Old 04-28-2009, 02:27 PM
2008 Toyota Tundra DCLB
Last Online: Yesterday 09:35 PM
Images: 16
nomadic is on a distinguished road.
nomadic's Photo Albums
Default Not a Tundra topper installed LB
I need a topper; we had this one in my back yard sitting for 5 years. It was on a 2001 gmc 3500. It does not fit exactly like I hoped but what the heck. The tail gate and the door have a ˝ inch gap. After setting it on the truck I thought long and hard about how to secure it to the bed. I came up with this method so that I would not lose my rails. They are 7 inch J (?) bolts from TSC. I had to cut a little off the J to get them to fit. I drilled the cap (it’s a fiber cap but the part that meets the bed is aluminum) with it sitting on the truck. I can insert the J bolts with the cap on the truck. I know a guy that does the one man paint shop thing and he painted it for 300.
pics
2008 DCLB work truck, diamond plate running boards , Firestone air bags
95 civic HB b18c1 “built” toy
I’m in your town or will be soon…
Old 04-28-2009, 06:09 PM
dariusld's Avatar
Dealer : Toyota of Chula Vista
Last Online: Today 01:34 PM
Images: 31
dariusld is on a distinguished road.
dariusld's Photo Albums
Default Re: Not a Tundra topper installed LB
You drilled holes in the bed?
Old 04-28-2009, 07:29 PM
SE2000's Avatar
Dealer : Northway Motor Car Corp.
- Other -,
2008 Toyota Tundra DC Blue Streak
Last Online: Today 04:43 PM
SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything. SE2000 has done just about everything.
SE2000's Photo Albums
He said he drilled the topper and used j bolts.
I think it is a good cheap solution and gets the old topper out of the yard.
Would a house AC gasket fill the gap?
Old 04-28-2009, 07:30 PM
Images: 16
i used the factory holes.
i do not know what all the holes are for in the pockets but the ones that go through into the bed worked for me
Old 04-28-2009, 07:37 PM
Images: 16
i just ran out to Home depot and got a foam piece intended for the bottom of garage doors for between the cap and bed, with the gap left were the tail gate and cap door meet i will have something fabed on the next work project. i'm thinking like a diamond plate rail guard that is a little thicker than the tail gate. i couldn't justify what they wanted for a new top for this truck when i had this one in the yard.
Old 04-29-2009, 06:48 AM
SE2000's Avatar
- Other -,
I was thinking, that did you see if you could trim the front of the topper at the bottom and slide it forward? Maybe you body shop could cut the fiberglass and reglass it to fit better. since the tundra cab leans forward you would only be doing the bottom and it would blend bettr
Old 04-29-2009, 07:02 AM
mendonsy's Avatar
Dealer : Lebrun Toyota
Last Online: Today 04:24 PM
Images: 7
mendonsy has blessed us with their presence. mendonsy has blessed us with their presence. mendonsy has blessed us with their presence.
mendonsy's Photo Albums
I guess it depends on how you want it to look. Considering how much you saved, it's not all that bad. Make sure that you check those J bolts for tight occasionally. Most RV stores have the standard bed clamps in stock.
07' SR5 DC 4x4, 5.7, TRD
Toyota SS steps
ARE MX cap
AMP bed step
DIY underseat storage
Weathertech Floor Liners
Weathertech Vent Visors
CBTMA member
Old 04-29-2009, 08:16 AM
Dealer : Bryan Easler Toyota
Last Online: 11-12-2009 12:58 PM
PPosey is on a distinguished road.
PPosey's Photo Albums
Pretty good, You may want to add a lock nut on top of the first one on those J bolts,,,, I have had a camper start squirming around pretty bad from the nuts working loose
2008 Tundra CrewMax SR5, Silver Sky 5.7 and 4x4
