Old 07-10-2008, 11:21 PM
Dealer : Stevens Creek Toyota
2002 Toyota Tacoma
Last Online: 11-03-2009 02:10 AM
truckin' is on a distinguished road.
truckin''s Photo Albums
Default 20x10 wheels
The wheels I want only come in 20x10, but the offset can be tailor to whatever I want. I have a 2.5" Ready Lift kit on the front. With the proper offset, can a 20x10 wheel fit in the front WITHOUT sticking out. I see that most wheels are rither 8.5" or 9" wide and fit somewhat flush with the fenders. I want it like that, but I'm not sure if it's possible with 10" wide wheels in the front. I think the rear should be ok with the correct offset. If I had a 6" plus lift, I wouldn't mind if the wheels/tires stick out, but on a mild 2.5" lift, I think it will look funny if it does sticks out.
Old 07-11-2008, 01:35 PM
Dealer : Toyota of Plano
2007 Toyota Tundra,
- Other - 2007 Mercedes C230
Last Online: Yesterday 11:48 PM
Images: 61
07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything. 07DCwhiteSR5 has done just about everything.
07DCwhiteSR5's Photo Albums
Default Re: 20x10 wheels
i think the 10s are too wide....and wont look good. im just guessing because of the offeset you would need to run in order to be able to turn and drive it.
now i may be wrong....i almost was wrong once but it was a false alarm.
what wheel are u going with thats only avail in one size? thers plenty out there that will fit and are avail in the correct size..
Old 07-11-2008, 04:04 PM
2002 Toyota Tacoma
the wheels i want are RBP wheels. most people using these wheels are lifted 6" plus.
Old 07-11-2008, 04:44 PM
scottruck1987's Avatar
Dealer : Germain Toyota Scion of Sarasota
Last Online: 10-19-2009 03:07 PM
Images: 10
scottruck1987 is on a distinguished road.
scottruck1987's Photo Albums
i ran 20x10s on my Explorer, although for a different purpose. The stock tire size was 16x7.5 and with the new wheels and tires everything was perfectly flush and I had no clearance/rubbing issues. I plan on investing on a set of 22x10s for my truck as soon as I can afford it.
Old 07-11-2008, 05:13 PM
2007 Toyota Tundra Crewmax Ltd
Last Online: 10-13-2009 10:21 AM
SC '04 is on a distinguished road.
SC '04's Photo Albums
With the factory 20" wheels, 33x12.5 tires and a 3" lift I had to have spacers installed. And that made the rubber stick out 2" or more. When I put on the new wheels the rubber started to rub in the wheel well when cranked in reverse.
Old 07-11-2008, 10:40 PM
XLR8's Avatar
Dealer : San Francisco Toyota
2000 Toyota Tundra,
2007 Toyota Tundra SR5 Black Crewmax
Last Online: 07-13-2009 10:28 PM
XLR8 is on a distinguished road.
XLR8's Photo Albums
I have custom made 20x10 with 305/55/20 and they don't rub. I think the backspacing was 6.825. Here are some pictures from the front and rear.
20x10 wheels-budnik3.jpg   20x10 wheels-rearshot1.jpg   20x10 wheels-resizewheel.jpg
Old 07-12-2008, 02:39 PM
2002 Toyota Tacoma
hmmm... very promising. are you running 20x10 all around? what wheels are you using, brand and model? they look really good. if possible, can you double check the backspacing for me? one least thing, can you provide bigger pics of the wheel/tire combo?
if the file is too big, you can email it to me at stangin46@yahoo.com. you have the closest setup that is shedding some light on what i want to do so i want to make sure i do it right. if you can help out, that would be great.
Old 07-14-2008, 10:55 PM
XLR8's Avatar
2000 Toyota Tundra,
XLR8's Photo Albums
Trukin'
The wheels are from Budnik. The backspacing is 6.875. I emailed you some bigger pictures, good luck.
Old 07-16-2008, 11:18 AM
2002 Toyota Tacoma
Trukin'
thanks you for the pics. i will be getting a set of RBP wheels very soon.
