Instructions for replacing front brake pads on 2007 Tundra
+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Like Tree1Likes
Thread: Instructions for replacing front brake pads on 2007 Tundra
  1. #1
    Join Date
    Jul 2006
    Location
    Hebron, CT
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Default Instructions for replacing front brake pads on 2007 Tundra
    HI.
    I need to replace the front disc pads on my 2007 Tundra Double-cab 4x4 with 5.7L. Cant find instructions of a Haynes repair manual.
    Can anyone tell me how to change them?? I've changed brakes forever. Even did the rear disc brakes on this truck, no problem. I've never seen anything like the front discs.
    Help!
    Thanks,
    John
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Aug 2007
    Location
    College Station, TX
    Posts
    593
    Liked
    6 times
    Rep Power
    1265
    Default Re: Instructions for replacing front brake pads on 2007 Tundra
    They are pretty standard. What problems are you running in to?
    • TRD Supercharger ♠ TRD Swaybar ♠ TRD Catback ♠ Auburn LSD ♠ IPT Valve Body ♠ Line-X Xtra ♠ Undercover SE ♠ BFG A/T 285-65-18 ♠ Katskinz 2-tone ♠ Platinum Mirrors ♠ Homelink ♠ Much more...........
  4. #3
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    I haven't done mine yet, but my understanding is they are easier than normal because you can just pull some pins and the pads come out without removing the calipers. You might have to get creative compressing the cylinders though since the caliper is still attached.
  5. #4
    Join Date
    Jul 2006
    Location
    Hebron, CT
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    I guess my biggest problem was being surprised by what they look like compared to all the disc brakes I worked on. It doesnt look like you would remove the bottom caliper screw and swing it up, mainly because the brake line is toward the center of caliper and its partially metal tubing.
    I saw the pins, but wasnt sure how to compress caliper to free up the pads to take them out. Any suggestions to compressing the caliper?
    For once in my life I decided not to continue until I could get a better idea of what to do. Did not want to break anything and be stuck with a brakeless truck. Maybe I'm starting to learn with age. Maybe!
    John
  6. #5
    Supercharged Member Time4change's Avatar
    Join Date
    Aug 2007
    Location
    Las Vegas
    Posts
    2,668
    Liked
    190 times
    Rep Power
    17849
    No need to remove the caliper.
    Simply remove the wire stays, pull the pins. Clean the pins and grease.
    Leave the old pads in on one side while using channel locks, C-clamp, whatever to push the pistons open. If you do not leave old pads in the other pistons will come out of their bore.
    Swap pads/sides and repeat.
    If the entire job, including tire removal takes more than 15 minutes, you're doing it wrong.
    '07 Tundra Cmax, '95 T-100POS, '08 RidgeRunner, '08 KTM 300 XCW, (2) Sea Doos, Kubota FEL, '70 Mustang (in pieces)
  7. #6
    Join Date
    Mar 2007
    Location
    Minnetonka
    Posts
    195
    Liked
    1 times
    Rep Power
    38
    How long did your brake pad last ?
  8. #7
    Join Date
    Aug 2007
    Location
    Las Vegas
    Posts
    2,668
    Liked
    190 times
    Rep Power
    17849
    Quote Originally Posted by tundra1569 View Post
    how long did your brake pad last ?
    31k.......might have been able to squeeze a few more out of 'em, but I thought I was hearing things.
  9. #8
    Jedi Ninja in Training mxsjw's Avatar
    Join Date
    Jan 2007
    Location
    Lakewood, WA
    Posts
    8,309
    Liked
    13 times
    Images
    12
    Rep Power
    79
    Mine are about at 38K and have at least half their life left, but I'm really easy on my brakes (lots-O-downshifting) and do alot of freeway driving.
    Beer please!
  10. #9
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    [QUOTE=Time4change;1263807]
    [QUOTE]
    Forgive me as I have yet to take a look at this, but will there be clearance for c-clamps when the caliper is still on the rotor? I guess having not done this I don't see how a c-clamp is going to fit in there.
  11. #10
    Join Date
    Aug 2007
    Location
    Las Vegas
    Posts
    2,668
    Liked
    190 times
    Rep Power
    17849
    [QUOTE=gobblerman;1263876][QUOTE=Time4change;1263807]
    Dude, I used channel locks..........probably could use a wood shim. What ever will work. The piston goes in without a fight.
    The key is to do one side of the caliper at a time.
    Remove one pad; compress piston, install new pad.
    Remove other pad and repeat.
  12. #11
    Join Date
    Sep 2007
    Location
    Salem County, NJ
    Posts
    363
    Liked
    0 times
    Rep Power
    9
    [/QUOTE]
    Remove other pad and repeat.[/QUOTE]
    Cool. Thanks
  13. #12
    Join Date
    Jul 2006
    Location
    Hebron, CT
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    Thanks for all the info. Sounds like a piece of cake now. I have about 32k i think. Doing alot of towing, while owning my own tree service. Replaced the rear discs about 6 months or so ago. Those are much smaller than front.
  14. #13
    Veteran Member bilztrd's Avatar
    Join Date
    Sep 2007
    Location
    whittier ca
    Posts
    588
    Liked
    7 times
    Images
    5
    Rep Power
    1311
    how do the rotors come off?
  15. #14
    Join Date
    Feb 2009
    Location
    San Antonio
    Posts
    420
    Liked
    7 times
    Images
    3
    Rep Power
    9
    So why aren't y'all taking off the calipers. Are we so shade tree where we will just pad slap the brakes?
    Put matchmarks on the disc and hub if you're planning on turning the rotors (if not buying new ones)
    If you can't Dodge it, Ram it, then buy a Tundra
    08 5.7 Black D-Cab LTD Red Rock int....
  16. #15
    Join Date
    Feb 2009
    Location
    San Antonio
    Posts
    420
    Liked
    7 times
    Images
    3
    Rep Power
    9
    Also caliper bolts are to be torqued to 73 ft/lbs.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
