Old 09-12-2008, 09:12 PM
crah's Avatar
Dealer : Desert Toyota of Las Vegas
Last Online: 10-30-2009 02:05 AM
crah is on a distinguished road.
crah's Photo Albums
Default Door popping noise when opening
My driver's side door makes a popping/clicking noise when opening. It seams like it pops at each stopping point. It doesn't seem like it's coming from the top or bottom hinge, but more from the center piece that goes into the door.
I already sprayed some WD40 with no results.
Anyone run into this and have a fix? I don't want to have to take it to the dealer, if I can fix it myself.
2007 DC 4x2 5.7 SR5
Old 09-12-2008, 09:22 PM
Dealer : Elmore Toyota Scion
Last Online: 10-25-2009 03:48 PM
blacktundra1 is on a distinguished road.
blacktundra1's Photo Albums
Default Re: Door popping noise when opening
You can check your door's latch to make sure it's perfectly in the middle of the striker on the B pillar.
BT
Old 09-13-2008, 11:37 AM
crah's Avatar
crah's Photo Albums
Door is lined up correctly and hits the strike perfect. I'm pretty sure it's the middle piece on the hinge side that goes into the door. It looks like I will have to have the dealer look at it at the next oil change. Thanks for the suggestion.
BT
2007 DC 4x2 5.7 SR5
Old 09-13-2008, 01:10 PM
Another thing you can try is to roll your window down and hold the bottom part of your door then push the upper window frame openning outward just a tad, this will probably help the popping and you might also want to wd40 the checkstrap too.
BT
Old 09-13-2008, 02:28 PM
Big_Al1's Avatar
veteran member
Dealer : Lake Charles Toyota
2005 Toyota Tundra,
2008 Toyota Sienna XLE
Last Online: Today 07:36 AM
Images: 16
Big_Al1 will become famous soon enough.
Send a message via Yahoo to Big_Al1 Big_Al1's Photo Albums My eBay
My company truck did this a while back not Toyota but come to find out the hinge where door connects to frame was cracked.Look at it closely when opening door.It would pop and click everytime I opened and closed the door.
Old 09-13-2008, 04:42 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
try to tighten the bolts on the door check
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
Old 09-13-2008, 05:06 PM
Dealer : Claremont Toyota Scion
Last Online: 11-20-2009 04:25 PM
Blaqk Tundra 67 is on a distinguished road.
Blaqk Tundra 67's Photo Albums
I had the same problem, it ended up being the door hinge area the bolts/nuts were loose, dealer fixed it for me when I went in for an oil change.
2007 Black Tundra CrewMax SR5 5.7 4x4.
.TRD Sway Bar. .Chrome Handles. .Carriage Works 5 Piece Black Billet Grille set. .Line-X Spray in bedliner. .Bed Rails. .Readylift 2.4. .Black 20" Ultra Goliath with Michelin LTX AT2 275/65/20.
Old 09-13-2008, 05:11 PM
crah's Avatar
crah's Photo Albums
Is the door check the middle piece in between the hinges? I'll check to see if I can see any bolts to tighten. Thanks for the info.
2007 DC 4x2 5.7 SR5
Old 09-13-2008, 07:52 PM
crah's Avatar
crah's Photo Albums
I tried your suggestion and it worked. All it took was a 10mm socket. I checked all the other doors and they need a little tightening too.
Thanks again.
2007 DC 4x2 5.7 SR5
Old 09-13-2008, 11:35 PM
mral1515's Avatar
2007 Toyota Tundra,
I have seen this a couple times. It is an easy fix we have seen it on a lot of Toyota's. Not just the Tundra
Master Toyota Tech
ASE Master Tech
Shop Foreman
