Old 11-16-2008, 07:08 AM
mhollack's Avatar
Dealer : Rodland Toyota Scion
2008 Toyota Tundra SR5 DC TRD 5.7L 4x4,
- Other - 2004 Acura TSX
Last Online: Today 03:35 PM
Images: 28
mhollack will become famous soon enough. mhollack will become famous soon enough.
Send a message via AIM to mhollack Send a message via MSN to mhollack Send a message via Yahoo to mhollack mhollack's Photo Albums
Default Toyo 285/75/18 - follow ups?
I know a bunch of you guys are running this tire in an A/T, which is one Im seriously considering. Im getting ready to do the readylift 2.5" with a 1" rear block and trying to make up my mind between these and the bfg 305's. So for those that chose this tire, now that youve had them for awhile, any regrets? issues? concerns? Im assuming with my lift all I will have to do is trim the skid plate. I also plan on installing the hypertech speedo calibrator to maintain proper shift points and speedometer/odometer readings. Any feedback is greatly appreciated.
2008 SR5 DC 4WD 5.7L TRD Radiant Red/Black (HM,EC,EJ,OF,RL,V5,R9,CT,LineX)
CBTMA Member
TRD Sway Bar, TRD CAI, TRD Dual Exhaust, Billet Grille, CF Dash Kit, Westin Platinum 4" Oval Nerfs, Low Range Off-Road 3/1 Lift, Rancho RS9000XL's - rear, Wet Okole Seat Covers - Fr&Rr, Toyo Open Country A/T's - 285/75/18 (35's), ProComp 6098s 18x8.5 +19, Hypertech Speedo Calibrator, Lund Genesis Tri-fold Tonneau, OE BackUp Camera, OE Fender Flares, VLeds Interior, Kenwood DNX8120 w/HD Radio and Rear Monitor
Old 11-16-2008, 11:30 PM
mhollack's Avatar
Images: 28
Default Re: Toyo 285/75/18 - follow ups?
C'mon, where are you guys?
CBTMA Member
Old 11-16-2008, 11:45 PM
Dealer : Thousand Oaks Toyota
1999 Toyota Tacoma
Last Online: 12-08-2008 07:55 PM
ch4rlie is on a distinguished road.
ch4rlie's Photo Albums
You gotta get the BFG All-Terrain man, thats the only way to go...
Old 11-17-2008, 12:05 PM
Dealer : Gresham Toyota
2007 Toyota FJ Cruiser Voodoo Blue,
2002 Toyota Tundra Limited/supercharged,
2007 Toyota Tundra Crewmax ltd silver
Last Online: 09-29-2009 05:27 PM
moonjim is on a distinguished road.
moonjim's Photo Albums
I've had mine on for over a year and had them siped wich real helps on snow/ice and wet. Great in muddy/fire road situations. For the price and the durability I don't think they can be matched.
Old 11-17-2008, 04:00 PM
Dealer : Camelback Toyota Scion
Last Online: 04-09-2009 09:50 AM
Images: 4
RT8827 is on a distinguished road.
RT8827's Photo Albums
That's a 35-inch tire, so I'd think you'll need more than 2.4" front lift in order to clear them without rubbing.
Old 11-17-2008, 06:05 PM
Dealer : Teton Toyota
Last Online: 10-09-2009 03:42 PM
jaywebguy is on a distinguished road.
jaywebguy's Photo Albums
I have the Toyo 285/75/18s. All I have is a leveling kit up front. My truck goes in to get the oil changed next week and the dealership is going to trim the skid plate for me while it's there. Only complaint I have about the tires, is the drop in gas mileage, although I shouldn't complain about it, I knew bigger tires would make an impact. I've used the same tires in the past on other vehicles, they're good tires, plus in my case were almost 400 cheaper then the BFs.
Old 11-17-2008, 06:23 PM
Images: 4
Do you have any pics? Not that I don't believe you, because I do... but I'd like to see wheelwell gap & tire clearance.
A couple more questions, Jay...
Was there a noticeable drop in power/accelaration?
