Old 07-03-2008, 01:26 AM
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Today 04:51 PM
Images: 61
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
Default W pics, Tow mirror install on Non Prewired SR5 DIY wiring
ok...i hope this can benefit some one else on here. I have an 07 DC SR5 with leather and all the goodies except somehow it didnt get the defrost mirrors, thus i didnt have the correct wiring harness for an easy tow mirror swap. (I only had 3 wires going into my plugs). For those of you wanting to add tow mirrors or perhaps already have added and lights dont work, then please review this.
I traded mirrors with another TS member "colb4130" - (PS thanks) his towing mirrors for my non heated SR5 mirrors.
I am not going to go into the details on door panel removal, etc.. as thats been discussed and posted many times and would be redundant.
first thing after door panels are off is to also take out the factory (really cheaply made i might add) speaker. 4 screws and unplug it. set it in safe spot. work the rubber boot that goes from the door jam loose. it pulls out from door and pulls away from cab partially, allowing u access to run a wire or fishtape as in my case, through the cab into the door.
This pic shows the boot pulled away to make it easier to run through (if you stretch the boot and make it a straight line its much easier to force the wire/fish tape through.
heres another pic showing what the fish tape end looks like where it came through...
now take three wires, i chose yellow, red and black. i used the yellow for turn signals, red for running lamp and black for ground.
i make a habit when doing multiple wires to do the old stick the end of them in a drill and hold the other and run it slowly to twist them into one wire thats easier to deal with.
once i had my wire, i put it in the end of the fishtape and pulled it through the boot into the cab. it comes out inside the cab where the factory wiring harnesses are, which is behind the kick panels which you need to remove, its easy, little plastic nut and some clips. even owners manual tells you how to do it to add the factory pigtail for trailer wires....both sides are the same.
(as seen in this pic, the three wire twisted ones come through the door to cab boot into here....)
once inside, theres a big rubber grommet on both sides of the truck on the firewall to run wires into the engine compartment. run the wires up through that rubber grommet. i pushed a screwdriver through from the engine side into the cab to make the hole then shoved my trusty fistape back through and pulled the wires through and once covered in wire loom it looks like this....
then i ran the 3 wires in that plastic loom down the inside of the fender on top of the fenderwell with the factory wiring and simply used the quick tap things to tap into the factory park/turn signal wires on the factory parking lights. just remove the bulb so you have room and seperate the wires, probe them to determine which is which with a test light and connect. i put the bulb back in and neatened it all up. once the red and yellow are connected to the running/parking lamp and turn signal wires, connect the black one with a ring terminal to an existing ground or just shoot a self tapping screw into it someplace to ground it out of the way and neatly.
now back to the inside.
take that twisted wiring we just ran into the door up through the rubber grommet with the speaker wires and zip tie it alongside the OEM wiring for the power mirrors up to the doors sail panel where the mirror bolts on and plugs in.
now you can move to the other side.
note some of these pics are from one side, some are from the other but the process is the same from side to side, i just kept forgetting to take pics to post. theres a large rubber grommet on both sides so both are done exactly the same way.
now, take your tow mirror and pull the rubber liner off from around the bolt studs and harness plug...it just pops on and off. you'll have to cut a zip tie on the backside and probally make a slit to get it to come off and get the white plug through it but you want the rubber part off so you can access the harness on the mirror. sorry no detailed pic of just that ( i forgot again).
once you have access to the wires, look at the plug...it has two rows of wires, one row with two black, one brown, one green and it then skips to the end and has one thats blue. the two black ones are for the defrost, which probally wont be needed if you are having to wire your truck for these lights as its probally not wired for that either. but the next wires are as follows: brown wire in the 3rd slot from the left if looking at the back of the plug is ground for both turn and running light. next to it is the green wire - that is the positive wire for the turn signal. the wire thats all the way at the end of that row is the blue wire that is for the running/parking lamp in the mirror. once again i just tapped into these wires with the quick tap things
and ran wires off each tap so i could run them into the truck and connect them once installed. you can see which wire goes to which here. also you can see that rubber insulator thing i was talking about earlier, its laying on my workbench in front of the mirror...
now that you have the short wires connected to the mirror, put the rubber insulator back in place (with the wire taps taped up for added protection) back inside that hollow area of the mirror base and pull the white plug back through where it was before we took it apart.
now bolt the mirror back up to the truck, making sure to pull the new wires through the rectangular hole where the factory plug comes in... once in it should look something like this...
