  #361 (permalink)
Old 04-14-2009, 12:38 PM
ninja ed's Avatar
Dealer : Findlay Toyota Scion
2008 Toyota Tundra 08 White CMaxSR5 TRD
Last Online: Today 12:14 PM
ninja ed is on a distinguished road.
ninja ed's Photo Albums
Default Re: 19.8mpg after HC removed!
when i first removed it i droped a couple of points. but on the way back from cali i was averagin about 19-21 on the highway and in the city for a couple of days.... but now its all downhill, im averaging 14 now!! wth? did i get bad gas or somethin? still driving normal like i always do and my truck is still bone stock besides the hc filter....
2008 White CrewMax SR5 4x4 TRD
No Fear .50Cal Grille - NoFearGrilles.com
Tow Mirror Swap! =]
Coga PA System
5% Tint
Color Matched Grille Surround
DRL Disabled
  #362 (permalink)
Old 04-15-2009, 05:09 PM
Dealer : Charles Barker Toyota
2008 Toyota Tundra Pyrite Mica and 4x4b,
2003 Lexus GS300 GS Ice SIlver
Last Online: 09-19-2009 10:57 AM
gregwendy is on a distinguished road.
gregwendy's Photo Albums
I have placed this info on other sites, here goes.
I have a 2008 DC 5.7 4x4 with 15000 miles and a bed cap. I removed the HC charcoal filter.
After an 820 mile trip on paper I got 21mpg.
I use the manual shift a lot but the AI kicks in when taking off from a stop.
I love this truck and when Obama is voted out gas prices may come down even more.
Greg D.
Old 04-16-2009, 07:49 AM
Ulev
This message has been deleted by mxsjw. Reason: stay on topic
  #363 (permalink)
Old 04-16-2009, 11:39 AM
joepersad's Avatar
Dealer : Serra Toyota Scion
2008 Toyota Tundra XSP,
- Other - 1969 Conv. Mustang
Last Online: Yesterday 09:39 PM
joepersad is on a distinguished road.
joepersad's Photo Albums
It looks like I'm the only unlucky bastard here. I pulled the charcoal filter - drove 545 miles to Tampa and got --- LESS MILEAGE!!!!!!!!!!!!! Took + battery cable off for 45 minutes - next day drove 780 miles all over the place and used Chevron gas whch usually yeilded 17.8 @ 72-79 mph and got----- 16.5!!!!!!!!!!. I am beside myself here - any input boys?? I sure could use some guidance.
Old 04-16-2009, 05:48 PM
gregwendy
  #364 (permalink)
Old 04-17-2009, 04:04 PM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
2007 Toyota Tundra,
2009 Toyota Venza,
- Other - 05 Honda Odyssey
Last Online: 11-06-2009 08:07 AM
Images: 13
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Too many variables to cover in one post. You have to consider wind, road grade, speed, summer vs winter gas, etc. Unless you do back-to-back runs in identical conditions it is not a valid comparison.
Bottom line is the battery disconnect trick will only give a temporary increase in mileage. For maximum benefit you need to do this on a warmed up engine, then immediately start driving gently after reconnecting.
The reality is the only way to increase your mileage long term is being gentler with your right foot. I regularly get 17+ around town, but I can suck it down to 14 pretty quickly if I want to.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
  #365 (permalink)
Old 04-18-2009, 06:05 PM
No question driving habits have more to do with better mileage than most any other variable.
Driving with the truck lightly loaded, towing, into the wind etc. all have an effect. Face it boys, we don't drive Tundra's for the gas savings but improvements are always welcome.
I recommend using manual shift mode and get to that 6th gear ASAP with a light foot on start-up. I have removed the HC filter and last trip got 20 MPG on paper. Wind was behind me most of the way home Praise Be!
I do think all things considered 20+ highway is very possible with sensible speeds and quality fuel.
It O.K. to let the badger loose on occasion but be willing to pay the price at the pump.
Blessings and drive safe.
  #366 (permalink)
Old 04-18-2009, 07:02 PM
J-ROD's Avatar
2008 Toyota Tundra Pyrite mica
Last Online: 11-05-2009 10:04 AM
Images: 12
J-ROD is on a distinguished road.
J-ROD's Photo Albums
This has to be one of the best free mods you can do for mileage and power.
What other free mods are there??
