Re: How-To Source on Basic Wiring and Installing LEDs
It's hard to really point to a single source. I would say start with Googling "Ohm's Law" to learn about the voltage, current, resistance relationship. Then try wikipedia for some info on LEDs and their basic characteristics. You will find LEDs need very low current to operate or they will burn, they also come in different voltage requirements. Using Ohm's law, you will understand how to limit the current these LEDs get using resistors. When you get all the basic info you need, you can look at this site: How to Wire/Connect LED's for some info on wiring series versus parallel.
Also, do a google search on "Voltage Regulator" in case you want to say, turn your 12V battery source into a regulated 5V source to use LEDs a little easier then using resistor networks.
2008 Tundra CM, 5.7L V8 4x4, OME HD Lift, 18" KMC XD Hoss in Black, 305 65 18 BFG AT/KO's, Black Headlight Mod, Weather Techs, Optima Yellow Top Battery, Iron Bull Winch Bumper, 4x KC Off Road Lights, Milemarker SI12000 winch, loaded Garmin 60Csx to get lost with! - Coming Soon: Rock Sliders, Custom Made Hi-lift holder - Future Mods: ARB Air Locker, Rear bumper with removable spare tire carrier
