Does anyone know what wires to tap into for the rear break light on a truck cap/canopy for the 3rd break light? I've been searching for 15 minutes with no luck.
Thanks
Thanks
Here is the wiring diagram for the brake lights:
http://www.tundrasolutions.com/forum...top-lights.pdf
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors
Scangauge II
Cooper Discoverer ATR's
Techstream
CBTMA member
aip override 1.1.pdf
Block Off Plate
The best way to do it is capture the wires that go to the light on the back of the cab. You can get to them under the driver's side door sill. The bed light is brown, the stop light is red, and the ground is black & white. The wires at the back are both brake and turn signal, so they won't do what you want. I have a double cab, so I mounted a switch under the back seat to switch between the cab and cap.
Toyota SS steps
ARE MX cap
AMP bed step
Scangauge II
Techstream
CBTMA member
Block Off Plate
