Old 08-19-2008, 04:10 PM
Dealer : Freeman Toyota
2007 Toyota Tundra,
2004 Toyota Avalon XLS loaded
Last Online: 11-06-2009 08:21 AM
mhejl is on a distinguished road.
mhejl's Photo Albums
Default SAP - adding a trans cooler
I have a '07 DC SAP = no tow package. I'd like to add an after market tranny cooler. Texas heat, plumbing, and specific coolers aren't the issue:
Has anyone installed an OEM "ATF Thermostatic Valve" which feeds the cooler? Looks like it just bolts up between the "ATF Warmer" body and the tranny case and simply has two hose nipples to the cooler. (Looking at the FSM, anyway.)
Are the ATF Warmers the same with or without the tow package?
Old 08-19-2008, 11:39 PM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: Today 01:07 AM
thumbster is a splendid one to behold. thumbster is a splendid one to behold.
thumbster's Photo Albums
Default Re: SAP - adding a trans cooler
The ATF heat exchanger is the same for both models. There's a plate sandwiched between it and the transmission case that has the thermostat and nipples for the trans cooler. To install a transmission cooler you have to buy the thermostat plate and o-rings as well as the hard lines. It's a few hundred bucks by the time you're all said and done. I've looked into this myself because of wanting to install an inline transmission filter.
Old 08-20-2008, 09:38 AM
2007 Toyota Tundra,
Thanks for the verification - exactly what I assumed and was asking for I'll just plumb the hard lines myself - no need for OEM expense there.
