Old 12-30-2008, 09:28 PM
PowerHogger's Avatar
Dealer : Fred Haas Toyota Country
Last Online: Today 12:56 PM
Images: 8
PowerHogger is on a distinguished road.
PowerHogger's Photo Albums
Default Transmission leak
Hi everyone im a long time reader, first time poster! I finally got a 5.7 RCSB tundra used with 10K miles for 17,500 dollars which i though was a good deal. So i drove it home from the dealership and i am amazed by the power of this vehicle and how fast it accelerates. It was just incredible until the next morning where i backed out and saw a large oil smudge on the ground. I s**t my pants and parked the car back into the driveway. After cleaning the seats and spraying lysol in the car i went under the truck. I found out that the part that was connecting the driveshaft to the transmission had a very small crack in it and sprayed a red oil all over the place( I think its transmission fluid) it was also dripping on the floor. I have contacted the dealer about this and i am bringing the car in to get it fixed. Has anyone else had this problem? Or am i just unlucky for buying a used vehicle.
Old 12-30-2008, 09:36 PM
Dealer : Bryan Easler Toyota
Last Online: 10-15-2009 10:10 PM
Images: 3
Psychosis is on a distinguished road.
Psychosis's Photo Albums
Default Re: Transmission leak
Is it a car or a truck?
Sounds like you enjoyed it too much on the way home with it. Nah, just picking. Was it the metal part of the tail of the tranny that had a crack in it or was it a seal? They should be able to fix you up at the dealer. Good luck
Oh and I haven't heard of that problem yet myself.
2007 Tundra Crewmax SR5 4x4, Silver Sky Metallic, 5.7L, Enkei 18" alloys, BFG Rugged Trail AT 275/65/18, 40/20/40 front bench, cold kit, deck rails, heated/power mirrors, Line-X bed spray, Access Literider Rollup cover, Yaesu ft-7100, Mobile1 5w-20, AVS ventvisors, Auto lock/unlock tailgate, Tundra step boards.
Old 12-30-2008, 09:46 PM
Images: 8
Im not sure just the part where the driveshaft is connected to, right behind the tranny
Old 12-30-2008, 09:52 PM
Dealer : Avondale Toyota Scion
Last Online: Yesterday 10:27 PM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
There is a TSB about your problem. The number is TC016-07, Title: TRANSMISSION FLUID LEAK THROUGH
DRIVESHAFT YOKE
It will require replacing the driveshaft.
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 12-30-2008, 10:00 PM
Images: 8
DRIVESHAFT YOKE
should i tell the fellas at the dealership this?
Old 12-30-2008, 10:12 PM
Yes, but they should be aware of it. Just give them the TSB number and title. Then have them check other TSB's that relate to your vehicle, like the one for the tailgate latch as an example. The should be able to check and see if any have been complied with by checking your VIN number. Unless you have an extended Toyota warranty, most TSB's will expire when you reach 36,000 miles.
Also, make sure they check your transmission fluid level when they are finished replacing your driveshaft. It's hard to say how much fluid leaked out because there is no transmission dipstick.
Old 12-30-2008, 10:32 PM
Here is a link to the TSB:
http://www.tundrasolutions.com/forum...-yoke-leak.pdf
Old 12-31-2008, 02:34 PM
Images: 8
I took the tundra in this morning and after five hours they gave me a call and said they were going to have to replace the whole driveshaft. The guy also said they have a driveshaft in stock but they were going to have to order it. What does that mean? So how long you guys think it will take before i can drive my Tundra again because i have no idea. Thanks in advance.
Old 12-31-2008, 02:50 PM
Machine's Avatar
Dealer : Lombard Toyota
Last Online: 11-06-2009 04:34 PM
Images: 11
Machine is on a distinguished road.
Send a message via AIM to Machine Machine's Photo Albums
It probably means that it is in a nearby warehouse, but not onsite. No more than a day to get it in, I would expect, but don't forget it is a holiday.
2008 White Tundra DoubleCab 5.7L TRD 4x4 w/Extang Solid Fold Tonneau
2009 Jeep Wrangler Rubicon
Old 12-31-2008, 07:59 PM
Dealer : Autoway Toyota
Last Online: 10-08-2009 09:45 PM
fla_guy is on a distinguished road.
fla_guy's Photo Albums
Once the driveshaft is in to the dealer, they will have it done in 4 hours or so.
2007 Tundra DC TRD 4x4
Pyrite Mica
Bucket Seats
Cold Kit
Deck Rails
Tow Mirrors
Door sill protectors
