If I read the PDF file correctly it syas to adjust you must turn the vertical AND horizontal screw at a 5:4 ratio for adjustment. Since I put a leveling kit on I seem to be blinding folks and wanted to adjust my headlights. Those that have performed an adjustment, did you adjust both screws at the 5:4 ratio?
I could use clarifacation on this also. A very helpful thread for me. Thank you.
__________________ 2007 Tundra DC SR5 5.7 4X4 Superwhite & debadged
Truxxx 3 & 1 lift <> Tuned Unichip <> Gibson single cb exhaust <> TRD CAI <> Aries side bars <> Carriage Works replacement grill <> TRD sway bar
After my lift, all I did was pull up to my garage door (about 5' away), turned on the headlights, turned each screw till they were a couple inches lower, and confirmed they were even from right to left.
That's how I've adjusted the headlights on every vehicle I've ever owned, I can see at night, and I don't get flashed by oncoming traffic...Who needs some fancy smanshy directions???
Beer to YOU my man!
And I spose' to help clarify, what the directions are telling you with the 5:4 ratio is this...
As you turn the vert. aim screw for up and down adjustment, it will also move the beam right or left some, so you will have to adjust the horiz. screw to compensate for the right or left movement.
Mark your garage door with masking tape, the headlights will create a very distinct line at close range. Mark the line for height and mark the outside edge of the line where the light cuts off. As you lower the light line with the vert. screw, bring the outside cutoff back out or in with the horiz. screw to match the tape mark.
If you've never done this before, it'll all make sense when you pull up to your garage door with the lights on...I promise...oh, and it helps if it's dark out or at least duskish.
I did a LONG thread about this about two years ago....SHEESH, wheres the LOVE????
__________________ Black 2007 D/C Limited 4x4, seems to have ALL the options, Flowmaster Dual Delta 40's, K&N drop in filter, Rhino Liner', 3" frt 1" rear Daystar leveling kit, BFG Radial All Terrain TA's 305x65x18, Moto Metal M0951's in Chrome 18x9. Fully DeBadged , Stebel horn, C/W grill, TRD Swaybar, Wet O's, Craven Speed Stubby Antenna, 10,000 lb winch, H11 bulbs, Production date 8/07
"CBTMA Member" all that is remaining is:
Black Mod Headlights 1997 Chevy Tahoe Sport 4x4 2008 Sequoia Ltd. Slate Metallic (purchased on 3/28/09)
"Some people spend an entire lifetime wondering if they made a difference. The MARINES don't have that problem." President Ronald Reagan 1985
