Old 04-11-2009, 05:37 PM
Dealer : Sun Country Toyota
Last Online: 11-03-2009 11:34 PM
Images: 34
brockoli is on a distinguished road.
brockoli's Photo Albums
Default can't stand it anymore!!
Ok, it's a small gripe but why is there an excessive amount of whine/hum/interference through the speakers when I have my satalite radio plugged in to the auxillary jack. I have to have the radio at about 40 to hear it clearly. If i switch to FM it's deafening! but not on Aux! Same satalite works great in my wifes Civic with the same wires. Is this an issue? Please help.
-Brock
Old 04-11-2009, 05:51 PM
Dealer : Bernardi Toyota
2003 Toyota Corolla,
2007 Toyota Tundra CM LTD 4x4
Last Online: Yesterday 09:27 PM
Bradscc is on a distinguished road.
Send a message via AIM to Bradscc Bradscc's Photo Albums
Default Re: can't stand it anymore!!
try this link...also do a search in this Forum on "aux whine"...there is a filter made esp. for this problem...good luck...B
Aux Input Engine whine
Old 04-11-2009, 05:53 PM
shooter2jim's Avatar
Slowpoke
1996 Toyota 4Runner,
2007 Toyota Tundra DCLB 4x4 5.7L
Last Online: Yesterday 11:00 PM
shooter2jim will become famous soon enough.
shooter2jim's Photo Albums My eBay
I had the same problem when one of the ends of the aux to aux cable was going bad. I know you said you were using the same cables, but try a new one just for kicks.
Old 04-11-2009, 06:12 PM
Images: 34
Thanks guys, I'll give that a shot. I haven't replaced the stock head unit yet but hopefully I won't need this item when that gets done. I'll let you know if it worked.
-Brock
Old 04-12-2009, 12:33 AM
Slowpoke
Yeah, keep us posted, please! I used an aux to aux cable I got off ebay with right angle mini plugs. It lasted nearly a year and one of the ends started getting a short. For a few days I could wiggle it and get it working, then it just went to the horrible hum/buzz full time. Unfortunately, even with a good cable neither XM unit I've owned sounds very good. I wish they'd get the audio quality better. After about 20-30 minutes of listening, the buzzy, scratchy audio does me in and it's back to FM or the iPod.
Old 04-12-2009, 12:47 AM
Dealer : Swope Toyota
2008 Toyota Tundra Salsa Red DC
Last Online: Yesterday 04:43 PM
chuckystoy has blessed us with their presence. chuckystoy has blessed us with their presence. chuckystoy has blessed us with their presence. chuckystoy has blessed us with their presence.
chuckystoy's Photo Albums
whine through speakers is usually due to cheap, low insulated wires picking up bleed off from other electrical sounds. if you hear your phone ring through your speakers or whine through them its just cheap wireing inside to save money. replace speaker and head unit helps sometimes.
just what little i know
good luck
chucky
Old 04-12-2009, 11:12 AM
WT's Avatar
WT WT is offline
Dealer : McGeorge Toyota
Last Online: Yesterday 10:25 PM
Images: 1
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Get one of the PAC units it cure the problem. It just seems there a ground loop that gets created when you plug in a source into the 3.5mm AUX jack and that same source is gettign power for 12V in the truck. I used the PAC SNI-1/3.5 and it cured my problem with AUX input from my Blackberry to the the AUX port to stream digital radio to it. Cheap and quick fix. Ypu you want to test it out get a secondary power soruce to feed the input device battery or maybe ever 12V from a battery charger you see that the humm goes away when there is silence or simply pull the plug from the AUX jack no more humm cause your introducing it through the source device when plugged in.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
Old 04-12-2009, 03:12 PM
SwingBringsPain's Avatar
Dealer : Butler Toyota Scion
2008 Toyota Tundra,
2007 Toyota Avalon Wife's LTD
Last Online: 10-22-2009 07:28 PM
Images: 18
SwingBringsPain is on a distinguished road.
SwingBringsPain's Photo Albums
Brockoli,
I had this same issue. The way I solved it was I looked on Craig's List and searched for Car Audio install services. I found a kid about 10 miles away who said he could fix anything, and install anything car-audio-related. He ended up installing a ground loop isolator and it fixed the whine 100%. He charged me $40.
What you have is called "Alternator Whine" or "Auxillary Input Whine." It has to do with how the stereo is grounded. I suggest finding a car audio guru in your area and asking him if he can fix alternator whine. It's a simple, cheap fix, but you'll spend a ton if you go to a "Pro" audio shop.
ColtFreaks dotcom - Huntin' Fishin' Trucks & Football
