Old 03-16-2009, 10:06 AM
joeyman15's Avatar
Dealer : Keith Pierson Toyota Scion
2006 Toyota Tacoma,
2008 Toyota Tundra SR-5
Last Online: 11-21-2009 03:58 AM
joeyman15 is on a distinguished road.
joeyman15's Photo Albums
Default Using Coolant
When i changed the oil for the first time(4000 miles) my coolant was at the low mark, so i fill it up.
I just changed my air filter at 12,000 miles and i saw that my coolant was at the low mark.
Is it normal to use some coolant as the miles go by, or do i have a problem. I've never seen any leaking on the ground and can't smell it.
Old 03-16-2009, 10:26 AM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Default Re: Using Coolant
Low Engine Coolant
Beer please!
Old 03-16-2009, 10:34 AM
basetundra's Avatar
Dealer : Toyotatown
Last Online: 08-12-2009 12:30 AM
basetundra is on a distinguished road.
basetundra's Photo Albums
Mine was at the low mark (cold) when I got it new, and it's still at the same level now.
Old 03-16-2009, 12:32 PM
cwit's Avatar
Dealer : New Country Toyota
2007 Toyota Tundra,
2006 Toyota Camry-Solara black moon roof
Last Online: Today 12:31 PM
Images: 3
cwit is on a distinguished road.
cwit's Photo Albums My eBay
That should be the cold level and the high one is the hot level , it may pump it out the over flow if the level is to high.
Charlie & Linda
Old 03-16-2009, 06:22 PM
Dealer : Avondale Toyota Scion
Last Online: Today 11:33 AM
LeeinAZ will become famous soon enough.
LeeinAZ's Photo Albums
Mine had a slight coolant leak when new. There is an engine block drain petcock on the right side of the block and mine was leaking. It was slow enough that it never made the floor wet. It dripped down on the skid plate and evaporated while driving. I first noticed it when I did my first oil change and dropped the skid plate. If you look over the top of the right front wheel after lifting the rubber splash guards, and using a flashlight, you should be able to locate the petcock. It is about in the middle of the block beneath the exhaust manifold. If it is leaking it will also show up on the skid plate.
'07 Tundra SR5, 2WD DC, 5.7L, Salsa Red Pearl with Running Boards, Delta Toolbox.
Old 03-16-2009, 06:46 PM
Dealer : Al Hendrickson Toyota
2005 Toyota Tundra
Last Online: Today 04:35 PM
GORILLA is a splendid one to behold. GORILLA is a splendid one to behold.
GORILLA's Photo Albums
hi although i have a 4.7 2005. i have never ever needed any coolant.
it has been at the top and my res. has stayed the same since new. now i used to have a temp of 188degree's. i bought a additive that was suppose to lower the temp up to 20%. but it didn't. but what it did do is lower it to 184, and at it's highest so far 186.
i think it cost me 10. i don't know why or how it work's, but it did lower it a little.
but i never lost any. it isn't suppose to evaporate, or loose any ,unless there is a leak. you might find the leak by using a black light.
let the dealership know, they can pressure test it, BUT PLEASE have them be very careful. i have known some people that have had there's tested & they popped the radiator, hose, etc. due to them pumping way to much air pressure into the radiator cap.
good luck,
gorilla
