ABS Light On, VSC Flashing, TC Light on, Brake Lights on. SNOW SNOW SNOW. Read on.
Ok, here is the situation.. I was in very VERY deep snow Yesterday. I do have a plow and I did plow a lot yesterday.. BUT I also just DROVE through very deep snow for many miles (5-6 Miles).. 18-22" deep EASILY. Anyways....
I drove about 10 miles on decent road (not much snow)... and my ABS Light came on, my Traction Control Light came on, my VSC Light was flashing... I didn't know it until I got home (about 2 hours later)... But my brake lights were staying on the entire time I was driving. My garage is not heated.. but I pulled it in there.. I had to disconnect my battery so it wouldn't die (I charged it also)...
I called the dealer - they said I could adjust the brake switch (and when I PULL the brake light the brake light goes out). They said to try to take it to a car wash also..
ANYWAYS - has anyone else ever had this problem? Any suggestions? I have to get out plowing like 5 hours ago (I'm missing on $$$)... I'm about to just drive it as is because I'm missing $100/hr.
Re: ABS Light On, VSC Flashing, TC Light on, Brake Lights on. SNOW SNOW SNOW. Read on
Check under the vehicle to make sure non of the wire for the sensors were pulled or disconnected as a result of driving on a deep snow. Wheel speed sensor wires on each wheel particularly.
I would suspect one of the wheel sensor wires got unplugged or damaged. The ABS thinks one wheel is not turning.
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors CBTMA member
Very interesting thread. this happened to my subaru a couple years back cause of driving in snow for hours too, but when it warmed up, and i did a battery reset it went away. Why didn't toyota make our tundras hermetically sealed up to 30 tinches like they did with the FJ? Probably the same reason they didn't put a true locker in the rear also. Sometimes Toyota make me pretty upset!!!
Anways, let us know the cause, and I hope it's nothing too serious. I'm betting it's not serious.
07 Crewmax 4x4 TRD SR5. Intake, exhaust, full 20% tint. 2"F 1" rear leveling kit installed.
Soon to come... 285/65/18 Hankook DynaPro ATM
Quickest 1/4 mile at a track 14.9
Quickest GTech time 14.67
I just plowed my drive and no lights came on (good news).. but my brake light is still on. IF I pull back on the brake pedal, the light does go out... Hoping that the pedal ajustment is easy... Wish it was warmer to check insetead of 14 Degrees.
Lights came back on. I did clean it at a car wash and drove it about 15 miles.. the lights are staying off. It appears they are all connected. my brake light deal is the wiring harness below the dash.. it apprears the wires are lose and just jarred around. I got the lights to stop staying on.
I just logged on to report the same exact thing. my dash was like my christmas tree. abs, vcs flashing ,4wd hi and low flashing ,brake light solid . I shut the truck down and everything cleared but the abs light . my was fine untill i spun alittle getting in my driveway. we have had about 2 feet of snow and i've been plowing. no trouble at all until i spun . i have been driving clean and clear roads since sunday afternoon
Originally Posted by rockstate45
Same thing happened to me but my 4wd light came no as well.
I turned the truck off and then turned it back on - all lights cleared themselves BUT the solid ABS light, which did clear itself after a little bit of driving.
-rockstate
Let me guess. You were in LSD mode when this happened?
My dealer says it's "normal". I think they are full of ****, and will be knocking on their door when I reproduce it. 40K truck, I'll be damned if I can't drive in LSD mode whenever I want and not have the truck get "confused".
2008 5.7L DC Limited TRD / Slate Metallic with Grey Leather interior / fully de-badged --- 19.2mpg over 450 miles averaging 57mph!
allot of times wires come loose as stated above or ice/snow buildup jams up the brakes and sensors. I have gotten misc. road debris lodged in the calipers as the snow gets pushed around and melts. Generally, I think the super cold situations reak havok on the fluids and sensors. Hope it all works after the bath!
Busted speed sensor wire=$65
Replace speed sensor=$250.
Did both and it was easy to fix, but wasn't cheap. My truck had all the warning lights when accidentally I pulled the wires out of my speed sensor plug installing on the front suspension. So, I waited a while to buy the wiring. Got it and went to install it and noticed some lain brain tried to force the plug in at a earlier time and bent one of the wires in the speed sensor. They are so delicate I could not straighten it out and it broke. So,I bought a speed sensor. Put it all in and all but the ABS light went out immediately. After a few minutes the ABS light went out.
Hope nothing got torn out. If not, it should work itself out. A little warmth, a little TLC, a little celaning and checking should make all the difference in the world. Good luck.
07 2wd SR5CM with 5.7 with some stuff done to it.
-rockstate
Ditto what Rockstate said above. It happened to me after driving in 30"+ snow on the street in front of my house. The temperature was also below 0F. It worked fine the next day and ABS light stayed on for a bit then turned off.
