Old 11-07-2008, 07:07 PM
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
Last Online: Today 05:46 AM
seadragon will become famous soon enough. seadragon will become famous soon enough.
seadragon's Photo Albums
Default Ratcheting sound on starting cold engine?
Hi everyone,
For the last few days and occasionally in the past, I've noticed a strange sound right after starting the engine from cold. About one second after the engine starts, there is a quick and rather loud "ratcheting" type sound that seems to come from right under the cab of the truck. Best way to describe it would be the sound you get from a ratchet lever on a tie down if you flip it quickly. Sounds like a gear trying to mesh or something. It only lasts for about one second and seems to only occur if the truck has been sitting overnight.
Anyone else notice this? It may be normal, but I'm not sure.
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 11-07-2008, 08:19 PM
Go Flames Go's Avatar
Dealer : Canyon Creek Toyota
Last Online: Yesterday 05:32 PM
Go Flames Go is a splendid one to behold. Go Flames Go is a splendid one to behold.
Go Flames Go's Photo Albums
Default Re: Ratcheting sound on starting cold engine?
I have this too. I dont drive my truck that often so it sits in my garage for a while; when I start it after it has been sitting I especially notice it.
Could it be the timing chain? I sure hope it is not dry cyclinder walls or something like that.
If any one has info I would love to know as well.
Old 11-07-2008, 09:27 PM
Dealer : Autoway Toyota
Last Online: 10-08-2009 09:45 PM
fla_guy is on a distinguished road.
fla_guy's Photo Albums
Could be a loose heat shield? Just a loose metal plate - happened to me and the dealer secured it with additional insulation.
2007 Tundra DC TRD 4x4
Pyrite Mica
Bucket Seats
Cold Kit
Deck Rails
Tow Mirrors
Door sill protectors
Old 11-07-2008, 09:30 PM
Terrocel's Avatar
Dealer : Al Hendrickson Toyota
1996 Toyota Tercel 200+ WHP, Monster!,
Last Online: Yesterday 10:24 PM
Terrocel is on a distinguished road.
Terrocel's Photo Albums
I have too, its "normal"
Old 11-07-2008, 09:36 PM
seadragon's Avatar
Thanks for the replies guys. Good thought on the heat shield fla_guy. However, it's not a rattly/loose kind of sound if you know what I mean. It sounds like the teeth of moving gears engaging momentarily.
The truck is functioning fine though. I may ask the dealer next time I'm in if they know what it is. I'm more curious than worried. I like knowing what all these sounds are.
Old 11-07-2008, 10:33 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
It's the ABS self check, I notice it more as the weather gets cooler too...check the manual if you have a hard time believing me. The ratchet sound is each of the ABS cylinders firing/checking in succession. Should be coming from the driver's side, right against the fire wall, where the ABS unit is located. Usually will only happen if the truck has been shut down and is completely cooled off.
Another sound that happens just about the same speed as the doors auto lock, is the VSC self check...makes a clunk/clank...most don't notice it cause the doors locking is louder. Sound comes from the passenger's side, towards the back of the cab. Happens when the transmission is cool. You can feel it vibrate a little. Again, it's in the manual.
One more odd one happens a couple hours after the truck is shut off, that's the EVAP check. Makes sort of a whirring sound...you guessed it, in the manual.
Hope that helps ease your mind.
Beer please!
Old 11-07-2008, 10:39 PM
seadragon's Avatar
Thanks, yes that info is helpful. I'm aware of the check that occurs when the doors lock and evap system check. But I think you nailed it on the head with the ABS firing in succession. The sound indeed seems to come from the firewall/driver side area.
Great info.
Old 11-07-2008, 10:52 PM
seadragon's Avatar
I also just read elsewhere that it might be the AC compressor kicking in. I'll have to pay attention if I left the HVAC in defrost mode thus activating the compressor on startup.
Old 11-07-2008, 11:48 PM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: 11-15-2009 01:12 AM
thumbster is a splendid one to behold. thumbster is a splendid one to behold.
thumbster's Photo Albums
I second the opinion on the ABS self test. You can actually hear the brake caliper pistons clank around from the test when the ABS unit pulses the solenoids - really freaked me out when I heard it the first time! The longer the truck sits, the more likely it will occur, because the unit stores residual hydraulic pressure between every time the truck is driven. If it doesn't have any pressure to work with upon startup, it pumps brake fluid itself to obtain pressure for the self test.
Old 11-08-2008, 12:12 AM
Dealer : Phil Meador Toyota
Last Online: 11-03-2009 04:31 PM
metrictundra is on a distinguished road.
metrictundra's Photo Albums
I don't know about the ABS thing but I will say it has something to do with the AC compressor.
Old 11-08-2008, 03:36 PM
Right on, that would explain why mine does it so loud; I dont drive it that much, there are long intervals between each time I get it out.
Puts my mind at ease!
Thanks guys.
