Unichip.com
  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 08-04-2008, 01:44 AM
Last Online: 10-09-2008 11:13 AM
ThreeSixT is on a distinguished road.
ThreeSixT's Photo Albums
Default New Toy Hauler - Towing Help
Just picked up this bad boy at an RV Clearance Sale to support my Track Day / Racing habbit.
Its a 25 footer and the weight specs state:
Hitch Weight 1,040 lbs
Dry Weight 7,240 lbs
Gross Weight 13,040 lbs
Cargo Weight 5,800 lbs
Axle Weight 12,000 lbs
The dealer told me the dry weight was 8,300 lbs, so I thought I would be fine even with the bike and other gear loaded in (500 lbs), but that seems like just the Hitch and Dry Weight combined. Can someone shed some light on this? Also, this is a travel trailer, not a 5th wheeler. Am I screwed here?
As for the truck itself, I have an 08 CrewMax 5.7L 6AT 4x4 Limited with Tow package, but with standard mirrors. I already have a Tekonsha Prodigy Brake Controller and they are installing the weight distribution hitch, but is there anything else I will need right away?...better suspension, tires, etc?
Thanks in advance!
Old 08-04-2008, 03:08 AM
asianflava's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Highlander,
2007 Toyota Tundra CrewMax
Last Online: 07-01-2009 07:20 PM
asianflava is on a distinguished road.
asianflava's Photo Albums
Default Re: New Toy Hauler - Towing Help
I think it is the dry weight + pin weight, there are still manufacturing differences so the actual weight will probably be different, it will probably be more.
If you really want to know, take it down to one of those CAT scales at a truck stop, pay the $8 and have it weighed.
Old 08-04-2008, 06:23 AM
RoboticRV's Avatar
Dealer : Tony Graham Lexus Toyota
Last Online: 06-22-2009 08:51 PM
Images: 5
RoboticRV is on a distinguished road.
RoboticRV's Photo Albums
You won't have a problem towing your trailer with the Tundra. Especially with the weight distribution hitch. On a level highway you will have no problems doing 90-100 Kph.
My trailer fully loaded is close to the same weight as yours if not more with all my junk in there.
2007 5.7L Tundra CrewMax SR5 4x4, Pyrite.
Old 08-04-2008, 06:27 AM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 05:39 AM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
If you get your wdh set right you should be all right , if your going to long haul I would air bag the truck with a 5er this takes the harsh banging of the weight out. You are about the same as my 5er in weight. When you can find a safe place to try this shut of your brake controller and come to a hard stop, nice piece of mind that the Tundra does it fine.
Charlie & Linda
Old 08-04-2008, 08:28 AM
bilztrd's Avatar
Dealer : Carson Toyota Scion
Last Online: Today 12:35 AM
Images: 5
bilztrd is on a distinguished road.
bilztrd's Photo Albums
Use a WD and a Sway Control. Air Bags clean up the ride. Be sure to level the combined unit.
Hope you stoled that Ragen!
Old 08-04-2008, 08:34 AM
Thanks guys!
Got it for $29K with the WD hitch and 2 year warranty included. Think that's pretty good to what I've seen them listed for.
Old 08-04-2008, 08:42 AM
FIVEPOINTSEVEN's Avatar
Dealer : Stadium Toyota Scion
Last Online: 04-22-2009 11:57 PM
Images: 17
FIVEPOINTSEVEN will become famous soon enough.
FIVEPOINTSEVEN's Photo Albums
Originally Posted by ThreeSixT View Post
Thanks guys!
That is awesome man. You have to take pics once you get it all hooked up to the Tundra!
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS, K&N 77 SERIES INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MOTO METAL 951 18" RIMS, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
TIKKKA T3 Stainless .270 Rifle w/Leupold scope...Mess with my truck and I'll show it to you hehe...
Old 08-04-2008, 01:28 PM
even with the stock 275/55/20 Dunlops which are rated at 2409 lbs each for max load?
Old 08-04-2008, 02:11 PM
wildbill129's Avatar
Last Online: Today 12:17 AM
Images: 6
wildbill129 is on a distinguished road.
wildbill129's Photo Albums
That's per tire, so that's roughly 9600 pounds max if evenly distributed across the vehicle, which it is not.
The curb weight is 5705 I think...so:
5705/2 = 2852.50
Hitch weight 1040
Total on rear 3892.5 (1946.25 per tire (Rear))
This doesn't include driver/passengers, gear in bed, loading the trailer etc. so you will be getting close. Personally, I would upgrade to an LT "E" rated tire.
2007 Crewmax 4x4 Limited - Silver
2.5" OME Front Lift w/Toytec 1" Diff Drop
1" Toytec Block rear w/Bilstein 5100 shocks
20" Ultra Mammoth Wheels
305/55/R20 Toyo Open Country A/T
Line-X Bed Liner
Undercover Tonneau
Console Vault
Two car seats and a box full of princess toys!
CBTMA Member
Old 08-04-2008, 02:50 PM
These are the specs I pulled from Toyota for my Tundra (CM LTD 5.7L 4x4 w/ Tow Pkg):
Wt Distributing Hitch - Max Trailer Wt. : 10100lbs
Wt Distributing Hitch - Max Tongue Wt. : 1010lbs
Is that right? And will that be able to handle this TH?
Old 08-04-2008, 02:51 PM
5705/2 = 2852.50
Hitch weight 1040
Yeah, I'm thinking that too. Will probably be switching to these, but they're a little pricey.
Michelin LTX A/T 2
Old 08-04-2008, 07:49 PM
CEL74's Avatar
Dealer : Sparks Toyota
2008 Toyota Tundra X-SP 4X4 Slate
Last Online: 04-19-2009 07:26 PM
Images: 2
CEL74 is on a distinguished road.
CEL74's Photo Albums
I hope I didn't missunderstand what you were asking/saying but on a tt the dry weight includes the hitch weight. So the total weight of the tt is the dry weight, the hitch weight is just that, the weight on the hitch. Typically you want 10 to 15 percent of the total weight of the trailer to be on the hitch. Then you use the weight distribution hitch to distribute the weight to all 4 wheels of the tow vehicle. You will be very close to the GVWR of the truck after you load gear and people in the vehicle. You will probably be okay on the tow capacity as long as you don't load too much stuff in the trailer. May want to check the CGVWR(combined) also.
If I misunderstood then I apologize, if not I hope this helps.
Old 08-04-2008, 07:52 PM
Images: 17
You'll be ok I think...I was on the interstate the other day and I saw a Jeep Cherokee pulling a damn 36' open fisherman!! Looked like the damn front tires of the Jeep were about to lift off the ground but he was just truckin along lol.
DCSB SR5 2WD
Old 08-04-2008, 08:02 PM
CEL74's Avatar
Images: 2
I'm glad ThreeSixT cares to ask and try to get it right instead of heading down the road like that dude!
By the way, the Toy hauler looks sweet!
Old 08-04-2008, 08:07 PM
Images: 17
I'm really glad he thought to ask and come on the forum too. I hope that guy I saw the other got scolded or ticketed by the popo's.
DCSB SR5 2WD
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/142975-new-toy-hauler-towing-help/
Posted By For Type Date
Good Sam Club Open Roads Forum: New Ragen Toy Hauler - Towing Help This thread Refback 02-19-2009 11:32 PM
RV.Net Open Roads Forum: Toy Haulers: New Ragen Toy Hauler - Towing Help This thread Refback 08-04-2008 11:21 PM
