Old 05-12-2009, 05:46 PM
OregonTundra's Avatar
Dealer : Mic Mac Motors
- Other -
Last Online: 10-04-2009 01:07 AM
OregonTundra is on a distinguished road.
OregonTundra's Photo Albums
Default Headlight Adjustment - I can't find screw!
I've looked at all the threads about HeadLight Adjustment for the Vertical, I even looked at the PDF file. The picture in the PDF is not clear as too where the screw is.. it kinda points to my front bumper...
I also read about it being just to the right ontop by the fender...
I look and LOOOoooOOk, but can't find this stupid screw adjuster...
Can any point out or give a picture showing a dumb @ss like me... its some time the simple things in life that elude me...lol..
Thanks
<------CrewMax Limited 5.7L, 4X4-Slate Metallic, Graphite Leather, Revtek 3" Lift, Moonroof, Mudguards, Cold Kit, Sonar, Line-X Bedliner, 20" Stock Wheels with Toyo 33/1250-20 M/T Tires, Brushed stainless steel running boards, Door sill protectors, Running Lamps, Husky Liners, Mounted Garmin Nuvi 660, ConsoleVault. Wade Vent Visors, Volant CAI, Snugtop SuperSport, Wet Okole Seat Covers, De-Badged - FUTURE MODS: PIAA 540 driving lights in place of FogLights.
Old 05-12-2009, 10:10 PM
Sanosuke's Avatar
Dealer : High River Toyota
2007 Toyota Tundra SR5 w/4x4
Last Online: 11-17-2009 05:50 PM
Images: 8
Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor. Sanosuke is a superior contributor.
Send a message via ICQ to Sanosuke Send a message via AIM to Sanosuke Send a message via MSN to Sanosuke Send a message via Yahoo to Sanosuke Sanosuke's Photo Albums
Talking Re: Headlight Adjustment - I can't find screw!
Thanks
ITs right there -- its a plastic cap you pull off and you stick your adjustment tool in there.
Sanosuke!
Old 05-12-2009, 10:28 PM
dariusld's Avatar
Dealer : Toyota of Chula Vista
Last Online: Today 01:34 PM
Images: 31
dariusld is on a distinguished road.
dariusld's Photo Albums
Default Re: Headlight Adjustment - I can't find screw!
Sanosuke!
Mine doesn't have a plastic cap
Old 05-12-2009, 11:16 PM
Sanosuke's Avatar
Images: 8
I just found the PDF and sure enough, the screw is located behind the headlight... I have the image from the PDF and will be putting the image here.
Old 05-12-2009, 11:34 PM
zzzpro's Avatar
Dealer : Frontier Toyota
2007 Toyota Tundra 4X4 crewmax
Last Online: 10-23-2009 10:45 PM
Images: 13
zzzpro is on a distinguished road.
zzzpro's Photo Albums
It's not so much a screw as a gear head that has 2 plastic wings on either side. a phillips head long screw driver fits easily between the plastic tabs which aligns the screw driver and the phillips will then turn the screw/gear head. Did that confuse you more? Just know that I was looking for a screw on mine and it was not what I expected. And no, there is no cap on it.
2007 4X4 SR5 ,Crewmax, Slate Metallic , 5.7
TRD Exhaust and CAI
TRD sway bar
Camburg Coilovers and UCA's
Rancho 9000xls
18" Ultra Goliaths
275/70/18 Goodyear wrangler silent armour
Carriageworks grill
Color matched front cowl/grill
Hunt hard, Kill Clean, Apologize to no one!
Old 05-12-2009, 11:44 PM
mxsjw's Avatar
Jedi Ninja in Training
Dealer : Toyota of Puyallup
- Other - 2003 VW Passat,
Images: 10
mxsjw's Photo Albums
Send beer, mine has a cap as shown with the yellow box around it, you can flip up the little door on top (yellow arrow), insert phillips and adjust, or you can remove the whole cap and use an 8mm socket or wrench.
See pics and don't forget to send that beer.
Headlight Adjustment - I can't find screw!-headliteadj1.jpg   Headlight Adjustment - I can't find screw!-headliteadj2.jpg
Beer please!
Old 05-12-2009, 11:47 PM
zzzpro's Avatar
Images: 13
Now that is wierd. That looks nothing like mine. What gives?
