Rear Wheel Bearings
+ Reply to Thread
Page 1 of 6 1 2 3 4 5 6 LastLast
Results 1 to 15 of 77
Thread: Rear Wheel Bearings
  1. #1
    Rookie sclem is on a distinguished road.
    Join Date
    May 2009
    Location
    Macon, Ga
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default Rear Wheel Bearings
    I have a 2007 Tundra, I have had to put rear (left & right)wheel bearings on 2 (TWO) times. What is the problem?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Deliciously Blunt GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY wants you off his porch. GGWOODY's Avatar
    Join Date
    Mar 2007
    Location
    Here
    Age
    35
    Posts
    5,687
    Liked
    45 times
    Rep Power
    34847
    Default Re: Rear Wheel Bearings
    huh? Why?
    "I'm not stupid; I'm big boned!"- Woody
    CBTMA Member
  4. #3
    Hall of Fame Member Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote wants you off his porch. Mr. Creosote's Avatar
    Join Date
    Apr 2006
    Location
    Posts
    32,680
    Liked
    1517 times
    Images
    5
    Rep Power
    263671
    On my Gen 1 it took four trips to the dealer to resolve a growling rear bearing issue. A touch of quality control from the factory, plus a heavier helping of mechanic incompetence at the dealer.
  5. #4
    Veteran Member Stripped Honda will become famous soon enough. Stripped Honda will become famous soon enough. Stripped Honda will become famous soon enough. Stripped Honda will become famous soon enough. Stripped Honda will become famous soon enough. Stripped Honda will become famous soon enough. Stripped Honda's Avatar
    Join Date
    Jul 2005
    Location
    So Cal
    Posts
    859
    Liked
    0 times
    Rep Power
    11
    are you overloading the bed?
  6. #5
    Supercharged Member Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me has a brilliant future. Only Toyota for me's Avatar
    Join Date
    Nov 2006
    Location
    Pleasant Grove, UT
    Posts
    2,223
    Liked
    0 times
    Images
    50
    Rep Power
    59
    Quote Originally Posted by GGWOODY View Post
    huh? Why?
    T
    R
    O
    L
    L
    Could be why maybe?
  7. #6
    Don't argue with an insomniac. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein wants you off his porch. Frankenstein's Avatar
    Join Date
    Nov 2007
    Location
    Northwestern Ontario
    Posts
    5,567
    Liked
    8 times
    Rep Power
    29896
    Since I've never heard of ANYONE needing to replace the rear wheel bearings on a gen2 Tundra, I think the problem is, someone thinks he's being funny.
    I load the snot out of my truck, have 36,000 miles on the clock, and the bearings are like new.
    edit: I note from sclem's other posts he has 95,000 miles on the clock, and maybe hasn't kept it properly lubed. I believe the wheel bearings are lubed by the differential oil -- but maybe someone with more mechanical background will correct me on this -- so if sclem does a lot of highway miles (to reach 95 K in 1.5 years, I'd guess he probably does) there may have been inadequate slow speed and stop and go which I understand -- again could be corrected -- helps to lubricate the wheel bearings.
    Anyone else heard of rear wheel bearing problems on this truck?
    And to the OP -- have you changed your diff oil regularly?
    Finally, again to sclem -- how much does it cost to replace the rear wheel bearings?
    [Frankenstein's Monster]
    Proud Member CBTMA
    Radiant Red
    Cold Weather Pkg and Block Heater. Brushed SS Stepboards, TS Sticker
    Tires: BFG All Terrain T/A KO LT265 65 R 18, Diamondback SE Tonneau Cover.
    Curt Front Receiver, custom 8" extension, & Warn 8000lb receiver mount winch back or front,
    Tekonsha Prodigy Brake Controller DSP 16,000 lb 5th wheel hitch Firestone Ride Rite 2445 Air Bags & TRD Rear Sway Bar (Best, Cheapest Mod!)
  8. #7
    Just Call Me Hank Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank is a splendid one to behold. Tankerhank's Avatar
    Join Date
    Mar 2006
    Location
    Tucson
    Posts
    1,420
    Liked
    0 times
    Images
    46
    Rep Power
    27
    Lightbulb Re: Rear Wheel Bearings
    Quote Originally Posted by TundraBay View Post
    You are right the bearings are lubed from the differential, but it should not matter if he drives freeway or stop 'n' go, I tend to lean towards the differential fluid is not at the proper level and he is running "dry" bearings. Of course over-loading means all bets are off...:whoo:
    Hank
    2007 Tundra SR5 DC LB 5.7, Underseat storage, Sonar, Backup Camera, Prodigy brake contoller, Reese 16k 5'er hitch, Towing Mirrors, Michelin LT AT2 275/65R18/E, Hellwig Helper Springs 2,000 lbs, 7/75 Platinum Warranty from Handy Toyota.
