installing a trailer brake controller
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 28
Thread: installing a trailer brake controller
  1. #1
    Lurking Member RT8827 is on a distinguished road.
    Join Date
    Jun 2008
    Location
    Phoenix, AZ
    Posts
    26
    Liked
    0 times
    Images
    4
    Rep Power
    5
    Default installing a trailer brake controller
    I've got a 2008 DC with the factory towing package, and I'm planning to purchase a travel trailer in the coming weeks. I've got a trailer brake pigtail in my glovebox which I plan to use for the installation. I've read several threads about the installation of a brake controller, and none of them indicate whether or not I'll need to purchase/install any additional fuses or relays. Are all the necessary fuses & relays already installed by Toyota, since I've got the factory towing package? In other words, I can immediately hook up to a trailer, adjust (dial in) the controller, and start towing?
    Thanks
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava is more than famous, they're infamous. asianflava's Avatar
    Join Date
    Jan 2004
    Location
    Longmont, CO
    Posts
    1,701
    Liked
    12 times
    Rep Power
    2917
    Default Re: installing a trailer brake controller
    It was all there, I bought the P3 and the Toyota harness online, I didn't use the harness in the glovebox. Took about 30min to install. I didn't have to add any fuses if I remember correctly.
  4. #3
    Supporter cwit has disabled reputation cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,332
    Liked
    8 times
    Images
    3
    Rep Power
    912
    Buy the p3 or prodigy and the factory harness, it is plug and play. By the time you figure out the factory harness and hook all the wires together it's just not worth it.
    Charlie & Linda
  5. #4
    Junior Member jarheadfor4 is on a distinguished road.
    Join Date
    Apr 2007
    Location
    Middle of Missouri
    Posts
    172
    Liked
    0 times
    Rep Power
    7
    I used the plug that came with the truck. It was easy to install. I didn't go out and buy anything else and I have been towing ever since.
    No extra fuses or relays needed.
    By the way....what kind of travel trailer are you getting?
    2007 Toyota Tundra 5.7
    ENOUGH SAID!!!
  6. #5
    Veteran Member LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some. LeeinAZ has done just about everything...and then some.
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,515
    Liked
    11 times
    Rep Power
    1155
    I would suggest that instead of using the supplied harness that you buy a harness from a RV store such as Camping World. It comes with connectors on both ends so all you have to do is plug one end into your controller and the other in into the plug on your truck. The color coding of the supplied harness does not match the color coding of the controllers, so you will need to use a schematic and an ohm meter to hook it up correctly. The connecting harness I bought cost less than $20.00 and I hooked up my controller in less than 30 minutes.
    Do a search on Brake Controllers....there should be part numbers, photos, etc. There have been many threads all ready written on the subject. Good Luck!
    '07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
  7. #6
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,515
    Liked
    11 times
    Rep Power
    1155
    Did some searching for you:
    Tekonsha Wire Replacement for Toyota and Lexus Vehicles 3040-P : Trailer hitch bike rack and trailer hitches - etrailer.com
    Brake controller placement in '07?
    Prodigy brake controller
    Tekonsha PRODIGY Trailer Brake Controller little help please
    Electric Trailer Brake Controller Installation
    The answer to your question about fuses and relays is YES, everything is there, ready to go once you connect your controller.
    A side note: The +12 volt wire in the 7 Pin connector that goes to your trailer battery only has power when the key is in the "ON" position.
  8. #7
    Join Date
    Jun 2008
    Location
    Phoenix, AZ
    Posts
    26
    Liked
    0 times
    Images
    4
    Rep Power
    5
    Thread Starter
    Thanks for all the info, guys. I had already viewed many/most of the supplied threads. I was specifically interested in the fuses & relays, though, since they hadn't been mentioned in the other threads. It sounds like I won't need to add any extra fuses/relays when I install the brake controller.
    Quote Originally Posted by jarheadfor4 View Post
    Not yet sure on the TT. I'm on a VERY tight budget, so it will likely be 7-10 years old. Just need something that's fully self-contained, for a family of 4. I'd consider some sort of pop-up trailer, since they're HOA-friendly and could stay on the side of my house... but I expect we'll end up with a traditional travel trailer.
  9. #8
    Junior Member Rifleman is on a distinguished road.
    Join Date
    Jul 2007
    Location
    Casa Grande
    Posts
    133
    Liked
    0 times
    Rep Power
    6
    You will not need to put in any fuses or breakers,they are already there. The factory supplied harness is easy to wire to any controller. Why spend $20.00, when you can do it yourself in ten minutes. If you have money to burn, please send it to me, I can use it.