Have you checked to see how slow your speedometer reads? (I'll guess that it reads 63-64mph when you're actually going 70mph)
According to the specs on the Toyo website, this tire size is 35.1" tall... about 3" taller than our stock tires, and about 1/2" wider.
Old 11-17-2008, 06:27 PM
Dealer : Quality Toyota Scion
Last Online: 11-18-2008 11:39 AM
sausage39 is on a distinguished road.
sausage39's Photo Albums
I just put these tires on my truck a couple days ago.
They fit perfect with the ready lift 2.4" kit (which actually turned out to be around 2.75"). With the tires and lift, the front wheel well height increased by about 4 inches. (Sorry for the vague measurement, I have them all written down at home).
As for rubbing issues.... I had the skid plate bent up below the sway bar just to be safe and I removed the little mud flaps in front of the tires. There was only one incident of rubbing when I was at full left lock and on a wierd angle, however they touched just enough to make a bit of noise without any sort of damage. (Please don't hold me to this because I've only had them 3 days with limited driving time.)
The spacer made the ride a tad bit more firm, but i'm super picky and notice stupid things like that. On that note, the toyo's seem to feel much softer than the crappy BFG's that came with the TRD package and therefore even out any change in ride. They are also quieter on the freeway and around town than the old ones.
In my opinion these tires make the truck perfectly proportional and seem to be the best choice, especially considering the minimal increase in width.
Hope this helps.
BTW... It looks way better in person
Toyo 285/75/18 - follow ups?-s7300196.jpg
Old 11-17-2008, 06:46 PM
mhollack's Avatar
Images: 28
We are actually talking about the A/T's here, not the M/T's. The A/T's are 34.8 x 11.3. As for the speedo readouts without correction, youve got it backwards. The speedo will say 60 when youre actually going 65.2
CBTMA Member
Old 11-17-2008, 06:55 PM
Images: 4
Originally Posted by mhollack View Post
We are actually talking about the A/T's here, not the M/T's. The A/T's are 34.8 x 11.3. As for the speedo readoouts without correction, youve got it backwards. The speedo will say 60 when youre actually going 65.2
Thanks for the correction on A/T vs M/T specs.
However, I wasn't backwards on the speedo issue. I said that it likely reads 63-64mph when you're actually travelling 70mph. You said that it reads 60mph when you're actually going 65.2mph. We're saying the same thing... just at a different speed of travel.
Old 11-17-2008, 07:03 PM
mhollack's Avatar
Images: 28
Youre right, I had read yours wrong, sorry about that.
CBTMA Member
Old 11-17-2008, 08:12 PM
Dealer : Lewis Toyota Scion
Last Online: 08-09-2009 04:51 PM
disneydave is on a distinguished road.
disneydave's Photo Albums
Anything out there to correct the spedo and fix the shift points?
On my jeep I only had to replace a cheap plastic gear in the diff. and all was well.
Old 11-17-2008, 08:17 PM
Last Online: 06-28-2009 07:39 PM
klane2 is on a distinguished road.
klane2's Photo Albums
I have the 305 65 18 BFG's on Moto Metal 18" with a 3" lift on my 07 Tundra and the Toyo 285 65 18 AT on my Nissan and the Toyo's perform and wear much better. The BFG's are great off-road but unless you use your truck as a farm or hunting truck I would go with the Toyo's. That is the tire I am going to go with on my Tundra next.
Old 11-17-2008, 10:14 PM
mhollack's Avatar
Images: 28
yes, there is the hypertech speedometer calibrator
CBTMA Member
Old 11-17-2008, 10:19 PM
mhollack's Avatar
Images: 28
Thanks klane, thats the kind of feedback Im looking for. I know BFG's are good tires, but I see enough "bad" reviews about them on different tire websites to question what might be better. Since the toyos and bfg's Im looking at basically weigh the same, Im trying to decide to I go with more height in the toyos (as well as they fit the 18x8 trd rims better being a 285) or more width with the bfgs. Toyos are 34.8 x11.3, bfg's 33.7 x 12.2.
CBTMA Member
