Old 08-25-2008, 02:47 PM
Curb71's Avatar
Dealer : Frontier Toyota
Last Online: 11-03-2009 10:17 PM
Images: 6
Curb71 is on a distinguished road.
Curb71's Photo Albums
Default New flowmaster muffler and my gas mileage is crap?
I had the 50 series flowmaster muffler installed a couple weeks ago and noticed since then my truck is different. While on the freeway goin 70-75mph it used to run around 1500rpms and now its a little over 2k. This hill on the 118 freeway I go over constantly I would get around 12-13mpg goin up it. Now I get about 10mpg goin up it. After I removed the HC filter from my TRD CAI I was getting about 18mpg on freeway but now Im getting about 15mpg.
Did the muffler make my truck run different and kill my mpg or is there something wrong with my truck?
2007 Silver Sky Metalic SR5 TRD 5.7L 4X2 Crewmax.
JBL Sound System
Autodimming Mirror
Bucketseats
Bedliner
(FE, EJ, BU, OF, RL, SO, SR, N1, LU, C4)
Just added:
5 piece Carriage Works Billet Grill. No Logo
Bed Extender
Exhaust Tip
Wet Okole Seat Covers
Anodized Aluminum Shift Knob
Door Sills
Sport Pedals
Tow Mirrors
Raptor 4" Stainless Oval Tube Bars
TRD CAI (with HC filter mod)
TRD Sway Bar
Truxxx 3"/1" lift
20% Tinted Front Windows
Bed Rail over OEM Bed Liner
Relocated Rear Window Button
Coin Holder Replaced With Garmin GPS Mount
50 Series Flowmaster
Old 08-25-2008, 02:59 PM
Sweet Mercy's Avatar
U didn't get an I-FORCE 5.7...
Dealer : Ramey Toyota
2007 Toyota Tundra,
- Other - 05 Legacy Sedan GT
Images: 41
Sweet Mercy will become famous soon enough.
Sweet Mercy's Photo Albums My eBay
Default Re: New flowmaster muffler and my gas milage is crap?
Curb
I have installed two different exhausts on my 5.7. The first being a JBA which I personally did not like because of drone--again just my opinion on my particular truck and my set of ears. I then installed the flowmaster 50 series big-block which was better with the drone but I soon got tired of feeling like the low end torque was missing. Again my opinion on what I felt.
I liked that the truck, when stock, pulled soooo good in 6th gear and rarely downshifted to 5th on hills but when I changed the exhaust, the truck more quickly downshifted on the same hills, although it did seem to run better at higher rpm's. I'm not one for high rpm's a lot so I put my factory exhaust back on and couldn't be happier.
Performance: Volant CAI; Classic Chambered Dual Exhaust--Powersticks
Exterior: Clear lens headlight covers; Westin side steps; Ventvisors-in channel, Spray in liner, Rancho shocks 9000xl front and rear, Silverstar high beams & fog lights, Polarg low beams, TRD oil cap, Chrome door handles, Limited outside mirrors, EGR bug shield, Remote start, TRD rear sway bar, TruXedo Tonneau, Grille overlay, 275/60 on Pro Comp 6066 20x8.5.
Interior: Opti Gauges, Limited instrument panel, Weathertech floor mats, Sport Pedals, auto-dim rear view and 35% side window tint.
CBTMA member
SEARCH FIRST
Old 08-25-2008, 03:00 PM
Dealer : Earnhardt Toyota
Last Online: 12-12-2008 06:55 PM
Rifleman may have some regrets.
Rifleman's Photo Albums
The only thing that is going to change your RPM at a given speed is if it's in a different gear (unless you changed tire size). In my opinion, the exhaust system on the Tundra is pretty darn good. Not very loud, but efficient. Sometimes, lowering the back pressure will hurt your mileage at constant lower RPM driving speeds. It will give some more power on the top end, but gives up some on the lower. Try disconnecting the negative terminal of the battery, leave it off for several minutes and then reconnect. This will reset the computer and let it relearn with the new muffler. It might help pick up your mileage some. I have the DC with towing option and my truck has never run at 1500 RPM at 70 to 75 mph. It's closer to 2000 to 2100 RPM. You might take a look at the welding job done also. If the muffler was put on at some weird angle that left a piece of the pipe wedged at an angle in the muffler, it could be restricting the flow.
John K
Old 08-25-2008, 03:24 PM
millsp's Avatar
Dealer : Lipton Toyota Scion
2007 Toyota Tundra Crew Max Silver TRD
Images: 39
millsp will become famous soon enough. millsp will become famous soon enough.
millsp's Photo Albums My eBay
Also be sure your tow haul button is not on.
TundraSolutions.com Forum Rules
Classified Forum Rules
What is Rep Power? read more HERE!
Florida Panthers Season Ticket Holder! Sweet!