    John K
  10. #9
    Supporter mkinzer has disabled reputation mkinzer's Avatar
    Join Date
    Oct 2007
    Location
    Winston, GA
    Posts
    27
    Liked
    0 times
    Rep Power
    6
    Asianflava.....We both have the exact same P3 controller mounted in the exact same place. LOL. Looks good. And I thought I was being so original.
    I used the toyota supplied harness and spliced it to the P3 wiring pigtail. One hour install time and most of that was getting the mounting point centered.
    2007 Tundra 5.7L Limited DC 2WD Silver TRD with Banks Dual Monster exhaust and Airaid CAI. Kenwood DNX-7100 and Infinity everything else.
    2007 KTM 250 SX-F
    2006 KTM 50 Mini Adventure
    2005 KTM 525 SMR
    2005 Suzuki DR-Z435SM
    2005 Yamaha FJR1300
    2006 Suzuki LTZ-400
  11. #10
    Junior Member frostydawg69 is on a distinguished road. frostydawg69's Avatar
    Join Date
    Nov 2007
    Location
    Abbeville, SC
    Posts
    58
    Liked
    0 times
    Rep Power
    6
    I really cant see why everyone is making a big deal out of using the factory harness that came with your truck. Its the simplest thing in the world to wire up just follow the instructions and you do not need an ohm meter or anything like that, but if you wanna spend 20 bucks on the other harness then go ahead its your money but I would say just wire the factory one to the controller and start towing.
  12. #11
    Supercharged Member Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog is a rep point pirate, Songdog's Avatar
    Join Date
    Sep 2007
    Location
    Hereford, AZ
    Age
    42
    Posts
    4,298
    Liked
    10 times
    Rep Power
    15021
    Quote Originally Posted by RT8827 View Post
    I would take a good look at the popups before you decide. Some of the new highwalls have every amenity that the TT's have and you can fit them in the garage and still get 15 mpg pulling them. I just bought a Fleetwood Saratoga a few months ago and have been very happy with it. Setup is very simple and only takes 15-20 minutes.
    Songdog
  13. #12
    Rookie joxyer is on a distinguished road.
    Join Date
    Aug 2008
    Location
    Clayton
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    HELP! I just purchased a Prodigy brake controller with cable kit 3040-P for my 2007 Tundra. I took the kick panel off and cannot find where this cable 'mates' into. I found a connector that was taped up higher above the electrical panel but it does not seem to mate up to my cable. Also where to place the white ground wire? I see a couple of wires screwed into the frame of the truck on the front portion of the kick area so assuming this is where the ground wire goes. My bigger problem is locating the connector under the kick panel. I have the tow package also.
    Any help would be appreciated:
    Thanks
  14. #13
    Jedi Ninja in Training mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw has a brilliant future. mxsjw's Avatar
    Join Date
    Jan 2007
    Location
    Lakewood, WA
    Posts
    8,393
    Liked
    8 times
    Images
    12
    Rep Power
    77
    Quote Originally Posted by joxyer View Post
    Thanks
    Sounds like you found the correct wire bundle, but you need to remove the blank that is inserted before you plug in the 3040-P harness.
    Yes, one of those 10mm bolts towards the front of the kick panel is a perfect place for the white ground wire, I just used one that already had grounds on it.
    PS, I removed your personal info from your post...not a good idea to post that stuff on a public forum.
    Beer please!
  15. #14
    Veteran Member bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd is a pinnacle in their own mind. bilztrd's Avatar
    Join Date
    Sep 2007
    Location
    whittier ca
    Posts
    563
    Liked
    4 times
    Images
    5
    Rep Power
    1309
    I spliced the factory cable it made it easier to route the harness. I took out the ash tray and replaced it with thre Prodigy (Bench Seat model SR5). The whole job was less than 1 hour including figuring where to mount it. Save Your $20, it not a big deal to splice.
  16. #15
    Join Date
    Apr 2007
    Location
    Kingman, AZ
    Posts
    1,515
    Liked
    11 times
    Rep Power
    1155
    That is a true statement, but only if you have experience in electronics and wiring. The main thing is to solder all connections and DO NOT use the crimp connectors. They are prone to bad electrical connections and can be unreliable. Remember, you are connecting a brake system that your life, or someone else's, may depend upon.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
