Old 05-03-2009, 06:53 PM
Last Online: 06-09-2009 02:41 PM
tundrasniper is on a distinguished road.
tundrasniper's Photo Albums
Default ready lift prob-rubbibg in front
just installed 3/1 lift (still have fac tires/wheels)....drove it a short distance and it sounds like something in/on the front wheels is rubbing (like the brakes) I cant find it....any ideas
Thanks in advance
Old 05-03-2009, 11:19 PM
xtreme6669's Avatar
Dealer : Scott Toyota
2008 Toyota Tundra White Limited DC 4x2
Last Online: 07-20-2009 12:29 PM
xtreme6669 is on a distinguished road.
xtreme6669's Photo Albums
Default Re: ready lift prob-rubbibg in front
Thanks in advance
Its probably the bottom edge of your brake backing plate rubbing the rotor....
bend it away from the rotor a little at the bottom... see if that helps.
'08 DC limited 4x2, Pure Performance X-factor lift, Bilstein 5100 front and rear shocks, 18X9 ballistic Wizard wheels W/ +14mm offset, Nitto Terra Grappler A/T's 325 65 18, Diamond Eye 3.5" single exhaust.
Sig created WWW.SCREEN-FX.NET
Old 05-04-2009, 11:34 AM
Last Online: 10-12-2009 04:35 PM
JIMBOCLASSIC is on a distinguished road.
JIMBOCLASSIC's Photo Albums
What size tires are you running.....I've had rubbing probs with my 35x12.50 Nito Mud Grapplers on R18x9. They rub a little in the front inner fender liner and they rub slightly in the rear of the front tire on the body mount. This only occurs when I am turning. I had to cut the front liner and take the mud flaps off....now, no more rubbing. The only time it rubs now, is if I take a turn too fast...the rear part of the front tires still rub the on the body mount....not sure what to do about that...I guess slow down.....hope this helps.
Old 05-04-2009, 11:36 PM
xtreme6669's Avatar
The tire rubbing is not a metallic sound... I'm pretty sure he has a bent backing plate/shield.
Also you can cut out or have someone cut out part of the body mount to clear your tire.
