Kewl man... glad it worked(or appears to)... and don't blame you for being sketical... LOL..silly fix for such a silly problem... It might just be a HomeLink mirror thing... dunno
You have no idea how anal I am about shitts shuffling around in any of my rigs... I get so irritated, that I can barley see straight, and more than often have to pull over in a rage to locate and rid of the noises...
I think I can appreciate how anal you are about these things because I am the same way. I can't let it go until I have it beat. It's a character flaw, what can I say. Thanks again for fix.. That was driving me nuts.
2008 CrewMax LTD
VAIS Technology IPOD Integration
Extang Trifecta Signature Series Cover
Tundra All Weather Mats
8" Kicker Sub in factory enclosure
WhiteThunder
I'm starting to get a very annoying creak (or more like a rattle) coming from the driver side of the dash near the windshield. It doesn't do it all the time and I'm still trying to find a pattern as to when it happens. The TSB only refers to the passenger side.
Ya, the TSB only states the passenger side, but the clip they use on the driver's side is the same part # as the one on the passenger side. So if it failed on the passenger side, it stands to reason it will fail on the driver's side as well.
The new ones are noticeably different, and are angled upwards more and are thicker. Just go and order one (or two). they are only $5ea.
I know where you're coming from. To have to spend 28K on up for a vehicle that creaks and rattles is ridiculous. I have had to go back twice now for my 07' tundra sr5 double cab and have the front plastic cowling on the outside of my truck below the wipers replaced since the last 2 winters during cold outside, the plastic whole length of the cowling would creak and pop continously over bumps. They had to replace the cowling, install better clips supposedly, and installed double sided tape between the plastic cowling touching the windshield due to vibration causing popping noises. It only does the same popping noise ONLY a few times driving it now, but still is not 100% fixed, but better than it was when it would pop over every bump in the road which was driving me nuts. Time will tell after this next winter after my warranty is up if it acts up worse again. I read somewhere else that the retaining clips holding the windshield in place had to be cut off with hacksaw since they were making that same creaking/popping noise I am having on occasion and am considering to go back and ask them about this also.
I always have the stereo up so I never hear anything besides music.
I turn my stereo up and all i hear is my overhead consoles creaking and making all kinds of noises i hate it. I have to leave them down if i wanna play my stuff loud.
08 CM 5.7L Super White
MODs.
Magnaflow duals H-PIPE
AFE CAI Stage 2
TRD Sway Bar
Boss 329 22's
Black Headlight MOD
its the only complaint i have bout the truck! been to the dealer 4 times for dash creak still no fix! mine is temp related to. creaks alot more with 22's on it. next step, drive with no dash! wheels are staying!
I had a little popping noise next to the little plastic triangle connecting the drivers window, door and column. The plastic crease would rub, so I put a drop of crazy glue on it and that stopped it.
BUT my dash rattle (somewhere in the middle of the dash near the NAV I think) is NOT the mirror cover and it isn't temp dependent. It's driving me nuts.
'07 Pyrite Mica Tundra Doublecab SR5 5.7 4x4 TRD w/ NAV, Total Chaos shackles, Bilstein 5100s on lowest setting, 275/70/18 E Michelin LTX AT2
'02 Landcruiser
I noticed the same exact creak the day I bought my 08 CM. I was freaking out thinking it was the nav unit. I had my wife listen for it while I drove and come to find out it was the mirror also. Easy Fix.
You really need to go drive a GM vehicle to know what creaks and squawks are.
I cannot agree more!!!
My 03 Silvy was rediculous.... everything creaked... grabbing the door handle to shut the door... driving over un-even surfaces made the dash front panel's snaps nearly pop out...x10 worse on cold days... hell, even turning the steering wheel made the column creak...
It could be different on the new body style, but this Tundra is x100 better in both hot and cold... Other than my right knee occasionally hitting the dash and creating a creak, my truck is creak free..
I thought the creak was coming from behind my nav too but it wasn't it was the top wire cover for the homelink mirror. Merely pushing it in did not do the trick, it did initially but it kept on creaking again. I bought some weather stripping, cut a small piece and put it in the inside of the top cover. Problem solved.
2008 CrewMax LTD
WhiteThunder
