Old 07-06-2008, 08:06 PM
BEAST-TUNDRA's Avatar
Images: 7
BEAST-TUNDRA is on a distinguished road.
BEAST-TUNDRA's Photo Albums
Default Interco Tires - Winter use only
I am looking at these 3 tires from Interco and I am wondering if anyone is or has ran them. I have the ProComp Stage 2 lift kit, and that is why I have only listed the sizes below. I like Option #1, but I am currently running 37" BFG KM2; which do not have the siping like the TrXus M/T. Option #2 looks pretty wild looking. Option #3 is probably the one for winter but A/T's I find in snow seem to ball up. M/T's if sipped correctly throws out the snow.
Thanks for your input
OPTION #1
http://www.tundrasolutions.com/photo...medium/579.jpg
The NEW TrXus Mud Terrain is INTERCO'S answer to the need of those who want a smooth, super quiet ride with tough, thick sidewalls with a chip and cut resistant compound. This tire has more siping than any other mud terrain on the market; which has proven to be almost magical in icy snowy conditions. These same traction features make this tire a serious rock climber.
Each TrXus Mud Terrain tire has its individual specifications and is heavier than the original equipment tires of comparable size. Many brands of tires are made from generic specifications which means there are many "brand names" coming out of a particular factory but all the tires have a common specification basic body or casing. The only difference is the mold the tire is cured in. The tires will have different tread designs but the body of the tire is common to many others of the same size but under various names.
Prod. Code B/RWL: RXM-16R
Weight: 72
Ply Rating: 10
Sidewall Ply: 3
Skid Depth: 21/32
Tread Width: 9.48
O.D.: 35.3
C.S.: 12.4
Rev Per Mile: 617
Rim: 18x10
Max Infla.: 65
Max Load: 3445
OPTION #2
http://www.tundrasolutions.com/photo...medium/580.jpg
The TrXus STS, the STS stands for Three Stage Sidewall, is a new concept in all terrain tires. These tires are not intended to be a substitute for the Super Swamper or Bogger tires but a tire for you if you spend a lot of time on the street. Besides working so well on the street it has good off road performance and excels in snow and sand. It is also very much at home in the rocks and will impress anyone with its all around performance. This tire is going to set a new standard in the all terrain category
Prod. Code: RXS-27
Weight: 71
Ply Rating: 10
Sidewall Ply: 3
Skid Depth: 20/32
Tread Width: 11.46
O.D.: 35.2
C.S.: 12.7
Rev Per Mile: 619
Rim: 18x10
Max Infla.: 65
Max Load: 3445
OPTION #3
http://www.tundrasolutions.com/photo...medium/648.jpg
The VorTrac design combines all of the features that make up a great all terrain tire. It has a tight tread pattern that is well supported toward the base of the pattern for good stability and long tread life. It has a lot of siping to provide traction in wet weather, snow and ice conditions. Some of the features are designed to prevent large stone retention. All of this is brought into a design that is smooth and quite running along with good looks that will enhance the appearance of any vehicle.
Prod. Code: VOR-44R
Weight: 71
Ply Rating: 10
Sidewall Ply: 2
Skid Depth: 16/32
Tread Width: 10
O.D.: 37
C.S.: 13.10
Rev Per Mile: 544
Rim: 18x8.5-11
Max Infla.: 65
Max Load: 3640
Old 07-06-2008, 08:19 PM
low c1500's Avatar
Dealer : Red Deer Toyota
Last Online: Yesterday 11:33 AM
Images: 1
low c1500 is on a distinguished road.
low c1500's Photo Albums
Default Re: Interco Tires - Winter use only
Save your money and buy a tire siper/groover off ebay. The "Ideal Groover" is around $60. Then just cut sipes 3/8" deep spaced 3/16" apart. This will make those slick mud tires much better on ice.
If new tires are needed go with Toyo MT's.
I could never recommend an Interco tire, they wear extremly fast, and usually vibrate.
2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
Old 07-06-2008, 08:27 PM
Images: 7
low c1500 Re: Interco Tires - Winter use only
I could never recommend an Interco tire, they wear extremly fast, and usually vibrate. Today 06:06 PM
Right on, this is the s**t I need to here
Old 07-06-2008, 08:48 PM
Imdone's Avatar
2004 Toyota 4Runner,
Last Online: 10-31-2009 02:18 PM
Images: 23
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
I had a set of 35s on 16" wheels and I had to keep them pumped up to 55psi to run freeway speed of 70mph, on the pavement they were okay around town, highway sucked but off-road, they were amazing. Their place is offroad, not onroad.
The STS is supposed to be a good sand tire, but I don't live in sand...
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
Old 07-06-2008, 08:50 PM
Images: 7
Imdone Re: Interco Tires - Winter use only
Thanks
Old 07-06-2008, 09:58 PM
apimpdad's Avatar
2002 Toyota Tundra
Last Online: Today 05:40 PM
Images: 57
apimpdad is a splendid one to behold. apimpdad is a splendid one to behold.
Send a message via AIM to apimpdad apimpdad's Photo Albums My eBay
I will never get another Super Swamper tire for my daily driver. They all ride like $h!t in my opinion, and there are better options out there for winter only tires.
SAS Tundra
Build Thread-
SAS on 02 Tundra
Old 07-06-2008, 11:12 PM
Images: 7
apimpdad Re: Interco Tires - Winter use only
Thanks for the reply. I do have a quote for the BFG KO's 37x12.5R18 tires. I am just checking on tires I do not know anything about. The feedback so far says "NO BUY".
