Old 02-20-2009, 08:18 PM
RONE's Avatar
Dealer : Little Apple Toyota
2008 Toyota Tundra 5.7L SR5 4x4 DC
Last Online: Today 11:27 AM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
Default How To Install Rear Swaybar:
This is for the TRD rear swaybar (I assume the others are pretty similar). The directions TRD includes are excellent (probably the best I've ever received with an aftermarket part), so pretty much I'm just including labeled pictures to help you guys find your way. Here you go!
Tools needed: 22mm socket, 19mm socket, ratchet, torque wrench (up to 85 ft-lbs)
Parts needed: you'll probably have to go to a parts store and get 2 new bolts or 2 new nuts (the 2 bolts and 2 nuts they give you for connecting the rearlinks to the swaybar aren't the same thread count)
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
This is the driver's side. The endlink goes on the outside of the swaybar:
Click for full size
Be sure and take note of which side of the brake bracket the U-bolt goes on (driver's and passenger's sides are different):
Click for full size
Click for full size
Click for full size
Old 02-20-2009, 08:48 PM
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 04:46 PM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Default Re: How To Install Rear Swaybar:
Great stuff!
Where have you been 5 month ago?
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
Old 02-20-2009, 09:01 PM
RONE's Avatar
RONE's Photo Albums
Originally Posted by zpaul View Post
Great stuff!
Haha, sorry, I'm a little slow.
Old 02-20-2009, 09:04 PM
Tundradrenalin's Avatar
Assistant Administrator
Last Online: Today 09:35 AM
Images: 205
Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family. Tundradrenalin is part of the TundraSolutions family.
Nice write-up DIY, adding to the sticky!
Many rep points to ya
Under the Hood: AMSOIL Synthetic Lubes all around, AMSOIL Ea Air Filter, Doug Thorley Headers, Magnaflow Exhaust, Semi-RAMair airbox mod
Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear]
Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES
Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion
Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead
Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
Old 02-20-2009, 09:08 PM
dariusld's Avatar
Dealer : Toyota of Chula Vista
Last Online: Today 01:34 PM
Images: 31
dariusld is on a distinguished road.
dariusld's Photo Albums
What causes some to hang lower? In this thread they vary in height.
Black Widow TRD Sway Bar
Old 02-20-2009, 09:10 PM
ATEC's Avatar
Dealer : Hertrich Toyota of Milford
2007 Toyota Tundra DC Blue Streak SR5
Last Online: 11-15-2009 07:48 PM
Images: 5
ATEC is on a distinguished road.
ATEC's Photo Albums
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Click for full size
Well I wonder if they changed Install PDF. My trd bar came with washers to install on sway bar end link Seventh picture down. Same pick as your but additional washers. Did you have any washers Left over. And I had no problem with Bolt threads . I try to get a picture posted. This weekend.
Old 02-20-2009, 09:18 PM
zpaul's Avatar
Images: 45
I had some leftover washers, so I added them like you said. But PDF that came with sway bar did not require it. And I had to buy 2 new bolts at ACE hardware store.
Old 02-20-2009, 09:28 PM
ATEC's Avatar
Images: 5
ATEC's Photo Albums
Well it makes sence to install the two additional washers on bushings. The top bushing are closed on both sides with washers , then spacer. So i did the same two lower bushings.
But I do have to check mine for position of C Clamps. I THOUGHT it said to center bushing with center of sway bar. If so I am on inside of the drivers side bracket. Not outside. Rone did a nice write up with pics. I am going to have to check the clamp placement in morning.
Old 02-20-2009, 09:41 PM
Dealer : Sun Toyota Scion
Last Online: 06-28-2009 04:08 PM
Dusty Raptor is on a distinguished road.
Dusty Raptor's Photo Albums
The extra washers are for tundras without the hitch.
No hitch, then add washers between the upper end link spacer and the frame.
Like this:
That accounts for two (out of the four) "extra washers".
The other two are supposed to go between the nut and the anti-sway bar (on the lower end link).
This isn't noted in the installation manual
Like this:
The above pics also identify the speed sensor line brackets as being brake brackets.
Old 02-20-2009, 09:57 PM
ATEC's Avatar
Images: 5
ATEC's Photo Albums
Originally Posted by Dusty Raptor View Post
The extra washers are for tundras without the hitch. No hitch, then add washers between the upper end link spacer and the frame.
http://img.skitch.com/20090221-cii1p...3d.preview.jpg
That accounts for two out (of the four) "extra washers".