  #367 (permalink)
Old 04-18-2009, 08:12 PM
Wacked's Avatar
Dealer : Atkinson Toyota
2007 Toyota Tundra Salsa Red Crewmax,
1995 Toyota Truck 4x4 Extra Cab
Last Online: 11-03-2009 09:45 PM
Images: 10
Wacked has much to be proud of. Wacked has much to be proud of. Wacked has much to be proud of. Wacked has much to be proud of.
Wacked's Photo Albums
Try this one
Removing Black Vinyl From Doors
2007 Salsa Red Limited Crewmax
Nav, Sonar, 20" Carved Wheels
Born in TEXAS Built by TEXANS
aFe Stage II Pro-S Dry Si
Corsa Sport Single Cat Back Exhaust
  #368 (permalink)
Old 04-18-2009, 08:21 PM
J-ROD's Avatar
Images: 12
Originally Posted by Wacked View Post
In my color it's prob. not a good idea. I have Pyrite Mica and have yet to see one with the vinyl removed.
  #369 (permalink)
Old 04-18-2009, 08:40 PM
DanMittaul's Avatar
gone fishn, Mullet over
Last Online: 10-20-2009 10:56 AM
Images: 166
DanMittaul has blessed us with their presence. DanMittaul has blessed us with their presence. DanMittaul has blessed us with their presence.
DanMittaul's Photo Albums
Another one I like, pop the hood and pull the metal clips from the horns. Takes a whole 30 seconds and noticeably pumps up the volume when you hit the middle of the steering wheel.
Dan
  #370 (permalink)
Old 04-20-2009, 12:57 PM
Last Online: 04-20-2009 12:58 PM
tgardea is on a distinguished road.
tgardea's Photo Albums
I live in Arizona and will try this. Do i just buy a filter from an auto zone or checkers to replace the one I'll be taking out? Does the Brand matter?
  #371 (permalink)
Old 04-20-2009, 01:14 PM
Dealer : Avondale Toyota Scion
Last Online: Yesterday 10:27 PM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
The HC filter is in the top cover of your air filter box. It is mounted by plastic tabs and was not designed to be removable. It is actually an emission filter made of a charcoal material. It has little effect, if any, on the air flow to the engine. Others will tell you different, but the results are merely wishful thinking and have no documented proof of mpg improvement.
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
  #372 (permalink)
Old 04-23-2009, 11:53 AM
J-ROD's Avatar
Images: 12
I am also getting worse MPG as a result. I drive my 4.7 aprox. 20 miles one way to work on the highway @ 65-70 MPH. I was getting 14.0 AMPG. After removing the HC filter, reseting the battery, and puting in a K&N drop in filter I am getting 13.2 AMPG. Anyone have any words of wizdom???
  #373 (permalink)
Old 04-28-2009, 11:54 PM
bilztrd's Avatar
Dealer : Carson Toyota Scion
Last Online: Today 12:32 PM
Images: 5
bilztrd is on a distinguished road.
bilztrd's Photo Albums
I sort of thrashed mine removing it . Can I get another one ?
The truck seems to run more responsive. Possibly 1-2 beter mpg, but my wife & i both drive it throughout the week.
  #374 (permalink)
Old 10-03-2009, 05:18 PM
Last Online: Today 07:13 AM
John1947 is on a distinguished road.
John1947's Photo Albums
Can you just unsnap the four clips that hold the top of the air box and lift the top of the air box up enough to get at the filter or do you have to disconnect the maf sensor and remove the hose clamp and hose to get at it?
2008 TUNDRA DBL Cab, Limited.
Line X Bedliner
Ventshade Window Visors
Rampage Streamline Step Bars
  #375 (permalink)
Old 10-03-2009, 07:42 PM
Tankerhank's Avatar
Just Call Me Hank
2007 Toyota Tundra Salsa Red DCLB 5.7,
2002 Toyota 4Runner Limited, Silver
Last Online: Today 12:01 AM
Images: 44
Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light. Tankerhank is a glorious beacon of light.
Tankerhank's Photo Albums
Just unsnap the top the HC filter is right there, it is held it by plastic taps "welded" in so you have to break the tabs to pull it out.
Hank
2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
Future mods:
Stebel 300hz Horn
Fog Lights
2005 Rockwood 26' 5'er
2000 Tundra (bought 9/9/99)
JBA Headers
Gone but not forgotten~