the straight wires are the ones from my mirror and the twisted ones are the ones we ran up through the door earlier...
simply connect these wires to the matching wires however you chose. i used crimp on connectors but you may want to use quick connects in case you need to remove the mirror later or even make a small wiring harness to plug it into. you could also go so far as to get the metal female pins for the inside of that factory mirror plug and just add the wires you need into the OEM plug so its a true plug and play but i didnt find the correct sized ones and didnt care that much haha.
once connected tuck the loop of wire in behind that door panel and reinstall the sail panel (and door panel if not already).
now we should be able to test the lights....heres the turn signals on and the parking lights on....
and now with the truck outside heres one with just parking lights on
i hope someone can find this useful. took me a while to do this thread haha. any questions feel free to ask and i'll try to address them.
OH AND EDIT: im sure there is a way to get to the correct wires inside the cab in that mess of wires but it was easier for me to do it this way. also, keep in mind if u have factory DRLS or did the DIY mod where the DRLS are the turn signals then the signal LEDs in the mirrors will also be lit up. i dont have DRLS so it wasnt an issue with me.
Last edited by 07DCwhiteSR5; 02-15-2009 at 12:32 PM. Reason: re do pics since gallery move
Old 07-03-2008, 01:47 AM
ChadG's Avatar
2007 Toyota Tundra,
2004 Toyota Tacoma TRD Limited Xtra Cab
Last Online: Yesterday 01:33 AM
Images: 7
ChadG is on a distinguished road.
ChadG's Photo Albums
Default Re: W pics, Tow mirror install on Non Prewired SR5 DIY wiring
great write up. Lots of people are going to find this very useful! Thanks for putting the time in and helping out the forum.
Old 07-03-2008, 04:42 AM
colb4130's Avatar
Dealer : Fort Myers Toyota Scion
Last Online: 11-12-2009 10:29 PM
Images: 4
colb4130 is on a distinguished road.
colb4130's Photo Albums
those are some handsome mirrors ;-)
Old 07-03-2008, 06:22 AM
daless2's Avatar
Dealer : Toyota On Nicholasville
Last Online: 08-07-2009 07:26 AM
daless2 will become famous soon enough.
daless2's Photo Albums
Great Write-up! Thanks for taking the time to document and post your project.
Frank
Old 07-03-2008, 08:43 AM
JBK23's Avatar
Dealer : Lowe Toyota of Warner Robins
2006 Toyota Tundra SR5 DC
Last Online: Yesterday 06:16 AM
Images: 10
JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor. JBK23 is a superior contributor.
JBK23's Photo Albums
Nice write up good pics and right to the point !
Old 07-03-2008, 12:21 PM
2007 Toyota Tundra,
Images: 61
why thank you. im bettin your truck sports some nice ones too. just a little less "elephant ear"-ish huh? hahha
Old 07-03-2008, 12:28 PM
dkizerian's Avatar
Dealer : Mark Miller Toyota
1997 Toyota T100,
2007 Toyota Tundra DCSB SR5 Slate
Last Online: 11-04-2009 04:17 PM
dkizerian is on a distinguished road.
dkizerian's Photo Albums
Great write-up!! I had all the wires when I swapped the tow mirrors onto my truck, but if I didn't this would be SUPER helpful!
07 4x4 DC 5.7 SR5
Old 07-03-2008, 01:56 PM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: 11-16-2009 06:28 PM
asianflava is on a distinguished road.
asianflava's Photo Albums
I was planning on doing the same thing once my housing situation was figured out. I have a question, did you tap into the signal wiring at the actual bulb housing?
Good job! Next will be figuring out how to get the heat to work.
Old 07-03-2008, 05:36 PM
2007 Toyota Tundra,
Images: 61
already ahead of you.
but first, yes there are three wires for the turnsignal/park light bulb there at the bulb housing. unscrew it so you have some room and remove the factory black tape stuff. seperate teh three wires, i cant remember which is which now but its super obvious with a test light and probing them. one blinks, one stays solid one just sits there and does nothing haha. i actually found the wires i needed right at the plug then backed dwon the harness a bit to do my taps so i would be able to conceal them better- hated to have a huge blob right at the plug.
as far as the heated mirror part goes, muth mirrors (the ones who sell the integrated LED turn signal mirrors) sells a heated mirror kit that you can use to add heat to their heated glass, its the same glass thats sold for the trucks with factory heat....so its all the same. their kit isnt expensive and includes the switch etc (aftermarket of course) and you can add the heated function so every function works...i just didnt do that now, i may later....dont really need them but it would be nice for that one day i might.
edit, their kit lists for 69 bucks at their website so thats not a bad deal....
