Re: Tcs/vsc
I have also heard that you can simply unplug one of the front wheel speed sensors and the system will fault and turn off... once you plug the sensor back in and restart the truck the system will re-initalize and turn all the warning lights back off....(haven't tried it) but for the drag strip all you need to do is press and hold the trac. control button one time for 3-5 seconds until the trac, alsd and vsc off light are all on... if you do it twice you will also turn off the asld... there will still be some trac. control lurking thou if you get the truck really sideways... not likely unless your playing in the dirt or on a road track...
'08 DC limited 4x2, Pure Performance X-factor lift, Bilstein 5100 front and rear shocks, 18X9 ballistic Wizard wheels W/ +14mm offset, Nitto Terra Grappler A/T's 325 65 18, Diamond Eye 3.5" single exhaust.
Sig created WWW.SCREEN-FX.NET
