You can't tell anything by the 2 pics because the angles are no good. It needs to be a side view pic of the whole truck from a standing position.
If I lay down by my wheel, I can make my Tacoma look like it has 30 inches of lift on the front end!!! Hmmmm.... now theres an idea
Glad I dont have to pay for gas! My job kicks ***!
I can tell just fine actually. Its weird I know what my truck looks like at those angles and then I look at his truck and I can tell the difference, and if I didn't know what my truck looked like at those angles well heck its just outside I could go compare. Thats amazing how that works!
2007 DC SR5 4x4 4.7
De Badged
All Weather Floor Mats
Painted Wheels
1 3" core 26" power stick mufflers
N-fab pre-runner light bar
Satin Black Head Light Mod
Weren't those pictures up before this thread started?
No if you look at the album you can see the date he posted them. Which is July 23
2007 DC SR5 4x4 4.7
De Badged
Painted Wheels
hey mclovinr all you did was install the bilstein shocks and you got 2.5'' lift ? i'm thinking about lifting my truck but don't want to spend a boatload can you give me some more info ?
well there about 100 bucks a shock so its cheaper then buying spacers and you get a nice pair of shock out of the deal. The shock basically has a spacer in it which compresses the coil, there are three different settings, .5,1.5.2.5, mine is set at the 2.5 and it a little bit higher in the front but i like the look.
Let us know what clip position you set it on and how/if ride was changed. I'm curious to find out if it gets "bouncier" with each higher position.
as far as the compression of the coil goes, i dont think it made it stiffer or bouncier at all and with the new shocks in there the ride has gotten a lot better
how much did they charge for install and alignment to give me idea?
I have crewmax and wonder if 1.5 lift position wouldn't be better cause I don't want to mess with rear end lift, any ideas on that?
the 1.5 will be pretty close i may sit a little bit lower in the front but you wont notice it, but i dont know how much they charge i put them in my self there not really that hard to do, if you decide to put them in ill give you a step by step instruction
Truck looks awesome man and we appreciate the post on the new product, I defininantly think i will be going this route based on your input, I think if you can get them in yourself an alignment usually can be done for under $75 but that would be required regardless of if you went with shocks or the spacer route
