This is a discussion thread titled "Somebody PLEASE explain.........", within the Tundra forum, part of the Truck Forums category.
Old 11-19-2008, 04:13 AM
Last Online: 12-06-2008 03:09 AM
JoeCastle is on a distinguished road.
JoeCastle's Photo Albums
Default Somebody PLEASE explain.........
Checked the owner's manual called the dealerships etc.... the 5.7 holds 7.4 quarts of oil. I'm cool with that but why does it read over the full mark after it sets for 10 or more minutes? I could understand if it was the 4.0 Tacoma that had the oil filter on top of the motor but everything is down low on the 5.7's. I'm hoping anybody hopefully everybody can give a answer that makes sense........ Please explain......
Old 11-19-2008, 08:02 AM
DanielAcosta's Avatar
Dealer : Earnhardt Toyota
Last Online: Yesterday 06:27 PM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: Somebody PLEASE explain.........
Maybe it's really over-filled? I've had 4 dealer oil changes and 2 independent shop oil changes, have yet to use any oil between 5K interval changes, and have never experienced the symptom you describe.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 35K miles, 17 mpg city after battery disconnect reset & removing extra (charcoal?) air filter. Truxedo Lo-Pro with deck rails.
Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), just swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5."
Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43."
Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper.
After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/18 or 35x12.50/18.
Added 5th 285/75/18 Toyo AT as spare. Foam pad above spare to help with bed bounce.
Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks and foam pad above spare. Still a stiff ride but tolerable now.
Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed.
Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
Old 11-19-2008, 11:15 AM
Dealer : Northside Toyota
Last Online: 01-04-2009 02:21 PM
wawagoosie is on a distinguished road.
wawagoosie's Photo Albums
Did you run the engine, it takes almost a quart to fill the filter, but the engine needs to run to pump the oil into the filter first.
Old 11-19-2008, 12:38 PM
Go Flames Go's Avatar
Dealer : Canyon Creek Toyota
Last Online: Today 04:45 PM
Go Flames Go is on a distinguished road.
Go Flames Go's Photo Albums
I did my own oil, toped up the oil to the middle of the operating range on the dip stick, started the truck let in trun for a 20 seconds. Checked the dip stick, could barely see the oil level. That filter holds a lot of oil.
I only did this becuase I was using 4 liter M1 jugs and didnt want to over fill it my first time. It does take the perscribed amount.
Old 11-19-2008, 01:16 PM
Negra's Avatar
Last Online: Today 05:02 PM
Negra is on a distinguished road.
Negra's Photo Albums
I run 8 Full US Qts in mine and its a hair over full.
What Band-Wagon You Riding ?
Old 11-19-2008, 01:22 PM
Dealer : Sunny King Toyota
Last Online: 01-03-2009 11:20 PM
bamadoc is on a distinguished road.
bamadoc's Photo Albums
I put 7 qts in mine every change and that keeps it between the marks.-Bamadoc
Old 11-19-2008, 07:36 PM
Senior Contributor
Last Online: Today 12:55 AM
Burger Steak & Eggs will become famous soon enough.
Burger Steak & Eggs's Photo Albums
I put seven liters in, leaves it just over the full mark. I found the rate at which the dipstick level rises is not very linear as you add oil. I wanted to get the level between the empty and full marks, so I added 6 liters and most of the seventh. It was in the middle of the range but towards the low side. Then I added the little left in the seventh liter and it shot just above the full mark.
Old 11-19-2008, 07:48 PM
Dealer : Avondale Toyota Scion
Last Online: Today 09:34 AM
LeeinAZ is on a distinguished road.
LeeinAZ's Photo Albums
It's a big engine and the top end has a lot of parts to lubricate, so there is a lot of oil there....mine has always done the same thing. Didn't have that happen with my 4 banger Honda.
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 11-19-2008, 08:13 PM
Dealer : Mike Calvert Toyota Scion
Last Online: Today 06:22 PM
choco is on a distinguished road.
choco's Photo Albums
Maybe the difference lies in the oil cooler. Do all 5.7 come with one?
Old 11-20-2008, 12:16 AM
jliltd's Avatar
Dealer : Las Cruces Toyota
2007 Toyota Tundra 4WD DCab Longbed 5.7,
2001 Toyota Sequoia (Wife's Broomstick)
Last Online: Today 01:20 PM
jliltd is on a distinguished road.
jliltd's Photo Albums
That's about right. 7 liters = 7.4 quarts.
"The beauty of the second amendment is that it will not be needed until they try to take it." -- Thomas Jefferson
Old 01-04-2009, 06:54 PM
Dealer : Mountain States Toyota
2007 Toyota Tundra DCSB 5.7L 4x4 SR5
Last Online: Today 07:36 PM
VX_R-V8 is on a distinguished road.
VX_R-V8's Photo Albums
OOPS.. I did an oil change today and put 7.4L (7.8qts).. it read a little over full.. is this a problem? Secondly (not intending to go off subject) but i use Kofran Racing Synthetic oil if anyone's heard of it.. anyways its SJ-10W60! Comments??
Old 01-04-2009, 07:53 PM
Only Toyota for me's Avatar
Dealer : Karl Malone Toyota
2008 Scion tC Daughter's car
Last Online: Today 01:05 AM
Only Toyota for me is on a distinguished road.
No, no problem at all. I put in 8 qts every OCI and it's just above the full mark.
After the truck has been sitting for 10 minutes like you say, you must pull the dipstick, wipe it off, reinsert and then get an accurate reading. You should do this when checking the level while the engine is cold as well.
Old 01-04-2009, 08:20 PM
jkd jkd is offline
Dealer : Prestige Toyota
Last Online: Today 02:49 PM
jkd is on a distinguished road.
jkd's Photo Albums
Right, this has come up a few times. The 5.7's retain excess oil in the dipstick tube, even overnite. Like "Only" says, pull the stick, the oil in the tube drains down, wipe the stick, recheck and you'll get an accurate reading.
http://sports.webshots.com/album/180135797kNEIOu
2007 LTD DC Blue Streak (her's)
2007 LTD DC Salsa Red (his)
'91 F250 5spd diesel with ATS Turbo
Old 01-04-2009, 08:32 PM
MissileTech's Avatar
Dealer : Keith Pierson Toyota Scion
Last Online: Today 01:47 PM
MissileTech is on a distinguished road.
MissileTech's Photo Albums
You never get all of the oil out of the engine. There is always some hung up in the rocker valley of the heads. I would just put seven quarts of oil in after the change, run the engine to fill the oil filter and check it later and add what is necessary.
Just Another Day In Paradise!
Old 01-05-2009, 05:53 PM
- Other -
Last Online: 01-06-2009 08:11 PM
daviszr1 is on a distinguished road.
daviszr1's Photo Albums
It has nothing to do with oil being retained in the dip stick tube. It has everything to do with surface tension of the oil. With the dip stick in the tube, there is a pile of surface area for the oil to come into contact. The synthetic and synthetic oil blends have a significantly higher surface tension than the older dino oils. The dip stick tube arrangement creates the perfect environment for capillary creap, a biproduct of surface tension and surface area. You can read all about this on BITOG.
I have the same "problem" in my 'vette, my wife's Maxima, and my older 4Runner after I switched to a synthetic blend. It's totally expected.
Bookmarks
