Is there any way to do something so when you turn the truck on the VSC is off already? I hate every time having to get in and push that button 3 times is so annoying!!
08 CM 5.7L Super White
MODs.
Magnaflow duals H-PIPE
AFE CAI Stage 2
TRD Sway Bar
Boss 329 22's
Black Headlight MOD
__________________ Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member" all that is remaining is:
Black Mod Headlights 1997 Chevy Tahoe Sport 4x4 2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem." President Ronald Reagan 1985
I am getting tired of that too. It shouldn't be that tough to set up a little microcontroller to sense when the truck starts up and then apply the switch press automatically.
That would be awesome should be the other away around anyways should be off than if you wanted vsc push the damn button but no toyota always has to be difficult!!
MODs.
AFE CAI Stage 2
TRD Sway Bar
Boss 329 22's
Black Headlight MOD
I do have a idea for this just have not found enough time to check out the wiring for the back of the switch yet. Also I seldom turn off the VSC in my truck, so to me this is not one of the things high on my priority list to do next.
I also don't see a high demand for this personally but I could be wrong.
Your Idea would be very appreciated if it worked, I dont like the vsc everytime im on a intersection and i wanna take off fast to turn the vsc makes the engine bog down
MODs.
AFE CAI Stage 2
TRD Sway Bar
Boss 329 22's
Black Headlight MOD
you might wanna look into the 350Z/ G35 Relm cause I had installed a box that did just that for those cars. I still have an extra box from a customer that ordered one to many and gave me the extra. I run the same unit on my G35 works out pretty well. There VDC was the same type set up. One of these days Ill get around to trying it out!
Okay for thoose of us that have a 07 I got around to test a few things out today since I was off and it was nice outside. My idea works as I thought it would. Just got to ground a wire for 4-5 seconds on the back of the switch with a module you can get for around $20.00 (I happen to have a few modules laying around for other projects). Well now my VSC button works opposite of stock, When you start the truck it bypass it automaticly and then if you want you can push the button to turn on the safety features again or bypass then as normal. Well I will post up more information once I get around to doing a little more real work testing this weekend. I want to make sure there are no odd side effects.
I am still debating on if I want to go through the trouble of writing anything up on this cause in my head cause I still don't think to many people want this option but I could be wrong. Guess If there is enough people that may want this I start a new post and add a few pictures and what not.
Is there a noticeable difference in power/torque with the VSC turned off? How exactly is this done again? Had the truck for almost a year but never deactivated the darn thing.
I am ALL for this mod. I also have an 08 - even if it just got me to VSC/ATRAC off and LSD on starting out (basically what you get after the first three seconds), that would be cool!
'08 5.7 TRD SR5 4X4 DC, Supercharged, Banks Monster single, Black Limited 20s, Line-X
Please man post pics how to do it and stuff that would be awesome and what box is that? Also mine is an 08 would it work?
Okay guys I start a new thread later tonight once I get a few pics off the camera, as for if this will work with the 08 not sure how you guys VSC button works compared to 07 but on the 07 we just push the VSC button for 1 second and it turns it half off and if you hold it for 4 seconds it turns everything else off.