Old 07-03-2008, 07:26 PM
asianflava's Avatar
I thought the wiring was already there the ends were just missing (the switch and the wires on the mirror harness). I figured that all I needed to do was to run the missing wires from the kick panel harness to the mirror plug. I was thinking about installing pins into the kick panel harness and the mirror harness. Those wire taps don't have a good history with me.
As far as the heat, I was going to add the heat wires the same way and then just buy the mirror switch that pops into the dash. Probably costs an arm and a leg but it will look totally factory.
Keep up the good work!
Old 07-03-2008, 11:31 PM
2007 Toyota Tundra,
Images: 61
as for the wiring already being there...nope not on an SR5 without heat. i went to muth's website and they had instructions on finding the signal wire in the door as well as in the kick panel, the wires shown in their pics for signals dont exist in mine. i traced the entire harness looking at tons of pics on the web of the wire colors and all and im not sure how far back the wires dont exist but i know they dont exist in the door or the kick panel on my truck...probally over on the pcm side of things maybe but i couldnt find them.
yeah the wire tap things arent the best...but i always crimp the heck out of them and out of all the times ive used them i only lost connection once. one of these days im gonna get the pins to add to the OEM plug anyway and just run the wires into there and do away with the crimp on things....then i plan on soldering the underhood light connections..but only when i have an issue haha.
Old 07-31-2008, 02:30 PM
Curb71's Avatar
Dealer : Frontier Toyota
Last Online: 11-03-2009 10:17 PM
Images: 6
Curb71 is on a distinguished road.
Curb71's Photo Albums
I have a 07 SR5 CM with non heated mirrors and mine DID have all the wires needed for the tow mirrors. So the only way to know for sure is to take a look at the harness.
Great write up btw. Im glad I got lucky and didnt need to do this.
2007 Silver Sky Metalic SR5 TRD 5.7L 4X2 Crewmax.
JBL Sound System
Autodimming Mirror
Bucketseats
Bedliner
(FE, EJ, BU, OF, RL, SO, SR, N1, LU, C4)
Just added:
5 piece Carriage Works Billet Grill. No Logo
Bed Extender
Exhaust Tip
Wet Okole Seat Covers
Anodized Aluminum Shift Knob
Door Sills
Sport Pedals
Tow Mirrors
Raptor 4" Stainless Oval Tube Bars
TRD CAI (with HC filter mod)
TRD Sway Bar
Truxxx 3"/1" lift
20% Tinted Front Windows
Bed Rail over OEM Bed Liner
Relocated Rear Window Button
Coin Holder Replaced With Garmin GPS Mount
50 Series Flowmaster
Old 10-13-2008, 11:08 PM
Wreckonized's Avatar
Dealer : Novato Toyota
2007 Toyota Tundra,
- Other - 1984 Mercedes 280 SL
Last Online: 11-13-2009 05:01 PM
Wreckonized is on a distinguished road.
Wreckonized's Photo Albums
does anyone know what happened to the pictures from this thread??
2007 Tundra Sr5 Double Cab LongBed 5.7
A.R.E. Z series
WeatherTech Liners
33x12.5/20 Toyo Open Country M/T
20x9 BMF Novakane5
Stock height
)x( SuperWhite Krew )x(
)x( Six Seater LongBed beast )x(
Old 10-13-2008, 11:18 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
07DC needs to relink them, they were lost when TS did the photo gallery swap.
Send him a PM and ask if he'll get it done, maybe if more ask, he'll lite a fire under it...LOL
Take a break from the criminals, and help out your Tundra brothers and sisters
Beer please!
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 04:46 PM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
The way the gallery works was changed and that is why so many posts were left with that kind of pics. The pics needed to be uploaded again by the person who posted and then some friendly moderator may have some free time to link them back to the post. Since there are a lot of posts like that it is a very time consuming job
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/136878-w-pics-tow-mirror-install-non/
Posted By For Type Date
DIY (Do-It-Yourself) & User Knowledgebase - Tundra Geeks :: The Toyota Tundra Enthusiast Forum This thread Refback 07-25-2009 09:40 AM