Old 08-25-2008, 05:11 PM
Dealer : Toyota of Temecula Valley
2007 Toyota Tundra,
2005 Scion xB,
2001 Toyota Tacoma XCab 4X4
Last Online: 11-21-2009 11:20 AM
svedspx is on a distinguished road.
svedspx's Photo Albums
John K
The battery disconnect gets my vote. My first exhaust had 3'' pipes. Changed to 2.5 and made a big difference w performance.
Old 08-25-2008, 05:29 PM
Curb71's Avatar
Images: 6
The tow/haul button is not on. That was the first thing I checked. Im a truck driver and noticed thats kinda how its been running is like the tow/haul button is on.
Ill disconnect the negitive terminal for a while to reset the ECU. Ill check the welding job too.
thanks all for your help.
JBL Sound System
Autodimming Mirror
Bucketseats
Bedliner
Just added:
Bed Extender
Exhaust Tip
Door Sills
Sport Pedals
Tow Mirrors
TRD Sway Bar
Truxxx 3"/1" lift
Old 08-25-2008, 10:54 PM
Curb71's Avatar
Images: 6
I disconnected the battery for about 30 minutes and hooked it back up and took it for a drive and it seems to run like it used to! back to 1500rpms on the freeway and much better mileage on the instant readout thing. thanks !
JBL Sound System
Autodimming Mirror
Bucketseats
Bedliner
Just added:
Bed Extender
Exhaust Tip
Door Sills
Sport Pedals
Tow Mirrors
TRD Sway Bar
Truxxx 3"/1" lift
Old 08-26-2008, 01:18 AM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
2007 Toyota Camry HV
Last Online: 10-28-2009 02:33 PM
Jer is on a distinguished road.
Jer's Photo Albums
Not the first time I've heard this. I would NEVER put anything with the name 'Flowmaster' on any vehicles I own even if it were free. That's just me though. I'm sure someone will flame me for posting but those that know DON'T use Flowmaster. Little late for you now.
A right, not a privilege - ΜΟΛΩΝ ΛΑΒΕ
=-----> DO NOT SHIP W/DAS (DEPENDABLE AUTO SHIPPERS)!! <----=
Old 08-26-2008, 03:14 AM
Dealer : Poway Toyota
Last Online: Today 07:19 PM
matrix77 is a splendid one to behold. matrix77 is a splendid one to behold.
matrix77's Photo Albums
Can you elaborate a little? I''m learning.....
2007 Tundra SR5 CrewMax 5.7L
Old 08-26-2008, 11:26 AM
RudyDep's Avatar
Moderator
Dealer : Universal Toyota
2007 Toyota Tundra,
- Other -,
2008 Toyota Sequoia Slate Metallic Ltd
Last Online: Today 05:21 PM
Images: 23
RudyDep has blessed us with their presence. RudyDep has blessed us with their presence. RudyDep has blessed us with their presence.
RudyDep's Photo Albums
Yeah, Id like to know whats wrong with the systems that Ive been using for 15 years !!!
Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member"
all that is remaining is:
Black Mod Headlights
1997 Chevy Tahoe Sport 4x4
2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem."
President Ronald Reagan 1985
Old 08-26-2008, 11:45 AM
semcoll's Avatar
Dealer : Panama City Toyota Scion
Last Online: Today 02:06 PM
Images: 15
semcoll will become famous soon enough. semcoll will become famous soon enough.
semcoll's Photo Albums
Please elaborate. I'm in the collision business and don't profess to be educated in the world of exhaust flow, backpressure and the like. Did I waste my money by installing a 50 series Flowmaster on my truck?
5.7L 2WD DC Salsa Red Pearl SOS/TR 2"/4" drop, 20 x 9 Incubus Shylock alloys, 295/45/20 Falken TZ01 tires , TRD anti-sway bar, Hella Optilux driving lights, Flowmaster 50 dual in/out w/baffled Hooker tips, LineX, DeeZee black diamond toolbox,filled color-matched grille shell w/CarriageWorks insert, Blacked-out headlights, 50 watt back-up lights in bumper, Rockford Fosgate T400-4 amp,Polk Audio speaker upgrade, single 10" MTX sub,Beltronics 955 radar unit.
Old 08-26-2008, 12:08 PM
Jer's Avatar
Jer Jer is offline
2006 Toyota Tundra,
1995 Toyota Supra,
Jer's Photo Albums
Do some searching. Many many many years ago I did a custom 3" exhaust on my 1990 Eclipse GSX with some mods. The exhaust actually felt worse then my HKS cat-back. This just can't be possible I thought to myself. Did some searching and found some bad reviews on Flowmaster and how little they actually flowed. Took it to a different shop and had them swap out the Flowmaster for a Magnaflow and the car ran like a stripe-ed @$$ed monkey the way I expected. It's been my experience over the years that whenever someone starts a thread on ANY forum about a new exhaust making the vehicle seem slower more often than not it's a Flowmaster. If you search the world wide web you will see more examples of what I'm speaking of.
Old 08-26-2008, 01:04 PM
semcoll's Avatar
Images: 15
Read this. It is not a Flowmaster issue, rather a rule of physics.
Flowmaster, Inc.
