  #46 (permalink)
Old 06-02-2009, 09:19 AM
Negra's Avatar
Last Online: Today 09:04 AM
Negra is a splendid one to behold. Negra is a splendid one to behold. Negra is a splendid one to behold.
Negra's Photo Albums
Default Re: Project traction
Is there a chance the ECM from a Sequoia will work ?
Local Toyo Tech seems to think the mapping is very simular to the Tundra.
He has been advised and should be watching this thread by now ?
I care not who defended our freedom in the past, who defends it tommorrow is who means the world today.
The trouble with the world is not that people know too little, but that they know so many things that ain't so
- Mark Twain
  #47 (permalink)
Old 06-02-2009, 11:37 AM
Dealer : Jackson's Toyota
Last Online: 11-18-2009 11:13 AM
Bertsonsracing is on a distinguished road.
Bertsonsracing's Photo Albums
Could you pelase put a sticky on this tread?
07 TUNDRA SR5 4x4 5.7 DCLB
-Solid Fold Cover -Tow Mirrors -Fog Lights -Roof Markers -Tint all Around -Toyo AT 275/65R18
-Thule XSPORTER RACk -Thule 18lt CARGO BOX
  #48 (permalink)
Old 06-02-2009, 03:14 PM
Jowett Engineering's Avatar
Preferred Dealer
Dealer : K-M Toyota
Last Online: Today 07:45 AM
Images: 10
Jowett Engineering has blessed us with their presence. Jowett Engineering has blessed us with their presence. Jowett Engineering has blessed us with their presence. Jowett Engineering has blessed us with their presence.
Jowett Engineering's Photo Albums
As things stand now, the truck thinks it is in 2WD, power is flowing to the front w/o issue. There are differences between the the actuators, which I will get more into depth with as the project is completed. For now I will say that although the connectors will plug in, those differences won't allow things to operate properly... again, more as this develops.
The Seqouia t-case and ecu may well be a better (easier?) swap if the center diff lock button can be added and a few other things are in place, such as the same ecu harness connectors matching etc.
The LX case is the same as the 200, my case actually came from a LX570. Toyota doesn't sell many 200/570 vehicles, but there should be enough that they'll start showing up in yards. The $2700 price for a new case is not outrageous when you factor in the sale of the stocker and such.
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
  #49 (permalink)
Old 06-03-2009, 02:08 PM
Could the internals be changed from one case to the other? Meaning could some go out anb buy the TORSEN from a Sequoia / LX750/200 and put it in the Tundra Case?
  #50 (permalink)
Old 06-03-2009, 04:13 PM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
The cases have the same dimensions, things from one case should fit the other. There are bound to be many internal parts differences, and I doubt you could buy just the Torsen and throw it in there. Input shaft, output shaft, shift forks... what is the same and what is different? I have a feeling by the time you get done it may well be cheaper to buy a whole case. Also do note that Toyota added a large amount of cooling fins to the 200 case. Running that front drive chain constantly creates significant heat.
Brian
Jowett Engineering
  #51 (permalink)
Old 06-05-2009, 07:48 PM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
This swap is now 99% (I say 99% because I'm still curious what will happen when significant wheel spin happens up front) To reiterate, the truck is AWD when the dial switch is set to the 2WD position, 4WD on the dial locks the center diff, and 4 Lo is still 4 Lo.
The physical changes made to incorporate this case into the Tundra include swapping the rear output flange, swapping some parts from the Tundra transfer case 2WD - 4WD actuator into the Land Cruiser AWD - CDL actuator.... and last are some simple mods to the front differential disconnect actuator that allows it to function while keeping the fork that locks the coupling sleeve to remain in the locked position. No wires or ecu's need to be bothered with.
Exactly one custom part is required, that is a small spacer that holds the front diff actuator shift fork in the locked position on the shaft which it normally slides on. Over the weekend I will snap some pictures and write up some basic instructions on the mods required.
The truck is an absolute blast now... the street manners are much improved in normal driving with the front end pulling a bit. Recomended....
Brian
Jowett Engineering
  #52 (permalink)
Old 06-05-2009, 08:48 PM
zpaul's Avatar
Dealer : Timonium Toyota
2007 Toyota Tundra CM Ltd
Last Online: Today 08:15 AM
Images: 45
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
What a cool stuff.
Now I miss having 4wd for sure!
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
  #53 (permalink)
Old 06-05-2009, 09:32 PM
Gutz's Avatar
Diplomacy is dead!!!
Dealer : Fletcher Jones Toyota
2007 Toyota Tundra 5.7 RC/SB
Last Online: Today 12:40 AM
Images: 15
Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything. Gutz has done just about everything.
Gutz's Photo Albums
As soon as you get a parts list together and have all the kinks worked out.....I am toyally doing this. AWESOME JOB!
iF57 Tundra Racing Club
  #54 (permalink)
Old 06-05-2009, 10:14 PM
Dealer : Universal Toyota
2007 Toyota Tundra Black Sport RCSB
Last Online: 11-19-2009 10:37 PM
Images: 19
Austin Aggie is on a distinguished road.
