Exclamation Point ?
+ Reply to Thread
Results 1 to 7 of 7
Thread: Exclamation Point ?
  1. #1
    Join Date
    Jun 2008
    Location
    Haverhill, MA
    Posts
    32
    Liked
    0 times
    Rep Power
    8
    Default Exclamation Point ?
    ok, based on my owners manual, i see a warning for tire pressure. however, is there more than one exclamation point on the dash indicating different issues? this exclamation point is in the oil pressure gauge.
    i checked my tire pressure and one of my tires was low last night. i filled it up, but the light is still on. i didnt check the pressure this morning, so perhaps i have a slow leak. but, i did check it right after i filled it last night, and the light was still on. does it need to be reset after adjusting the pressure? i would think if its intelligent enough to decide it is low, it should be intelligent enough to realize when its back at the correct pressure.
    anyone familiar with this? is an exclamation point in that area for tire pressure? if so, any suggestions. obviously i can take it to the dealer, but we all know thats a PITA.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Feb 2008
    Location
    jacksonville, fl
    Age
    32
    Posts
    42
    Liked
    0 times
    Rep Power
    8
    Default Re: Exclamation Point ?
    I know when my tire pressure light came on, once I filled it up over 26psi the light cleared it self. Did you check all of your other tires? I am not sure but you might have TPMS on your spare as well.
  4. #3
    Join Date
    Jun 2008
    Location
    Haverhill, MA
    Posts
    32
    Liked
    0 times
    Rep Power
    8
    Thread Starter
    thanks for the response. i did not check the spare. does anyone know if it monitors the spare?
    i did have my 10,000 mile service a cpl weeks ago. could rotating the tires have caused an issue?
  5. #4
    Supporter PACER's Avatar
    Join Date
    Apr 2004
    Location
    Newburgh, IN
    Age
    41
    Posts
    165
    Liked
    0 times
    Images
    11
    Rep Power
    12
    When I looked in my manual about this it stated that the spare tire does not have a tire pressure sensor. When my tpms light came on last week I made sure I didn't have a flat or a low tire first. All tires were at 34 psi. I increased it a little and reset the tpms, and the warning light came off. I believe the manual states that after changing the air pressure you need to resest the tpms and turn your key to the on position for 3 to 6 minutes for the warning light to go off. It also states that if this doesn't work then try it again or have it inspected by the dealership.
  6. #5
    Join Date
    Jun 2008
    Location
    Haverhill, MA
    Posts
    32
    Liked
    0 times
    Rep Power
    8
    Thread Starter
    ok, ill check my manual. i couldnt find anything in there. no idea how to reset the tpms.
  7. #6
    Supporter RIjon's Avatar
    Join Date
    Jun 2006
    Location
    Rhode Island
    Age
    42
    Posts
    1,142
    Liked
    71 times
    Images
    25
    Rep Power
    7908
    The reset button is down by your knees on the drivers side.
    Push and hold that button for 3+ seconds.
    2008 Tundra 5.7L RCSB 2WD Supercharged, Auburn LSD, IPT Valvebody, Sequoia swaybar, BAM stainless custom exhaust, etc...
    www.gaugeplates.com
  8. #7
    Supporter los211's Avatar
    Join Date
    May 2007
    Location
    San Jose, CA
    Posts
    846
    Liked
    0 times
    Images
    6
    Rep Power
    43
    If the reset under the dash does not clear the light you may have a failed sensor and need to have Toyota hookup their techstream to find which one has failed.
    '10 5.7 SUPER WHITE CREWMAX
    2 Flowmaster 40 series w/ dual tips out the back, Airaid intake, 22" BOSS 329 w/ 305/45/22 General grabber UHP, weathertech window vent shades, TRD swaybar.
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
