I have a Tundra DC 5.7 Liter 4x4 long Bed 20 inch rims Nitto 275/65/20's
Does anyone use the tow haul mode when there towing? I tow almost everday, and definitley noticed more power, or something. But I also noticed my gas mileage was less than when I tow without the tow haul mode on. Just wondering what people have to say about it?
oh yea i also put a 3/1 ready lift kit on with those nittos. I am talking about my experiences prior to the mods. I used it a few times (the tow haul feature) but then just stopped using it. Should I be?
The Tow/haul mode will give you different shift points for the load. I use it when I have max payload and other say to use it with a 5000 lb trailer.
-rockstate
"Mr. Policeman" by Brad Paisley
Hey, hey, Mr. Policeman
Bet I can drive faster than you can
Come on Tinker, let's have some fun
Go on shoot me with your radar gun
You look bored and I sure am
Catch me if you can
Tow-haul does not give you more power when towing. It changes the shift points in the trans that supposedly translate into a better towing experience. I always use it.
2007 SR5 CrewMax, SiLver w/5.7 V8
>Bakflip Tonneau Cover.
>Rampage Running Boards.
>Heavy Duty 6 ft. Rubber Bed Mat
out of my 2000 Tundra cut to fit!
If I recall correctly (and it makes sense) it will hold a gear longer (into higher revs) before shifting up into the next gear, and will downshift a bit quicker before the engine revs drop much. Higher revs = a bit higher torque, but also a bit more fuel consumption.
I use tow/haul when I tow my 11,000 lb camper.
__________________ [Frankenstein's Monster]
Proud Member CBTMA
Radiant Red 2007 Double Cab Limited w/Graphite Leather Interior
Factory Nav, Sonar, and 10 spkr 440W JBL stereo with Sirius (sweet) Cold Weather Pkg and Block Heater. Brushed SS Stepboards,
You recall correctly.
Different strokes for different folks. I NEVER use it. I hate the shifting. I pull a 6000 pound boat. Depending on wind, hills, speed I like to use S4 or S5.
I bought mt Doublecab limited in Sept 08. Towed a 5000 lb bumper pull up the Blue Ridge parkway and Skyline drive in October. I used the Tow/Haul Mode in those sttep hills and could feel it mostly on the down grade. I think it kept me from riding the brake as much with the feature call SHIFT LODGING, where it holds lower gears longer acceleration and locks in a lower gear while going down hill, like shifting down to 2nd in the older automatic trannys. I read about it and a lot of research went in to it so I have to think that there must be a benefit to musing it under load.
