SRT-10:
The truck houses the highest displacement engine in a factory pickup truck--the same 8.3-liter V-10 that powers the all-new 2003 Dodge Viper.
If it's power you're after, this truck sets out to deliver it, with 500 horsepower and 525 lb.-ft. of torque. The truck goes from 0 to 60 in approximately five seconds and tops out at about 150 mph.
Supercharged Tundra:
Unique design fully integrated into the engine with the latest generation Eaton® Twin Vortices System (TVS) roots-type rotor pack. ---The twin four-lobe rotors feature 160-degree twist improves air-handling, noise, and vibration characteristics - Kit includes: -- High flow fuel injectors, single belt drive, and lower heat range iridium-tip spark plugs. -- Water-to-air intercooler system with a custom low temperature radiator (LTR) -- A new performance air Intake system is included in the kit with a TRD re-useable performance filter, Intake Flow Accelerator and a larger upper air box lid with a filter service gauge. -- 50-State emissions legal. Power: 504hp up from 381hp / torque 550lb-ft up from 401lb-ft.
What do you think?
* 1995 LS400 - Supercharged 5.2 Stroker at work
* 1995 SC470 - 4.7L Tundra Motor Start-up Video
* 1993 SC300 - BHG
* 1993 Previa - Cargo Hauler and Love it!
It is known around here that stock 5.7 RCSB's will run almost door to door with a stock Ram SRT-10. The SRT might only get it by one length or so. With a S/C the Tundra would flat our MURDER a Ram SRT-10.
...Hopefully a few peeps will chime in but some guys on here with RCSB's have run into them on the streets and strips and did not really get beat.
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, AFE PRO DRY INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
If its not really a comparison, then why did my stock DOUBLE CAB Tundra hang with a RCSB SRT-10 from 60-95 and only lost by 1.5 trucks to 115 when my top speed limiter kicked in?
You are right, it really is no comparison - a RCSB Tundra would have eaten its lunch in stock form. Supercharged RCSB Tundra would pretty much murder one.
What a waste of $50k+!!! Sink some more money into it so you can keep up with a truck that costs half as much. :der:
Oh yeah, and they guy I raced said his runs 11's...HA HA HA - what, in the 1/8th?
Mine: 2007 Tundra Double Cab, 5.7L, slate, 4x2, Flowmaster 50 series dual in/dual out, black headlight mod, white LED gauges, custom 8" Sub enclosure, Bilstein 5100's at 1.75" lift, 18" Dick Cepek DC-1's with 305/60/18 Mickey Thompson Baja ATZ Radial
Hers: 2007 Tahoe LTZ, Gold Mist Met., 5.3, 4x2, Nav
Previous Vehicles:
1990 Jeep Wrangler Islander, Rancho Lift
1992 Chevrolet Silverado Z71 4x4 RCSB - 190,000 miles and still running strong when I sold it.
2001 Honda Magna VF750
2002 Chevrolet Tahoe Z71
2006 Chevrolet Trailblazer SS (8.9 sec 1/8 mile - STOCK)
2007 Tundra Double Cab, TRD 4x2, 4.7L, desert sand
Check out dragtimes.com, the quickest stock srt10 ran 13 flat, the quickest stock rc/sc 5.7 tundra was 14.1..............
Do a little more homework. Some of the quickest times for RCSB's are NOT on dragtimes lol. What you think every single fastest time for any vehicle in the world is on dragtimes lol?? Nobody gives a $hit about that site. Just look at the list of 1/4 times on THIS SITE and report back...they're in the 13's.
DCSB SR5 2WD
The SRT10 is a cool concept but good luck finding a certified Viper mechanic to work on one!
Slightly modified Ls will be able to keep up/ beat an SRT10. It would not surprise me that a S/Ced Tundra or maybe even one wtih CAI/Exhaust, long tubes and a tune would be able to beat one as well.
Just b/c you have 500 hp in the Ram doesn't mean you can plant it to get the ground. I guess that Tremec has trouble planting it all, and even with the tires being as wide as they are in the rear, it's still difficult.
Just so you know those trucks in that vid have WAY more power than that vette. My dad had that exact C6. The automatic convetible C6's with the LS2 only put down about 320-330rwhp in stock form. Now if that was a manual coupe with Z51 package it would be whooping those trucks...oh and if a guy was driving lol.
DCSB SR5 2WD
Lightning's don't come with S/C'ers do they???
Can't believe an SRT can take a Vett.
To be fair though the starts should have been switched, the guy blowing the horn is going to have a BIG advantage.
Lets look at the factors:
-Girl driver in vette
-Automatic tranny in vette (most driveline loss of all vettes)
-Convertible vette...means heaviest version of the Corvette
-320rwhp
Now for the Lightning:
-Light weight single cab and probably weight reduction!
-Guy driver!
-Probably small pulley, headers, intake, tune!
-400+ rwhp is easy!
Now for the Ram:
-Guy driver!
-8.4L V-10!!
-500 crank hp!
-Probably had intake/tune/headers/exhaust
As usual when all the advantages are on the side opposite the vette it STILL manages to beat or tie the competition!
...Put a stock C6 Z06 out there and see what happens haha.
DCSB SR5 2WD
The guy driving the SRT can snap a gear pretty good, considering its a manual tranny with truck shifter.
The Ford sounds pretty mean, maybe its modded.
That Vette is the slowest production C6 vette, a converttible with 4 spd auto, and a girl driving. You can see her just floor it, and the the traction control kicks in. Had the Vette done a small burn out, then disabled trac-control, it would have launched alot harder.
__________________ 2008 Tundra CrewMax Limited 4x4 5.7, White w/ oak leather, Moonroof, NAV, Factory 20's, XM.
2006 Nissan Murano SE Black, Loaded, Black leather, 20" Dubs
2005 Corvette C6 (#581) Coupe 6 spd Black, Loaded, Black Leather, Navigation, XM, Onstar, HUD, F55 Magnetic ride, Z51 Brakes/calipers/sway-bars, Route 66 Exhaust, Intake, Custom Tune, 160 stat. Only 2 runs at the track...12.4s @116mph
Agree big time. My dad's had a few C6's and they launch muuch better with a 6spd manual and a guy driving lol.:laughing:
DCSB SR5 2WD
There has only been one quarter mile time for a super charged tundra. That time was not very good for so much power. But it was on par with the 2003 Ford and SRT. The thing that scares me, no one has addressed drive shaft speed for the tundra. Everyone wants top speed limiter disabled on a truck with split drive shafts (Dbl Cab, Crew Max) what about the balance of the shaft.
