Old 06-22-2008, 07:36 PM
Dealer : Gander Toyota
2008 Toyota Tundra CM LTD Salsa Red,
2000 Toyota Avalon XLS with Moon Roof
Last Online: Today 02:43 PM
stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light. stuball is a glorious beacon of light.
stuball's Photo Albums
Default Back-up lights don't work
The back-up lights aren't working on my '08 Tundra. I looked for the B/U fuse in the fuse box in the engine compartment and couldn't find it.
Does anyone know which fuse would be for the B/U lights? Or could it be some other problem than the fuse?
Thanks.
Stuball
2008 CrewMax Limited 2WD, Salsa Red Pearl w/Biege Int., 5.7 Eng., Moonroof, Nav/Cam, XM Radio, Remote Start, Running Brds with Foot Lamps, Woodgrain Trim, Billet Grill, 3M protection, Weathertechs, Bedrug, A.R.E. LSII Tonneau Cover, Air Lift suspension and using Amsoil.
Old 06-22-2008, 08:18 PM
Default Re: Back-up lights don't work
I did find the B/U light fuse on the fuse panel under the dash. It certainly is inconvenient to access. Anyway, it was a blown fuse.
Stuball
Old 06-22-2008, 08:27 PM
Dealer : Avondale Toyota Scion
Last Online: Yesterday 10:27 PM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
Thanks for the info...at least now we know where to look.
Did you have anything plugged into the trailer plug that might have blown the fuse? Are you running stock backup bulbs?
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 06-23-2008, 12:28 AM
Yes, I'm running stock B/U bulbs.
However, I did hookup and plug into a neighbor's travel trailer to my trailer plug in order to see if my stock rear view mirrors might be sufficient to see behind me without having to use clip-on mirrors. After that episode my back-up lights no longer worked.
After talking to a couple of neighbors, that IMO, are certainly more experienced with auto mechanics than I, they thought replacing the present 10 amp fuse for the B/U light with a 15 amp was OK considering that I will be using it in the near future on my trailer that has B/U lights.
Do you think using a 15 amp to replace a 10 amp in this situation is OK?
My last truck was a '04 GMC that had pulled this same trailer of mine and the GM dealership suggested at the time replacing a burnt out trailer braking fuse (not B/U light fuse) with one that was 5 amps higher would be safe to do so. I don't know. I'm asking is this OK?
Stuball
Old 06-23-2008, 08:13 PM
WT's Avatar
WT WT is online now
Dealer : McGeorge Toyota
Last Online: Today 04:19 PM
Images: 1
WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Stuball
I say no never increase the fuse size unless your in a serious emergency pinch only. Sounds to me the trailer you hooked up to probably had a short in the backup circuit and it caused you to blow your fuse, so the fuse did what its suppose to do. If you increase the fuse size you may end up causing some wires to burn before the fuse blows and could cause a truck fire.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
Old 06-24-2008, 07:46 AM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 04:13 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
What he said.
Charlie & Linda
