  2 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 04-03-2009, 11:52 PM
Jowett Engineering's Avatar
Preferred Dealer
Dealer : K-M Toyota
Last Online: Yesterday 11:04 PM
Images: 10
Jowett Engineering has blessed us with their presence. Jowett Engineering has blessed us with their presence. Jowett Engineering has blessed us with their presence.
Jowett Engineering's Photo Albums
Default Project traction
Let's face it, the Tundra has an issue with getting the power down to the terra. It's really no surprise with the power it has stock, never mind the supercharger (which is really the catalyst for me to find something as I'll be installing te TRD SC in the coming weeks). As most know, traction devices for the rear differential are non existent. Calls have been made, and if we are very lucky something MIGHT come along in about a year... Too long for me.
Soooo, what to do? Well, Toyota has already solved it for us... maybe. The Tundra is based on the 200 series Land Cruiser which comes with an AWD/full time transfer case (the Sequoia also has a version). This 200 series case may bolt into the Tundra with minor complications... GAME ON! I have a unit on the way.
Hmmmm, 500 hp and AWD going through a lockable Torsen center differential with 40/60 front to rear torque split...
Additionally, maneuvering this beast in tight places while in 4WD will be easier. For instance, while plowing the truck frequenty runs on and off previously cleared or dry pavement, this causes wind up and the inevitable bind/ tire dragging and larger turning radius.
Thoughts good and bad welcome....
Brian
Jowett Engineering
Extreme duty parts for the Tundra that works and plays.
Webpage coming soon!
2008 DC TRD Supercharged w/ AWD
Old 04-04-2009, 12:34 AM
Dealer : Universal Toyota
2007 Toyota Tundra Black Sport RCSB
Last Online: 11-06-2009 02:46 PM
Images: 19
Austin Aggie is on a distinguished road.
Austin Aggie's Photo Albums
Default Re: Project traction
My thoughts are - I hope that it works! I'm optomistic. It would seemingly be a fairly easy switch. Is the overall width of that third member the same as the Tundra (either the Sequoia or Land Rover)? I'm full-on tuned into this.
Old 04-04-2009, 01:42 AM
jgonzales's Avatar
Dealer : CarlockToyota of Tupelo
2009 Toyota Camry Silver TSS Edition,
2008 Toyota Tundra Black SR5 Crewmax
Last Online: 10-29-2009 05:51 PM
Images: 1
jgonzales is on a distinguished road.
Send a message via Yahoo to jgonzales jgonzales's Photo Albums My eBay
I'll be following this one too... count me in as interested.
Joe
Old 04-04-2009, 02:40 AM
thumbster's Avatar
Moderator
Dealer : Capitol Toyota
2005 Toyota Corolla,
2007 Toyota Tundra 5.7 RC SB SR5 Sport
Last Online: Today 12:57 AM
thumbster is a splendid one to behold. thumbster is a splendid one to behold.
thumbster's Photo Albums
I'm curious how the front diff comes into the equation - the ECM might be pissed off about not having full control of the transfer case.
Old 04-04-2009, 08:32 AM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
The width of the 200 and Tundra diffs should be the same. Though that may not matter as the stock front differential could potentially be retained by locking the ADD sleeve.
Right now it appears as though the the electronic shift actuator on the 200 series case will plug right into the Tundra harness and possibly use the Tundra 4WD ecu. The actuator on both vehicles work in nearly identicle ways... the difference lies in what the first function does, on the Tundra it shifts the case from 2WD to 4WD, on the 200 it locks the center diff. A quick run through the manuals for both vehicles shows the same wires and signals are used to show 4WD in the Tundra and center diff lock in the 200. Basically the stock t-case switch on the dash would work like this 2WD = AWD, 4HI = center diff lock (with resulting light on the dash), and 4LO = 4LO.
The significant problems I see right now are what to do with the front ADD actuator and the resulting signals it sends to the ECU.... and what will the truck's traction control and stability systems do when power is flowing up front and potentially causing wheel spin when it thinks it is in RWD?
Brian
Jowett Engineering
Old 04-04-2009, 11:59 AM
RONE's Avatar
Dealer : Little Apple Toyota
2008 Toyota Tundra 5.7L SR5 4x4 DC
Last Online: Yesterday 10:35 PM
RONE is a splendid one to behold. RONE is a splendid one to behold.
RONE's Photo Albums
Wow, good luck! That would make for a very impressive beast.