    Future mods:
    Stebel 300hz Horn
    Fog Lights
    2000 Tundra (bought 9/9/99)
    JBA Headers
    Gone but not forgotten~
  9. #8
    Junior Member Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold. Rockpig is a splendid one to behold.
    Join Date
    May 2009
    Location
    Around the Corner
    Posts
    198
    Liked
    2 times
    Rep Power
    22
    I've replaced several of these bearings on my trucks (94 and 85 4Runners). They are sealed bearings that are prelubed, no grease packing needed. To properly take them off they must be prressed off. There are tricks that can be used to get them off by building a home made SST and slamming it on the ground. This is fine to remove the bearing since it's bad anyway, but the new one should be pressed in. Maybe they used the slam it ont he ground method to put the new bearings on also!
    I don't think the bearing is lubed by the diff at all, not on my older trucks at least. There is a seal that the rear axle slides into inside the housing. The bearing would technically be on the other side of this seal closest to the axle stub. Your rear axle tube should have a bulge to it when it reaches the outermost portion, this bulge is where the bearing rides.
    If I can find any pictures of the setup on my trucks I'll post up.
  10. #9
    Join Date
    May 2009
    Location
    Around the Corner
    Posts
    198
    Liked
    2 times
    Rep Power
    22
    Toyota Maintenance: Replacing Rear Wheel Bearings and Seals
    Here is the processs I'm talking about, this is for drum brakes however. Don't know how it works for the Tundra with disc, but think it would be essentially the same.
  11. #10
    Rookie macaroni is on a distinguished road. macaroni's Avatar
    Join Date
    Jan 2003
    Location
    birmingham
    Posts
    18
    Liked
    0 times
    Rep Power
    0
    Well i had to have one of mine replaced under warranty, they told me it was my tires making all that noise since my 5K mile oil change then they finally got it right at 20k mile service. So, I am SOMEONE who has had a problem with my RWB in a 2008 tundra. But twice does seem excessive.
    Cheers.
  12. #11
    Lurking Member LMDAVE is on a distinguished road.
    Join Date
    Jan 2005
    Location
    MEtairie, LA
    Posts
    20
    Liked
    0 times
    Rep Power
    9
    I have a 2005 Tundra. It was making loud humming noises and I pretty much deterimined it wasnt' the tires. I'm out of warranty with 65,000 miles. Toyota service said I had to have both rear axle bearings replaced. They quoted me $1120 for parts and service.
    So, they got my money now. I just wanted it fixed since I'm planning on keeping this truck for a while. I pick it up this afternoon.
  13. #12
    Rookie rstet10712 is on a distinguished road.
    Join Date
    Jul 2010
    Location
    Home
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I have a 2008 Tundra I purchased new May of 2009. At 30,000 I was getting a slight growl, only noticible when I was coasting to a stop. I had my 30,000 mile check-up done. All the required maintainence. Had the front end presicion aligned, the wheels all balance. One even had the tire properly set to the rim. They checked the differential fluid. All up, but the rear had a sheen to it. Had new synthetic lube installed (manufacturers spec). That drone though was still there. Hardly noticable, but there. For the last few weeks it has gotten more pronounced. Another check. Left rear wheel bearing. At least I know I wasn't crazy. So now it's off to the dealer I had look at it at 27000 and was told it was a "normal" noise. NOT! My truck is usually just about empty. So there you have it.
  14. #13
    Supporter cwit has disabled reputation cwit's Avatar
    Join Date
    May 2007
    Location
    keeseville ny
    Posts
    1,331
    Liked
    8 times
    Images
    3
    Rep Power
    911
    I have to go with troll he hasen't been baqck .
    Charlie & Linda
  15. #14
    Preferred Dealer Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes. Jowett Engineering comes in many shapes and sizes.
    Join Date
    Jan 2008
    Location
    North Adams, Massachusetts
    Posts
    1,167
    Liked
    54 times
    Images
    10
    Rep Power
    4925
    Toyota recently issued a TSB for the rear bearings on our trucks... they will replace them, no charge.
    Brian
    Jowett HD Tundra Parts
    Driving the Tundra aftermarket forward.
    ARB 10.5" Locking Differentials now Available!
    "The person who says it cannot be done should not interrupt the person doing it."
    brian@jowettengineering.com
    www.jowettengineering.com
  16. #15
    Rookie 07 tundra is on a distinguished road. 07 tundra's Avatar
    Join Date
    Jul 2010
    Location
    nh
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    i had my rear wheel bearings done too with about 28000 miles
    07 tundra dc 5.7
    my first toyota and could not be happier with this truck
Posting Permissions
  • You may not post replies
  • You may not edit your posts