Austin Aggie's Photo Albums
Gutz,
He started with a 4WD truck. I think yours is a 2WD, if I remember correctly. I don't think it can be done with a 2WD truck making it AWD.
  #55 (permalink)
Old 06-06-2009, 02:34 AM
Dealer : Fremont Toyota
Last Online: 10-10-2009 10:27 AM
Images: 7
sofix is on a distinguished road.
sofix's Photo Albums
Nice cant wait to see some pics and mpg
  #56 (permalink)
Old 06-06-2009, 04:57 AM
Last Online: 10-21-2009 09:47 PM
rangerbrown is on a distinguished road.
rangerbrown's Photo Albums
going to awd from 2wd is easy, i have done two fords although not the same brand/truck the idea is simple
the edge ranger was 2wd but had the same set up as the v8 exploder just swap the awd diff then trans fer case and parts and done.
i would think that with the tundra if the 2wd truck was to see that a front wheel was spinning faster than say a rear it would start the vsc (or what ever it called) to control the wheel spin or reduce power, but as long as the front and rear diffs have the same ratio you should be fine. how ever if you wanted 4 lo or to lock the case you would have to figure a way to wire it. that could (but is not known to me) be as simple as just installing the switches (wiring as well) and sending power to the unit in the case, how ever that ecm would never see it. vsc would not turn off you would have to do that manually i would think.
this is just my opinion but until some one trys theres no need to say it can work.
  #57 (permalink)
Old 06-08-2009, 04:08 PM
CACressida's Avatar
Dealer : Modesto Toyota World
2007 Toyota FJ Cruiser,
2006 Toyota Corolla CE with 17s,
2002 Toyota 4Runner Sport 215,000 Miles,
- Other - 91Cressida M/T Turbo,
1995 Toyota Supra 89 Single Turbo
Last Online: Yesterday 04:25 AM
CACressida is on a distinguished road.
CACressida's Photo Albums
Very Very cool!!
2010 International ProStar 13spd, 06 Corolla CE, 02 4Runner SE 4x4 A/T
1991 Toyota Cressida 5spd M/T Turbo Charged
Originally Posted by MT Groove View Post
Nitrous is like a hot chick with an STD. You want to hit it, but you fear the consequences.
  #58 (permalink)
Old 06-08-2009, 05:51 PM
ChitownTundra's Avatar
Dealer : Mark Toyota
2007 Toyota Tundra,
2008 Toyota Tacoma
Last Online: 11-19-2009 10:07 AM
Images: 6
ChitownTundra will become famous soon enough.
ChitownTundra's Photo Albums My eBay
There are some hurdles to make a 2wd into a 4wd truck. Different Front spindles, Drive Shafts, Front Diff, Mounting Front diff, Axles, and then the Computer stuff.
About the only way I would attack it would be to get an entire rolled truck or wrecked truck from a yard.
This is assuming that the 2wd and 4x4 have the same front end frames as well.
It is possible on a Tacoma, but both truck have to be a 6lug set up, and not the 5 lug set up. The 5lugs and 6 lugs are totally different.
2007 RCSB 5.7 4x4 Black Sport
Tundra Racing 2/5 Drop, TRD Brakes, Wheels, Swaybar, Exhaust
Morel Elate 3 Way Speakers, Alpine PDX amplifiers, Phoenix Gold Ti 15" Subwoofer in custom enclosure, K40 Laser/Radar Detector, Seat Rail Modification, Back up Camera, Full LED Interior upgrade from VLEDS.com, Homelink Rear View Mirror,
http://s116.photobucket.com/albums/o4/sq60ss/
  #59 (permalink)
Old 06-08-2009, 06:15 PM
Gutz's Avatar
Images: 15
Gutz's Photo Albums
Originally Posted by Austin Aggie View Post
Gutz,
Anything can be done with enough $$$ and time.....
  #60 (permalink)
Old 06-09-2009, 12:14 AM
Dealer : Sunnyside Toyota Scion
2008 Toyota Tundra DC
Last Online: Yesterday 12:08 AM
Skyssx is on a distinguished road.
Send a message via ICQ to Skyssx Send a message via MSN to Skyssx Send a message via Skype™ to Skyssx Skyssx's Photo Albums
This is the best thing i've seen on this forum. I'll end up doing the conversion when I hit 60,000 miles. I figure that should be another 4 years or so unless I need to start driving a lot more daily.
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/161713-project-traction/
Posted By For Type Date
2nd Generation Tundra Building - Page 4 - Expedition Portal Forum This thread Refback 08-28-2009 01:44 PM
200 series transfer case into Tundra - IH8MUD Forums This thread Refback 06-05-2009 10:53 PM
