Old 08-06-2008, 09:24 AM
Last Online: 08-15-2008 10:53 AM
GATSFTundra is on a distinguished road.
GATSFTundra's Photo Albums
Default Wiring question about fog lights
I know, I know... another foglight posting!
I've searched the forums and the DIY stuff is great.
I have a simple wiring question though. If I buy the 20 dollar walmart "foglights" 55W and mount them, can I wire them directly to the headlights without blowing a fuse?
I don't want a separate switch. I want the foglights to be on when I turn the headlights on.
Any thoughts?
Thanks in advance.
(I know you get what you pay for - but I was inspired by the "faux foglights" post)
Old 08-06-2008, 09:39 AM
mendonsy's Avatar
Dealer : Lebrun Toyota
Last Online: Today 04:24 PM
Images: 7
mendonsy has blessed us with their presence. mendonsy has blessed us with their presence. mendonsy has blessed us with their presence.
mendonsy's Photo Albums
Default Re: Wiring question about fog lights
The short answer is no. It would draw too much power for the fuses. If you want them to work as described you will need to run battery power through a relay (fused of course) and turn the relay on with power to the low beams.
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors
CBTMA member
Old 08-06-2008, 09:53 AM
mendonsy's Avatar
Images: 7
I checked the TIS wiring diagram. Each element (LL, LH, RL, RH) has a separate 15 amp fuse. The 55 watt fog draw about 5 amps, so you might get way with wiring one to each of the low beams but it would be close!! If you decide to try it, buy a box of 15 amp fuses before dark.
Toyota SS steps
ARE MX cap
AMP bed step
CBTMA member
Old 08-06-2008, 10:31 AM
Thank you. I'll give it a shot (post amp purchase).
Should I switch the 15 amps to 20 amps? Would that solve anything?
I appreciate your input.
Old 08-06-2008, 11:03 AM
mendonsy's Avatar
Images: 7
I would suggest not doing that because of the wire size, but there is nothing to prevent you from doing it. Toyota doesn't size their wires and connectors to take much extra load. If you decide to try that, check to see if the wire is getting warm. If you can notice the temperature rise, it will probably cause problems.
Toyota SS steps
ARE MX cap
AMP bed step
CBTMA member
Old 08-06-2008, 02:33 PM
wildbill129's Avatar
Last Online: Today 04:46 PM
Images: 6
wildbill129 will become famous soon enough.
wildbill129's Photo Albums
Only if you plan on roasting marshmallows with the fire in your engine compartment.....
NEVER, I mean NEVER increase the fuse size if you don't know whether or not the wire size can handle the load.......
Buy a relay, they are cheap, and you will accomplish the same thing........
2007 Crewmax 4x4 Limited - Silver
2.5" OME Front Lift w/Toytec 1" Diff Drop
1" Toytec Block rear w/Bilstein 5100 shocks
20" Ultra Mammoth Wheels
305/55/R20 Toyo Open Country A/T
Line-X Bed Liner
Undercover Tonneau
Console Vault
Two car seats and a box full of princess toys!
CBTMA Member
Old 08-06-2008, 03:10 PM
FIVEPOINTSEVEN's Avatar
Dealer : Stadium Toyota Scion
Last Online: 07-22-2009 10:31 AM
Images: 17
FIVEPOINTSEVEN will become famous soon enough.
FIVEPOINTSEVEN's Photo Albums
You sure you want to put $20 fogs on a 2008 Tundra? If you pay like $60 you can get a nice pair of Hella fogs from Walmart and they'll come with all the wiring, relay, harnesses, switch, diagrams/directions...everything you need. And they also show you how to wire them so they come on with either your low or hi beams.
DCSB SR5 2WD
-THE MONSTROUS 5.7, 6SPD AUTO, TOW PACKAGE W/4.30 GEARS BABY!, STEBEL 300HZ TRUCK HORN+2 FACTORY HORNS, K&N 77 SERIES INTAKE, TOYTEC 3" LIFT, DEBADGED SYLVANIA H9 LOW BEAM MOD (2100 LUMENS), HIR1 HI BEAM MOD (2350 LUMENS), SILVERSTAR EURO SIGNALS, BLACK HEADLIGHT MOD, BLACK BADGE, JBL 440W SYSTEM W/ NAV W/ BACKUP CAM, SONAR, ESCORT PASSPORT 8500 X50 RADAR, MOTO METAL 951 18" RIMS, MAGNAFLOW 14" 2 IN/2 OUT CATBACK EXHAUST -SYSTEM WITH 4" MAGNAFLOW TIPS, BFG TA KO 285/65/18's!!(32.7"), PIONEER PREMIER SPEAKERS, 2 PREMIER 10" SUBS, 2 KICKER AMPS!!!
Old 08-06-2008, 03:41 PM
Thanks FIVEPOINTSEVEN - I'll got that route.
After buying rims, volant cai, new mats, sidesteps, what's another 60 bucks.
I thought I had the quick easy solution.
Guess not.
Thanks for everyone's input.