TRD Exhaust and CAI
TRD sway bar
Rancho 9000xls
18" Ultra Goliaths
Carriageworks grill
Old 05-13-2009, 12:50 AM
- Other -
Thank you very much... that is what my 07 Limited looks like.. the PDF manual image isn't even close to helping figure this one out..
PM your address to me.. I'll send beer!
Old 05-13-2009, 12:52 AM
Sanosuke's Avatar
Images: 8
The PDF file I posted DOES point out the location of the hole to insert the screw driver though. Maybe you could use a new pair of bifocals? No offense intended though..
Sanosuke!
Old 05-13-2009, 07:03 AM
seadragon's Avatar
Dealer : Milton Toyota
2006 Toyota RAV4 Limited,
2007 Toyota Tundra 5.7L DC 4x4 SR5 TRD
Last Online: Today 05:24 PM
seadragon will become famous soon enough. seadragon will become famous soon enough.
seadragon's Photo Albums
Guys,
There are 2 adjustment screws on each headlight. One is for vertical aiming and the other is for horizontal. The one shown in the pdf is the vertical adjuster, although the diagram is a bit confusing. It is located at the bottom rear of the headlight assembly.
The screw that mxsjw is showing with the cap on it is for horizontal adjustment. You usually don't have to adjust this setting.
Here is the vertical adjuster... you just use a long phillips screwdriver to adjust it. There is a groove that guides the screwdriver down the the adjuster screw.
2007 Tundra 4x4 5.7L SR5 TRD BLK
Old 05-13-2009, 07:19 AM
Henry T's Avatar
Dealer : St. Charles Toyota
Last Online: Today 04:34 PM
Images: 25
Henry T will become famous soon enough. Henry T will become famous soon enough.
Henry T's Photo Albums
No cap on mine. If you use the worm gear type set up that they developed just remember that the way you turn the screw driver is the exact opposite of what you would think, as the worm drive turms the main screw clockwise to raise the headlight, so you must turn your screw driver counterclockwise. If you go the direct route and get a small socket on the main screw then it is clockwise to raise.
2007 Tundra DC SR5 TRD Nautical Blue, 5.7, 4X4, Toytec 2.5" front lift, 1" rear block, Diff. drop kit, BFG AT KOs 305/65R/18, JVC KW-AVX810 head unit, HD Radio, Sirius, JVC CH X1500 12 disc CD changer, Scosche piano black dash kit, Alpine 550 4 channel amp 90 watts per channel, Focal 165 V1 components front, Cliff Designs CD60-4C Components rear, Modified Pioneer sealed sub box, MTX Audio TT 6510-04 10" shallow sub, Alpine 450 mono amp 220 watts, R/F 1 farad digital capacitor, All 4 doors and rear wall DynaMatt, Hard wired Escort Passport 8500 X50, Boyo VLT 300 rear veiw camera.
Old 05-17-2009, 05:09 PM
- Other -
Thank You SeaDragon ..
I would not been able to do this had you not provided your pictures..
And Yes.. I probably could use the glasses... but I'm not ready yet to admin I need them.. maybe a couple more years.. when I'm over 50! ...
Lol
Old 11-03-2009, 08:17 PM
Last Online: 11-07-2009 10:11 AM
DENVER TUNDRA is on a distinguished road.
DENVER TUNDRA's Photo Albums
Thnaks seadragon- clear ,concise-nice pics- need more like you .
Old 11-03-2009, 08:45 PM
Djackman777's Avatar
Last Online: 11-19-2009 08:38 PM
Djackman777 is on a distinguished road.
Djackman777's Photo Albums
Use an 8mm socket with a round spinner rachet or a stubby phillips screwdriver. Both will work.
2008 Tundra Crewmax LTD Black/Redrock, Nav, Mnrf, 4WD
Old 11-03-2009, 11:56 PM
Last Online: 11-17-2009 12:29 PM
harleyheaven is on a distinguished road.
harleyheaven's Photo Albums
If I read the PDF file correctly it syas to adjust you must turn the vertical AND horizontal screw at a 5:4 ratio for adjustment. Since I put a leveling kit on I seem to be blinding folks and wanted to adjust my headlights. Those that have performed an adjustment, did you adjust both screws at the 5:4 ratio?