The other two are supposed to go between the nut and and the anti-sway bar. This isn't noted in the installation manual
http://img.skitch.com/20090221-rk7qm...5a.preview.jpg
Dam ...How can something so simple be so screwed up. Well looks like I got the bottom washers right that where not listed. But put on a extra top washer that was not needed because I do have the hitch. O well ..I am going to leave it on , I dont see how it could make that much of a difference.
Thanks For info.
Old 02-20-2009, 11:03 PM
slackjaw07's Avatar
Last Online: Today 01:09 PM
slackjaw07 will become famous soon enough. slackjaw07 will become famous soon enough.
slackjaw07's Photo Albums
I think that's an optical illusion caused by the different angles and distance the photos are being taken from.
2007 Toyota Tundra CrewMax SR5 5.7L w/ TRD Package, Blue Streak Metallic/Graphite, FormulaOne Pinnacle Ceramic Tint (15%), auto-dimming mirror, Line-X Bedliner (under the rail), RS3200 alarm/GBS/hood switch, brushed stainless steel running boards, bed extender, door sill protectors, TRD rear sway bar, TRD CAI, Corsa Touring exhaust.
"Never underestimate how much people are willing to spend on their kids, their pets or their trucks!"
Old 02-21-2009, 09:48 AM
Dealer : Tejas Toyota
Last Online: Today 09:00 AM
EVOL ARDNUT is on a distinguished road.
EVOL ARDNUT's Photo Albums
I was driving behind a red DC 07 with TRD ANTISWAYBAR AND THE THING LOOKED LIKE IT HUNG way too low and away from differential, looked goofy IMO!
Also what size bolts did you ask for exactly at parts store that would fit correctly?
HELWIG LOOKS LIKE A TIGHTER AND BEEFIER FIT, BUT I DON'T KNOW ABOUT QUALITY OF COMPONENTS?
This write up WAS GREAT AND I THANK YOU FOR CLARITY, especially about where to place those extra washers is great if/when I decide to put bar on my crewmax!!
Old 02-21-2009, 09:51 AM
I am sure that torque specs are in manual, do you feel they are correct for installation??
Old 02-21-2009, 10:38 AM
shooter2jim's Avatar
Slowpoke
1996 Toyota 4Runner,
2007 Toyota Tundra DCLB 4x4 5.7L
Last Online: Yesterday 11:59 PM
shooter2jim will become famous soon enough.
shooter2jim's Photo Albums My eBay
Rone, I would trash the bolts you bought and purchase "hardened" bolts like the ones supplied. Or purchase the correct hardened lock nuts to fit the hardened bolts they supplied. It may not make a difference, but I'm sure there's a reason they supplied the hardened pieces instead of plain stainless or zinc coated steel. I decided to purchase washers to put between upper end link spacers and the hitch (frame).... and spray the bar black. Other than that, everything was complete in my kit. Great write up! What software did you use to add the arrows and text?
Evol- the torque specs are supplied in the sway bar instructions and seem correct. If I remember, they give you a pretty good leeway on the end link bolts- something like 45 ft-lb +/- 12ft-lb. Don't remember the U-bolt specs off the top of my head. The upper link bolt-to-frame spec is 90 ftlb. I would highly recommend an impact wrench on the frame bolt unless you plan on removing the tire and SAFELY supporting the vehicle to tighten the bolt. It's a little difficult to get in a position to manually torque that thing to 90, especially on the tailpipe side.
Old 02-21-2009, 10:39 AM
RONE's Avatar
RONE's Photo Albums
The swaybar doesn't really hand down any more than the rear differential. It's closer to the rear of the truck than the diff, so that's probably why it looked lower.
I picked up 2 new bolts at Home Depot because they didn't have any nuts that fit the TRD-included bolts. I think they were M12x1.75x70mm, but if you bring the bolts or nuts in with you they can match them for you.
torque specs are in the included directions. 84 lb-ft for the endlink-to-frame bolts and 48 lb-ft for the endlink-to-sway bar bolts and for the U-bolt nuts. Seemed okay to me.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/158331-how-to-install-rear-swaybar/
Posted By For Type Date
Beat the Heat Lawn Service 2009 - Page 60 - LawnSite.com™ - Lawn Care & Landscaping Business Forum Powered by Moose River Media This thread Refback 10-11-2009 01:04 PM
