope it holds up well for you. im considering doing this on my project car im fixin up for my brother in law- discount tire has great prices right now on silver custom rims but gunmetal is what we want....so i may just do this haha. let us knwo how it holds up over time. but once again excellent so far.
Old 06-22-2008, 03:42 PM
semcoll's Avatar
Dealer : Panama City Toyota Scion
Last Online: Yesterday 01:06 PM
Images: 15
semcoll will become famous soon enough. semcoll will become famous soon enough.
semcoll's Photo Albums
Great job and great instructions!
5.7L 2WD DC Salsa Red Pearl SOS/TR 2"/4" drop, 20 x 9 Incubus Shylock alloys, 295/45/20 Falken TZ01 tires , TRD anti-sway bar, Hella Optilux driving lights, Flowmaster 50 dual in/out w/baffled Hooker tips, LineX, DeeZee black diamond toolbox,filled color-matched grille shell w/CarriageWorks insert, Blacked-out headlights, 50 watt back-up lights in bumper, Rockford Fosgate T400-4 amp,Polk Audio speaker upgrade, single 10" MTX sub,Beltronics 955 radar unit.
Old 06-22-2008, 03:57 PM
Dealer : Poway Toyota
Last Online: Yesterday 05:11 PM
matrix77 is a splendid one to behold. matrix77 is a splendid one to behold.
matrix77's Photo Albums
Wow... very cool.... I know what I should do with my 1999 4Runner.... The gas station carwash messed up all the rims' covers!
Thanks for detailed info.
Old 06-22-2008, 05:38 PM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Today 05:40 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
Damn, that looks good!
SAS Tundra
Build Thread-
SAS on 02 Tundra
Old 06-22-2008, 06:26 PM
pcardinal42's Avatar
Dealer : Lithia Toyota Of Abilene
Last Online: Yesterday 09:59 AM
Images: 21
pcardinal42 is on a distinguished road.
Send a message via AIM to pcardinal42 pcardinal42's Photo Albums
WOW! I'm in the same boat with the no money thing and I was just going to have a paint shop powder coat mine. I think I'll try this mod very soon.
2007 DC SR5 4x4 4.7
De Badged
All Weather Floor Mats
Painted Wheels
1 3" core 26" power stick mufflers
N-fab pre-runner light bar
Satin Black Head Light Mod
Old 06-22-2008, 06:30 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 04:03 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
I think that is much better than black would be. Nice job well done.
Charlie & Linda
Old 06-22-2008, 09:21 PM
Dealer : Desert Toyota of Las Vegas
Last Online: 08-21-2009 06:53 PM
gary_william is on a distinguished road.
gary_william's Photo Albums
man, red brake calipers would really POP on that truck, now that it has dark rims.
Last edited by gary_william; 06-22-2008 at 09:21 PM. Reason: changed color reference from black to dark
Old 06-22-2008, 09:41 PM
Dealer : Universal Toyota
Last Online: 04-08-2009 07:01 PM
djb383 is on a distinguished road.
djb383's Photo Albums
Nice job. Here's just the opposite - black steelies on a silver truck. Definitely do the calipers.
'07 RCSB 5.7L SR5 Silver Sky Metallic (The Silver Bullet) Yep....it's gotta HEMI
Never argue with an idiot. They will bring you down to their level and beat you with experience!
Old 06-22-2008, 09:45 PM
1996 Toyota Tacoma,
Thanks for the kind words guys!
I thought of the red calipers, but I just don't have the extra $$$ for the paint right now. I can always do it later down the road though.
Line-x xtra
Old 06-22-2008, 10:18 PM
300 ULTRA's Avatar
Happy Member
Dealer : Stone's Town & Country Toyota
2007 Toyota Tundra DC 4x4 LTD TRD,
2008 Toyota Rav4 Black LTD
Last Online: 10-12-2009 10:24 PM
300 ULTRA may have some regrets.
300 ULTRA's Photo Albums
I'd have to kill if I came out and saw my Tundra on jack stands. Nice job and good to see people that DIY. Well done.
Old 06-22-2008, 10:23 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Swank, great little write-up
DIY (Do-It-Yourself) & User Knowledgebase Sticky thread has been updated.
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 06-22-2008, 10:28 PM
OntheRox's Avatar
Proprio una storia vera
2007 Toyota Tundra,
- Other - 2003 Subaru Leg GT
Images: 65
OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One. OntheRox is the One.
Send a message via AIM to OntheRox OntheRox's Photo Albums
Very nice tutorial I like that color with the black truck.
2007 Tundra DC 4.7 SR5 TRD 4X4
Garmin Nuvi 1300T
Stubby antenna
Clear Bra,
ARB Bumper,
Line-X,
325/60/18 Nitto Terra Grapplers,
18" KMC XD Hoss Black,
ARE CX Series Topper,
KC Rally 800 long range lights,
Tinted windows,
Wet Okoles Frt & Rear,
Weather Tech rain deflectors,
Weather Tech floor liners frt/rear,
Ready Lift 2.4"
Bel Vector 995 Radar Detector,
Wilson cellular booster,
Cobra 75 WX ST Compact/Remote CB,
Sirius Satellite Radio,
S&W .38 Spl Laser grip (hot pink),
TRD sway bar (black widow style),
Debadged except TRD sticker,
Roxy Sticker
TS Tank Top
____________________________
Wish list:
Horn Blaster train horn, ARB rear bumper (if they ever make one) or line-x rear bumper, Color matched fender flares, Underseat storage of some sort, Winch (if i can ever afford one), GPS system! Sun roof! Going broke thinking about it.
__________________________________________
I need a new word of the month people!
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/136200-diy-wheel-painting/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 09-06-2009 09:58 PM
RAV4World - :: View topic - 2006 Sport 18" wheel corrosion This thread Refback 06-17-2009 08:19 PM
DIY (Do-It-Yourself) & User Knowledgebase - IBTO Official Forums This thread Refback 05-20-2009 01:00 AM
painting stock rims 07 - CustomTacos.com Forum This thread Refback 05-02-2009 06:54 PM
For all your Car Guru's - Page 45 - Skateboard-City Forum This thread Refback 05-02-2009 05:14 PM
Auto Ventshade Stepshield, Auto Ventshade, Auto Water Pump Service - Laverdausa This thread Refback 03-08-2009 08:29 AM
Oem Wheels, Time Attack Style - RDTiburon.com This thread Refback 02-02-2009 08:00 PM
Toyota Tundra alloy wheels, 18x8, 5x150mm, 2007/2008 This thread Refback 12-13-2008 09:20 PM
2007/2008 Tundra Sequoia alloy wheels + tires, P275/65R18 This thread Refback 12-12-2008 03:22 AM
2007/2008 Tundra alloy wheels + tires, paintable, P275/65R18 This thread Refback 11-25-2008 06:32 PM
2007/2008 Tundra alloy wheels + tires, paintable, for sale or trade This thread Refback 11-17-2008 04:03 PM
