Thanks and right back at you with the compliment. Your setup is very tough looking and well proportioned.
How did your ARB bumper connect to the frame? Did it use the same 4 bolts on each side as the stock bumper like my expedition one does, or did they supply additional brackets of some sort?
While e1 is supposed to supply additional brackets to beef things up, i'm curious what ARB did and how rugged it's been when winching?
__________________ 2008 CrewMax 5.7L Limited +Nav - Salsa Red
Nitto 35x13x20 (325/60r20) on Balistic 20x9 (+12mm) Wheels
LazerLite Tonneau, Wilderness Rack, XM, Scanner and Broadband Antenna's. Davis Weather Station (remote anemometer up/down control), 3 Cameras, Shovel and High-Lift Mounts, 2 Bed Mounted 5gal. Jerry Cans
Bearcat Scanner (GPS and Remote Head), Ram Mounted Tablet PC (GPS - Google Earth, USB HUB, Broadband, and Video wired). Cobra Integrated GPS Radar, IPOD and XM Integrated
Two mounting brackets(which does not affect the operation of the airbags) to the chassis, using the existing flange nuts.
Funny thing is, I pulled out a stuck 30 ft. U-haul with my truck because I was in to much of a hurry to set up the pull using the winch. Other than that story, it has been dormant. Truck weighs 7000lbs. now, so I purchased a snatch block to increase my pull weight from 9500 to 18000 lbs.
__________________ 07 Tundra Ltd. 4x4 5.7L.
ARB Winch Bull Bar Bumper c/w Warn 9.5XP Winch, and the Light Force 170 Striker driving lights Fab Fours Bumper ProComp --- Alcan Leafs (6" lift) c/w TC shackles --- Icon Coil overs P/N# IVD5-8650 c/w 4.25" spacer MBRP 3.5" Exhaust - modified Weston - Oval 2 Heim U.C.A Hellwig Sway Bar - modified BFG KM2 Mud Terrains - 37" --- KMC Wheels: XD series Monsters – 20 x 9 Nitto Terra Grapplers - 35" --- American Racing: Thugs - 18x9 Bushwacker Fenders Mobil 1 & Amsoil Synthetic Line-X P.E JackRabbit Bed Cover Black Front Grill TRD SC Tiregate - Bed mount Series VI c/w BlendMount Bracket Garmin 255W
Funny thing is, I pulled out a stuck 30 ft. U-haul with my truck because I was in to much of a hurry to set up the pull using the winch. Other than that story, it has been dormant. Truck weighs 7000lbs. now, so I purchased a shackle to increase my pull weight from 9500 to 18000 lbs.
That's good to hear, this is exactly how the expedition one is connected to the frame. I was a little Leary because the flange nuts are smaller than what I experienced with other winch bumper mounts.
I got e1 to thrown in a pulley block to double my winch pull to 18000 lbs., just like you have. If you connect the winch line through the pulley and back to your OEM tow hook, the load should evenly divide between the bumper and frame, while still doubling your pull power.
When I had my ARB bumper on my 98 Land cruiser I used to max out the 9000lbs. winch all the time when high centered and mired in mud. That bumper always held up and was strong as an OX. I hope this expedition one bumper proves just as tough.
WOW!! its like your driving my truck! thats the same thing i would like to do except for all that badass storm chasing equipment. I prefer to curl up in in the fetal position in an underground bunker during tornadoes and the like.
Spend the money and do it right the first time!!!!
Nice truck it would be perfect for storm chasing but you would soon need a new wind shield for that ! I bet it would be fun to do some off roading in that thing
very cool truck...looks like the new mars rover...
Can you tell me some more about your research into the "Deaver 11 pack rear leafs " you list as a future refinement.
I have always thought it would be better to beef up the rear springs, instead of airbags, to increase the weight carrying capacity of these trucks.
Many Thanks