Old 04-09-2009, 05:06 PM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
The case has arrived. It dosn't look a whole lot different on the outside, the only noteworthy change is a large grouping of cooling fins cast into the front side and bottom of the case.
Front diff... no differential disconnect.
Inside things are quite different. The center Torsen Differential is a T3 3rd generation piece. It is rear drive axle biased and can supply up to 70% of the torque to rear wheels... that means less understeer.
Center Torsen differential, Torsen is now owned by Toyota.
Brian
Jowett Engineering
Old 04-09-2009, 05:11 PM
Last Online: 10-21-2009 09:47 PM
rangerbrown is on a distinguished road.
rangerbrown's Photo Albums
looking forward to how this will turn out.
Old 04-09-2009, 07:06 PM
THUNDERA's Avatar
Tire Roasting Member
Dealer : Stevinson Toyota East Inc
2007 Toyota Tundra,
- Other -- VW Touareg V10 TDI,
- Other - '94 Ford Taurus SHO
Last Online: 11-06-2009 03:18 PM
Images: 12
THUNDERA is a splendid one to behold. THUNDERA is a splendid one to behold.
THUNDERA's Photo Albums
I would *LOVE* to have AWD in this truck I wonder how it would effect power and fuel economy...
2007 Tundra DC Limited - Slate Metallic 5.7L 4WD
Red Rock Leather | Navigation | TRD Exhaust | TRD Sway Bar | TRD Supercharger | JBA Headers | URD MAF Calibrator w/ AFR Tune
ReadyLift 2.5" Front Spacers | 1" Rear Blocks |Pro Comp Front Coilovers | TRD Off-Road Package Springs | Bilstein Shocks | Pro Comp 6066 Wheels
BFG A/T KO 305/55R20 (33") |Bushwhacker Pocket Fender Flares (Color Keyed) | Escort SRX Radar Detection/Laser Defense System | Illumination by Hoen
- Coming Soon -
LED Tails | Tonneau Cover | Bed Divider | Rancho RS9000XL Shocks with in Cab Adjustibility | Pro Comp Traction Bars | Upgraded Stereo
Old 04-09-2009, 07:46 PM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
Toyota rates the Land Cruiser at 13/18. Power... it will probably feel the same or better in many instances.
Brian
Jowett Engineering
Old 04-10-2009, 12:07 AM
OTR's Avatar
OTR OTR is offline
Dealer : Ron Tonkin Toyota
Last Online: 10-10-2009 12:42 AM
Images: 6
OTR will become famous soon enough.
OTR's Photo Albums
Will this decrease towing abilities for any reason???
Old 04-10-2009, 08:43 AM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
There should be no reduction in towing abilities... if anything ability would be better due to the traction and handling benefits of AWD.
Brian
Jowett Engineering
Old 04-10-2009, 09:11 AM
VX_R-V8's Avatar
Dealer : Mountain States Toyota
2007 Toyota Tundra DCSB 5.7L 4x4 SR5
Last Online: Yesterday 09:39 PM
VX_R-V8 is on a distinguished road.
VX_R-V8's Photo Albums
Not to be negative in anyway, i believe this is a great idea once you've got it on and going. However, i do believe that you will encounter another problem in addition to the ones you have mentioned; Tundra has an excellent turning radius (best in class i believe), and you should be sacrificing that due to awd... Hope it works out for you though.. goodluck n keep us updated
Old 04-10-2009, 09:24 AM
TundraBay's Avatar
Dealer : Wayne Toyota
2007 Toyota Tundra,
Last Online: Yesterday 10:00 PM
TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One. TundraBay is the One.
TundraBay's Photo Albums
Leaving rear axle as is for the time being?
And all this can be had for a mere what - - 10 G?
[Tundra Bay]
Proud Member CBTMA
Radiant Red
Old 04-10-2009, 09:25 AM
Preferred Dealer
Dealer : K-M Toyota
Images: 10
The center differential should prevent any increase in turning radius. Additionally it will allow traction on surfaces like grass while minimizing tire impacts to it that regular 4WD wind up would cause while dragging a tire.
Brian
Jowett Engineering
LinkBack to this Thread: http://www.tundrasolutions.com/forums/tundra/161713-project-traction/
Posted By For Type Date
2nd Generation Tundra Building - Page 4 - Expedition Portal Forum This thread Refback 08-28-2009 01:44 PM
200 series transfer case into Tundra - IH8MUD Forums This thread Refback 06-05-2009 10:53 PM
